Like this..
2020-2021 Trek Rail Rear Guard by DeltoroIndustries on Shapeways
Check out 2020-2021 Trek Rail Rear Guard by DeltoroIndustries on Shapeways and discover more 3D printed products in Other.
www.shapeways.com
This is what we have on our '22 Rails. I've used a small self adhesive Velcro 20mm square on the frame just above the pivot to hold the flap in position.Like this..
Check out 2020-2021 Trek Rail Rear Guard by DeltoroIndustries on Shapeways and discover more 3D printed products in Other.www.shapeways.com
While you're waiting …Does anyone on here print these?
Depris goes down off the wheel not upThis solution does not stop debris coing from underneath.
Still finds it way inDepris goes down off the wheel not up
Also you will never stop everything unless you leave the bike at home.
Message me you address Dave as I have a spare one. I'll be in Weston Super-Mare over the weekend if you want to pop upWhere do you get yours from Jamie? Did you mate print one? Would he be able to print me one?
Hello - I've had to remove the 3D Print file, after someone started to sell prints based on my design from Trek Rail Pivot Guard, even he accepted the Non Commercial License - please reach out, if you are interested. It's tested on 20 and 21 Carbon frame. 22+ Carbon frame is out for testingWhere do you get yours from Jamie? Did you mate print one? Would he be able to print me one?
Interested if you're going to produce some of these. Any idea of the possible cost including P. & P. I'm in the UKHello - I've had to remove the 3D Print file, after someone started to sell prints based on my design from Trek Rail Pivot Guard, even he accepted the Non Commercial License - please reach out, if you are interested. It's tested on 20 and 21 Carbon frame. 22+ Carbon frame is out for testing
You need a hardtail.Still finds it way in
