Can you share the source of this information?I won't be rushing to do mine after reading elsewhere that his battery capacity dropped right down to 639wh after full charge
I am not sure if I want to have this upgrade honestly. Nothing is clear. If it is a battery update I doubt also the motor firmware will be touched. Maybe it will be influenced though.Took my 2020 Gen2 to LBS today and they upgraded both 700W and 500W batteries (for free!). The tech said even though it's "only a battery firmware", it does update something on the motor side, per his update tool he ran on his laptop. The firmware revision on the motor did not increment after the update, so I suspect probably some internal configuration on the motor side was adjusted). So, bring your bike to LBS, not just your batteries!
Whole thing.Did they need the whole bike or just the battery
It doesn’tWhere does it display that in MC?
Interesting. The old firmware "seems" to be calculating Wh correctly. 94% of 700Wh is 658Wh.I did the update today and I lost 50 watt. I don’t know why.
View attachment 102050 View attachment 102051
I’ve had the update and thought my range was better than normal after a ride in 4.c temperatures yesterday.But people have been loosing range. I'll see if I can find it, think it was on the turbo levo and kenevo forum.
Now the display shows 280 miles to empty after I fill the tank. The tank size didn't change. I didn't lose any range.
Now it‘s out, it’s also a prerequisite to enable the 80% battery charge limit, that can be enabled/disabled in the latest app version
/02/23 – Levo/ Kenevo (Release Notes) – Specialized Content Hub
content.specialized.com
BATTERY FIRMWARE RELEASES
Bike: Levo MY19-22 / Kenevo MY20-21
Battery firmware x.6.6
Release date: 15/11/2022
Features:
Fixes:
- Improved algorithm for battery state of charge calculation
- Support for battery health optimization
- Enables “Charge Limit” feature (released 14/02/2023 in Mission Control 3.11 onwards)
- Improved battery diagnostic capabilities (retailer tools)
- Bug Fix to battery health status shown in app
Seems so now that they released this update...Do you need to have the dealer update the battery firmware first?
You will need to have the battery updated at some point.Do you need to have the dealer update the battery firmware first?
