Well expert is pike, sworks 36. I was gonna go lyrik/36. Aim for the best. If I could choose any combination it'd be 36 dpsx. I've heard the x2 is a dark art.
I've got a shockwiz, so I'm gonna try setting the current/standard suspension up better before upgrading... Only because I'm skint![]()
Fox Factory 36 29er 160mm travel, 51mm offset £699 in CRC sale. Don't know what offset is right for the levo.
Fox Suspension 36 Float Factory RC2 Forks BOOST 2018 | Chain Reaction Cycles
Rc2 is the higher end fork, fit4 is cheaper. It has the independent compression settings. But being 2018 it doesn't have the grip2 damper, which is a massive improvement apparently. £400 more though, so you have to decide.Fox Factory 36 29er 160mm travel, 51mm offset £699 in CRC sale. Don't know what offset is right for the levo.
I believe this is the cheaper on that does not have the FIT 4 damper. Might be worth a look though if you're on a budget![]()
Personally i would ride the fork first and see if you need it.
£425Every day is a school day£400 is a big saving on the grip 2 damper...how much is it to retro fit one anyway? Plus 160mm travel...will that work?
I'd already looked into it to see if it would saved money.It feels and tracks ok to me and I ride pretty aggressive. Haven't noticed flex. It does beat me up a bit though, feels harsh and feel it in my hands. Ride it first and see, then if you change you'll be able to know what's improved and whether it was worth the coin.Personally i would ride the fork first and see if you need it.
After having a Pike and a Fox Factory 34 on my other 29ers I'm sure I'll want something a little more suited for my riding rather than the Sektor RL. Although I'm sure this will be a good fork![]()
yeah i have the new RC2 on my bike, and its smooth as you like
Swapped my standard DPS shock for a DPX2 with custom rebound setting (addopted for my wider shoulders) also very satisfied with this.
What measurement is the correct one for the dpx2? Have this on my SC Hightower and love it there. But I thought Fox didn't sell stock shocks for the Levo? (just oem)
The correct lenght is 210mm with a 52.5 stroke.
Fox offers them in a 50stroke and a 55 stroke, most Fox dealers are happy to convert one to a 52.5 stroke. This is what Fox Germany did and probably almost all suspension centers can do for you.
