Spectral:On Ride E coil.
Dhd12
Almería (Provincia)
So after some deliberation and a short wait the Fast Suspension Ride E arrived. The sag is bang on 30% as requested so Fabien nailed the spring rate. Feels super plush and should be a perfect match for my 170 Smashpot coil conversion in the fork. A quick blast in my olive grove suggests it’s as expected. Off to ride now 👍
'Edit' don't know why the photos won't load up
View attachment IMG_2124.jpeg View attachment IMG_2126.jpeg View attachment IMG_2127.jpeg
View attachment 141200 View attachment 141201 View attachment 141202
Hi, would you mind advising your riding weight and what your spring rate is? Just got the same shock - my LBS mechanic chose the spring which is 550lb and only giving me 23% sag (80kg riding weight). Our bikes are different which is major factor, but just to give me another baseline to compare. I have a stock Fox Factory 38 up front so maybe less sag in the rear will be OK balance wise?
Cheers.
Cheers.
I weigh 75kg ready to ride and have a 450 lb spring. Works perfectly for me, just added a couple of clicks of rebound from how Fabien at Fast set it up. Around 28% sag. Sounds like yours is a bit to heavy maybe. Email Fabien @ Fast he will advise I’m sure
