Because the EXe is different.What’s the reason the Hope Cranks from my Levo won’t work on the EXe?
I reckon they'll fit fine, but the q factor may be differentWhat’s the reason the Hope Cranks from my Levo won’t work on the EXe?
Yep they're both isis.It’s the same interface right?
Q factor is the total width between the two cranks where the pedals fit?
Where exactly is the shock close to the the frame? Is it the reservoir close to the downtube on full compression of is it close to the range extender?
Double check torque on motor bolts first. It work for me.Bike is creaking…again!. This time
it’s coming from the motor area. I don’t have the tools or expertise to remove all the motor bolts as well the chain ring. Has anyone done this? Is there a tutorial video haha. Also, does it matter what grease I use when re greasing the headset? I just use regular bontrager grease. I’ve cleaned and regreased the headset but still hear a creak or two ugh.
Can you do that without removing the chain ring? There's 2 motor bolts?Double check torque on motor bolts first. It work for me.
Read the service manual!Can you do that without removing the chain ring? There's 2 motor bolts?
Then you REALLY should check your local bike shop and ask for help.I don’t have the tools or expertise to remove all the motor bolts as well the chain ring.
Yes, they are accessed from the non drive side, it just needs an Allen key.Can you do that without removing the chain ring? There's 2 motor bolts?
Yes it possible. Two Allen bolt heads.Can you do that without removing the chain ring? There's 2 motor bolts?
I didn't read the entire 95 pages here so apologies if this has been discussed...Bike is creaking…again!. This time
Maybe B-RAD SYSTEM. Flexible and affordable.Anyone riding packless on the EXe?
I’m trying to work out how to fit a bottle, OneUp pump and a small pack for phone, keys and a small multi tool.
Have a Spesh MTB Bandit to hold a tube under my seat
On my Large EXe:Anyone riding packless on the EXe?
For bolts - i used rotor bolts, they are about 15mm long which is perfect for fitting a pump under the bid on cage- fiddle to install of course, they are torx t20 i think, so useful if you have a torx bit set for a drill driver - it enables you to get it up to finger tight without too much swearingThanks guys
I currently use a Henty Enduro pack but trying to keep it simple
The OneUp pump has an EDC tool and inflator so I’m good there.
I’ve also got a Wolftooth B-RAD plate, so maybe a TekLite bag under the top tube for a phone, keys and a few bits?
Also, what length bolts are people using for a pump under the bottle cage? The stock ones are too short…
