MTB_MIKE
Gutch, any word on how the bike rides with your DHX2?That’s the direction I went.
Mine rides fine with the Marzochi CR shock.
I hadn't considered the effects on anti-squat actually! Do you know if the smaller wheel and longer travel will increase the anti-squat or decrease it? EDIT: Did my own research and it seems it’ll increase AS, but not dramatically. E bikes can tolerate higher AS levels than analog IMO so I should be fine. The worst effect will potentially be bobbing ABOVE sag point when I put power down.Have you thought about the effects a longer shock will have on anti squat? The rise has quite a bit at sag already (115% I have read), dropping the rear axle with a smaller wheel and extending the start of the travel could make the suspension terrible at the early to mid stroke. It would be interesting to see an anti squat graph before making that change.
I saw that IG post. Funny thing is there are 2-3 others on a DHX2 that have not noticed any bushing/shaft issues so he could just have a bad shock. Fox QC is complete shit on their 2021 X2/DHX2 shocks. I ride with 3-4 guys who all have problems and have sent their shocks in for warranty workI hadn't considered the effects on anti-squat actually! Do you know if the smaller wheel and longer travel will increase the anti-squat or decrease it?
I think it would be fine with a little more AS, but I wouldn't want much less.
As for coil shock selection, I got into an Instagram thread with the owner of Biker's Edge in Utah, @utzach, who ran a DHX2 for a bit on his Rise, but it had too much play to feel safe with the clevis setup. The DHX2 shaft is super thin compared to other coil shocks and it seems the shock has very little bushing overlap. The Marzzochi CR and Fox Van are much thicker. Zach eventually went with the Rockshox Super Deluxe and said it has more bushing overlap aka it's more stable-bodied shock.
There's some good info in various Levo threads actually, since it uses a clevis/yoke as well.
I am looking at the anti squat figures for the Occam with a 32T/50T configuration. It is 104% at 25% sag. With the Rise and 160mm of travel, you are at 108-109%. A 34t chainring would help reduce this greatly but it shouldn’t be a big deal. If you look at these figures on other bikes, it’s pretty similar
The only available figures for the Rise are 115% at sag point (assume 30%). Extending the shock to add ~20mm additional travel at the start of the travel is going to bump this up to around 120%. Dropping the rear axle by adding a smaller back wheel is going to effectively raise the main pivot, increasing anti squat further still.
I'm not saying it won't work, i'd love to try it, but you just need to be careful you don't lose the benefits of the light and agile bike with a heavy coil, then also lose the benefits of a coil by making the suspension harsh through anti-squat. A 34 or 36t chainring could possibly be one of the best upgrades for the rear suspension, and the cheapest.
Yeah I’ll check clearance at the end stroke when my Rise arrives. Keeps getting pushed back, April now. Had a chance to snag an alternate color (dark blue) but wanted to hold out for white/green. Kicking myself now that my preferred colorway got delayed...Jimsantos, if you run this full 29er setup. Can you check to see if you can run some offset bushings to get the shock from 216 to 213x63?
www.offsetbushings.com
Might be of use:There's some good info in various Levo threads actually, since it uses a clevis/yoke as well.
I’ll check when I get home. It looks like it’s fine if you run a 55mm stroke shock but is cutting it close for a 60/63mm stroke shock. The bulletin is saying further investigation is needed if you go longer thanDid you validate that the shock is ok following Information on
About 69-70mm which is just below the maximum 72mm allowed by Fox for a 65mm stroke shock. On a 63 stroke, it would be about 75-80mm allowed so it’s more than goodDid you validate that the shock is ok following Information on
I don't see why there is resistance to the Rise being built up as an aggressive trail bike and adding a bit of extra weight to it to handle more aggressive riding styles or suspension preferences.
Orbea themselves have two different types of builds, one with a Fox 34 and a beefier one with a Fox 36.
I currently have a Decoy 29 with 145 rear. That bike can handle anything I throw at it on my local trails. The appeal of the rise isn't becoming a weight weenie and riding it like a cross country bike. It is dropping 10lbs off my current bike, with a similar rise build (bump the fork to 160mm), and still having an aggressive trail bike build that you can push hard and enjoy on trails where you may not need 170+mm of travel. The bonus being that it handles more like your normal trail bike AND has a powerful motor.
There are plenty of riders pushing analog 140mm/150mm trail bikes hard. You'll even see bikes in that category pop into an enduro race now and then.
There seems to be a weird trend with rise riders obsessing over one or two pounds which is not significant enough to matter on an ebike. And let's keep in mind the other options are still +-10lbs heaver than this thing, so there still aren't any other bikes for aggressive riders who want a powerful motor and light bike.
The market segment between a levo sl and a 53lb 170mm ebike still hasn't been cracked open. 150mm rear + 160mm front, full power, around 43lbs is the holy grail IMO. Orbea has gotten fairly close with this one. Might be a few years till we fully get there.
Couldn’t agree more!I don't see why there is resistance to the Rise being built up as an aggressive trail bike and adding a bit of extra weight to it to handle more aggressive riding styles or suspension preferences.
I’m wanting to do this to my arise. What is your opinion of how it rides? Is it the stock length or did you long shock it?
