It varies so much depending on the steepness of the hill, your speed, your weight etc, so its really hard to give any numbers that you can compare directly with your fazua numbers, the only way to know for sure for your circumstance would be to try one, But I get between 900m-1000m usually.What's the range like in the middle power setting? Just really the climbing distance as most of my rides are up a steep fire road (400m) and bombing down an enduros trail which I do with the power off. On the Fazua I could get 1200m in the highest assistance and around 1500m in the middle setting.
Depending on the terrain, most of our rides on the Trek Fuel EXe have typically racked up 1,000-1,300m of elevation gain over a distance of 30-38km. We’ve mostly utilised the Mid power setting, which strikes a nice balance for general trail riding.
To see how the Fuel EXe’s efficiency compares directly to some of the other e-MTBs we’ve reviewed, we subjected it to our standardised range test. This involves the same rider pedalling up a road climb with a 10% average grade, with the motor set to its most powerful setting, before bombing back down a singletrack descent. The idea is to see how much elevation, and how many laps each bike can rack up on a single charge, while keeping the variables as constant as possible.
- Norco Sight VLT (Shimano EP8, 900Wh Battery) – 2,478m climbing (12.8 runs)
- Rocky Mountain Altitude Powerplay (Dyname 4.0, 720Wh Battery) – 2,108m climbing (10.9 runs)
- Cube Stereo Hybrid 160 (Bosch Gen 4, 625Wh Battery) – 1,800m climbing (9.3 runs)
- Canyon Spectral:ON (Shimano EP8, 630Wh Battery) – 1,570m climbing (8 runs)
- Orbea Rise (Shimano EP8-RS, 360Wh Battery) – 1,388m climbing (7.2 runs)
- Specialized Levo SL (SL 1.1, 320Wh Battery) – 1,377m climbing (7.1 runs)
- Trek Fuel EXe (TQ-HPR50, 360Wh Battery) – 1,312m climbing (6.8 runs)
- Specialized Kenevo SL (SL 1.1, 320Wh Battery) – 1,053m climbing (5.5 runs)
You will get better range and more power with the Fazua. There are tests on line. It Is my understanding the Rise is still the most powerful and best range with the 540 wh battery. Great deals on those as well. Fazua has too many issues, and that is the same across all the bikes that use it.What's the range like in the middle power setting? Just really the climbing distance as most of my rides are up a steep fire road (400m) and bombing down an enduros trail which I do with the power off. On the Fazua I could get 1200m in the highest assistance and around 1500m in the middle setting.
1300 HARD miles, lots of deep water crossings (motor is IP67) zero issues. Bike is solid!Hi all I'm in the market for a lightweight ebike after getting a refund on my Heckler SL (numerous failures in first month of ownership). I'm looking at the Fuel EXE, are there issues with this or is it a reliable motor?
