Levo Gen 3 Battery 320Wh
CjP
PRIME TIME
1,671
2,393
Everywhere
320wh/SL = 500wh/FF
320WH + 160wh extender/SL = 700wh/FF
In my experience SL gave just a tad more range if both SL and FF were in turbo with a similar rider. Everytime
Streddaz
251
358
Tasmania
Turbo Levo SL Expert Carbon​
So small battery? Others have 630Wh / 700Wh / 900Wh
How many km?
How may Km, is a very open-ended question.
I have got 75km out of one charge, from 86% to 9% but most of the distance was relatively flat cycle path. I have got 53km from mainly single track with 16% remaining.
Smooth road/pathway with little elevation you will get a lot of Km and steep technical single track will give you a whole lot less Km. Rider weight and fitness, also makes a considerable difference. The lighter the rider the more Km and the stronger the rider (ie the more power the rider puts in) the more Km.
Also depends on the amount of assistance selected. I can get unlimited Km if I set the assistance to zero ;)
G-Sport
253
187
Yorkshire
In trail mode, I get 30km and 1000m of climbing with about 20% battery left at the end. I'm about 80kgs in riding gear.
I would suggest always aiming to have 10% minimum left at the end as a buffer to protect the battery and because it starts limiting the assistance at about 13% remaining. This is in reasonably warm weather (12C). Some range loss when cold.
