Bent/twisted fork
1Squadr0n
Hi All,
Had a bit of a stack recently which fully taco'd my rear wheel, somewhat bent my front and also seems to have affected the forks. The axle used to slide in and out like a dream, bit is now stiff/binding.
You can't see anything visually, but something has moved.
So, I am looking at a Zeb. It's a bit of a minefield, specs wise. I am inclined to buy the "best" one ie Ultimate. But are there any nuances I should be aware of? Updates etc that I should make sure it has (if I am ordering stock rather than new factory shipment).
Thanks!
If it is not the axle or hub, there must be a way to restore proper geometry by the application of controlled force!
What do you have to lose?
