Cushcore bead dropper
Bones
752
991
Harrogate
Has anyone used this tool and is it any good?
I have rimpact inserts with a pro front and an emtb rear.
The rear is a total bitch to sort out and it's the only time in years that I have broken tyre levers.
So I'm wondering if its worth investing in this tool or try spoons like the old days 😅
Alexbn921
545
506
East Bay CA
Best level ever made. I have 2 and you can lock each one onto the bead and work the tire onto the rim from both directions.
Bones
752
991
Harrogate
The problem I have with the insert is getting the tyre under it and into the middle of the rim. Because the insert is that tight on the rim its quite hard to get any slack on the tyre.
kombos
250
309
Arizona
I like using one to push the bead inward. Can appl a lot of force easily pushing on the ball end it has.
Alexbn921
545
506
East Bay CA
Once you have tension on the beed from both sides it will just slide under the insert. Then you move the levers to create more tension and repeat
James_MTB
266
216
I've snapped two! The warranty is great though.
I HATE installing tyre inserts on carbon rims
521K
