I'm sold on gearboxes, but there are always compromises:
- Poor/no shifting under load
- Additional transmission losses
- More parts to go wrong within an already very unreliable system (I mean ebike motors as a whole, not pinion specifically)
- Heavier system weight
- Possible kinematics and geo constraints (e g. The Nicolai having a very long chainstay but limited to 160mm rear)
I believe shifting under load is fine. I’ll let you know though. These are other benefits with shifting, such as shifting at a standstill, whilst coasting as well as general gearbox benefits, like extremely low maintenance, zero setup faff, no cables or gears to index, no screws to mess around with etc etc.
There’s way more clearance out the back and far less risk for hitting rocks or logs, like there is with a derailleur hanging 6cm from the ground (on a mullet bike).
Transmission losses may be a thing, but I think on an ebike with 160Nm in gears 1-4 and good power everywhere else, this is a minimal downside and virtually imperceptible to most users.
Parts to go wrong is a concern. I hope this system is reliable! That’s part of why I’d like to test it. Especially over a dirty wet British winter - I’d like to try it in the worst of conditions. I’m looking forward to not having to degrease, clean and lube a chain though!
The new Nicolai isn’t that wild at all - the geo is standard enduro geo really. Mine has a 170 fork, 63.5 head angle, mullet, 455 chainstay, yes the wheelbase and front centre is longer than usual bikes, but they do so many sizes they will likely fit most riders
