140 HPC TM2023 Upgrade options.
Sussex UK
Hi Fellow CUBEer's,
I've just ordered a 140 HPC TM2023 to replace my 4 year old Levo for trail use, and will be looking to upgrade a few things....
Forks, probably just a new damper cartridge (Grip 2?).
Shock, is there a list of what defiantly fits? Looking at Cane creek Kitsuma Air or Ohlins TTX1air but open to other options.
Is there any room to 'over shock' by 5mm? (205x65)
Wheels, I will just steal my DT Swiss from my other bike :) All my bikes are 29".
Brakes, will try the MT7's as they are, but got spare Shimano levers if needed....
Gears, I will swap over my GX AXS or 'downgrade' to a BOX 9/10 speed.
Colour - Vinyl wrapping will be needed to hide the pea green, yuck!
Mainly riding Surrey Hills, longish XC style on North/South downs & XC/Trail riding in Wales/up north.
Occasional BPW trips and also Alps this year (but Levo can take that abuse...lol)
Any other tweeks or mod's to consider or feedback on my choices welcomed.
A little foam padding on the inside of the battery compartment quiets them a little. In particular a thin patch on the upper rear side of the battery. The original stems are garbage too. Other than that I'm sure you will love it. My cube was the best thing I ever bought.
Hei CUBEer's,
Tilasin juuri 140 HPC TM2023:n korvaamaan 4 vuotta vanhan Levon polkukäyttöön, ja aion päivittää muutamia asioita...
Haarukat , luultavasti vain uusi vaimennuspatruuna (Grip 2?).
Shock , onko olemassa luetteloa siitä, mikä sopii uhmakkaasti? Tarkasteltaessa Cane creek Kitsuma Airia tai Ohlins TTX1airia, mutta avoin muille vaihtoehdoille.
Onko tilaa "yliiskulle" 5 mm? (205x65)
Pyörät , varastan vain DT Swissin toiselta pyörältäni :) Kaikki pyöräni ovat 29".
Jarrut , kokeilevat MT7:itä sellaisenaan, mutta hankin Shimanon varavivut tarvittaessa...
Gears , vaihdan GX AXS:ni tai "lasken" BOX 9/10 -nopeuteen.
Väri - Vinyylikääre tarvitaan piilottamaan herneenvihreä, jee!
Pääasiassa ajelu Surrey Hillsillä, pitkähkö XC-tyyli pohjois-/etelälaskuissa ja XC/Trail-ajo Walesissa/ylös pohjoiseen.
Satunnaisia BPW-matkoja ja myös Alpit tänä vuonna (mutta Levo kestää sen väärinkäytön...lol)
Kaikki muut harkittavat viikot tai modit tai palaute valinnoistani ovat tervetulleita.
Minulla Cube Hybrid 140 sl 2019.Päivitin Fox 36 160mm,performanse.Taakse tulee Float 210x55mm.Maavara nousee mukavasti 155mm,kampi.Nämä toimii omassani.
