• Warning!!
    UK Pedelec Law
    Worldwide Laws
Volspeed 4
jonmat
Sheffield
Today I installed a Volspeed V4 on my 2021 Orbea Wild FS. It was a piece of cake to install and I can set the assistance speed anywhere between 15.5 to 27.5 MPH. Very easy to turn on and off. I was surprised you can actually engage it while you are riding. Set mine at 22 MPH, which is fine for my style of riding. I’ll update this post if anything goes wrong. I still have 6 months warranty on the Bosch gen 4 CX and would just remove it if I needed to make a warranty claim. I didn’t have to remove the crank arm and completed the job in around 15 minutes.
I've been wanting to go with Volspeed too but I'd be devastated if my bosch unit bricked. Hope it goes well for you! I'll be following this post
Just for clarity my firmware is updated to the very latest.
With Volspeed 4 being brand new it should still bypass Bosch no problem with no errors. Id hold off further updates from Bosch if pos though, they really don't like tampering from what I've seen
Have on my Gen 4 2022 Cube and no problems so far. Set to 24 mph for now, but seldom enable it. Another thumbs for purchasing was that it corrects the computer from reading mph ~5% slow even if limiter is not bypassed. From factory reading 5% slow, then cuts power some at 18.5 and fully at 20 mph, but never really going 20. Verified with my Garmin GPS it reads very close all the time, tire pressure still affects of course.
The only issue I can detect with the Volspeed 4 active is the range jumps around a bit. One minute it says 40 miles then changes to 80 or 90 which is clearly false. It doesn't seem to make much difference which assistance mode I'm in either. The top speed setting appears to be 27.9 mph not 27.5 which I stated in my original first post. The plastic cover over the bottom of the motor offers no sort of ingression protection and is purely just a bash guard or sump guard depending on what you want to call it. One of my previous bikes, a Cube with a CX 3 motor had way more protection so I'm guessing the CX 4 produces more heat and needs more ventilation.
It think it clashes up the battery % for a second or so every 5 seconds.
The range calculator on the volspeed uses a much shorter time frame than the standard Bosch figure. It's more a guide of your range as you're riding at that moment, or over a couple of minutes. Whilst the Bosch one seems to take data over a far longer time span and average it out.
I have the new Bosh 750 smart system on my Rail , will this work on there ?
Thats one of the really handy things with the Volspeed. The bar meter on the Purion is the only thing that bugs me. Fitting the dongle means I won't ever think about needing to upgrade the display and of course you get the speed increase to boot.
And more accurate display of speed! This was more important to me than increasing top assisted speed much than few mph. With gearing on my 11 speed single chainring would be peddling like hell at 28 mph.
Has anyone tested if Volspeed4 somehow changes ride data, if you import it with ebike connect to strava for example? Speed, distance, rider power etc?
How is the VOLspeed 'sensation' compared to stock Bosch even at lower speeds? I mean, I have the pedal-arm-mod installed, and it feels more natural than stock even at lower speeds. The motor output is much more rider input dependend. Lite touch on the pedals, less motor power, hard touch on the pedals much more motor power. Same principle as stock Bosch configuration, but more pronounced, dynamic or whatever. QUESTION: is that kind of dynamic or 'natural' feeling in Volspeed too, or is Volspeed more like stock Bosch just without the 25 km/h limit?
(Thought I would post the question here instead of making a new thread, as this one seems fairly general about VOLspeed.)
carsten T
carsten T
What is this pedal-arm-mod you are talking about? I feel that the EMTB on the stock Bosch Gen 4 is pretty much telepathy.
Agreed. The feel is exactly the same whether Volspeed is enabled or not. Only the max mph changes. And yes, emtb mode is so good its almost come from the College of Jedi.
Further to the EMTB query, is the progressive nature of Tour+ still maintained once the chip is installed? Ever since having Tour+ installed that is the only mode I ride in due to it being progressive, would hate to lose that just so I can up the speed at which the motor cuts out.......hoping to have best of both worlds! Cheers
Volspeed 4 now at over 1000 miles problem free bosch cx 2020 pre smart system. Really make emtb mode come alive. Set to 22mph. Love it!
Any problems yet thinking about getting one for my gen2 performance line motor I’ve had it wiped after 3 error codes and really don’t fancy going to my lbs again
Still working, not one 504 error since Install. Note I leave the limit at 21.8mph and always have.
No problems here in 1700 miles.
Just installed mine pretty easy just have one question for anyone my motor was small when I opened to fit it and had to put the box at the back inside the under plastic part because and if water would do any damage
