Moe Ped
Just wondering if anyone has bought one and can give feedback on how well it works, we can get the fitting kit here in Aus but not the battery at the moment.
yes . bought with Genius eRide 910 Large.
There is a bike specific fitting part that is supplied by Scott . Its just a plastic plate to sit on top of the down tube, with screw thread holes in various places. These mate with holes (under 2x black stick on covers) in the top of the bikes down tube , and the bosch battery pack mounting brackets on its upper side.
I'm told by the bike shop this has to be the right size for the bike and is bike and frame-size specific. I've also been told that if your frame size is M or S, you cannot remove the REX battery once fitted. On the L, it removes just fine. The mounting kit itself, stays in place permanently. For me, being able to remove the battery was a necessity - need to be able to take batteries out to lift on car etc.
The rest of the kit is all bosch branded parts. there are upper (with integrated lock ) and lower brackets that hold the battery pack in place - these screw to the top of the scott-specific fitting plate. Various torx and allen screws, couple of which were wrong length which I found annoying (but I have many spares, so not an issue overall) . There's a Y cable wiring loom to splice two batteries in parallel into one motor input. It has no active components, its just a Y loom. And finally the battery pack, which is a completely standard bosch power pack 500.
I ordered the bike with the REX fitted, but the bike shop hit delivery issues with the REX parts due to covid so they shipped me the REX several weeks after the bike. I therefore fitted it myself - it wasn't too bad . I spent a lot of time RTFM and dry running it before taking the bike to bits, and waited for bad weather so I wouldn't feel like losing ride time whilst I had it in bits in the garage!
Was a bit nervous about dropping the motor out (never done it before on a bosch), hardest part of that was getting enough torque into a 40mm torx bolts to loosen it. Other fiddly bits getting the cable from the 2nd battery through the rubber cover at the base of the shock, and getting the excess cable of the Y loom tucked up into the base of the seat tube.
, I upgraded the display to Kiox as well, so I get % battery display for both batteries . In riding, it uses using both batteries in parallel, I am not aware of it pulling from one or the other , both batteries stay within one or two % of each other despite being different sizes (500 and 650), so I suspect its keeping them at same voltage level.
Its definitively not a case of using one to flat then using the other. Range extension is what you'd expect - I rode 45km the other day, really hammering it, lots of Emtb fast uphills to winch to the top then dropping down, used about 45% of the two. Had I been on a single pack I'd have been nervous by the end. handling wise I don't find any problem, I am a 6ft 95kg guy, in fact it carves nicely into berms with the low down weight.
I've got the plate had it since I bought the bike the duel battery cable and then the bosch mounting kit and battery. Did you have have your bike reprogrammed for the duel battery? Can you run it with just one? was it easy to git? The plate look a bit odd got a cut out underneath I believe
Thanks for the write up. Sounds easy enough. I've changed my brakes to hope and fitted a speedbox to my bike so had the motor right out. And off the bike. I was originally going do this last year but I've had a injury to my neck so not been about get out on it.
I'm guessing I need these two parts plus a battery:-
Bosch Kit Adapter DualBat, 515/430 mm | eBay
Find many great new & used options and get the best deals for Bosch Kit Adapter DualBat, 515/430 mm at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
Bosch Frame Battery Mount Complete For Dualbetrieb | eBay
Bosch frame battery holder complete for dual operation Please measure beforehand whether this bracket also fits into your e-bike. It is not enough if the holder fits in length (33cm), you also have to consider that the battery has to be inserted at an angle downwards. The base plate has a height...www.ebay.co.uk
the front is an RRP pro bolt onHi Sandyman, what fenders are those?
Nyes . bought with Genius eRide 910 Large.
It’s definitively not a case of using one to flat then using the other. Range extension is what you'd expect - I rode 45km the other day, really hammering it, lots of Emtb fast uphills to winch to the top then dropping down, used about 45% of the two. Had I been on a single pack I'd have been nervous by the end. handling wise I don't find any problem, I am a 6ft 95kg guy, in fact it carves nicely into berms with the low down weight.
