Sorry I currently have some projects that need completing. Over winter I’m sure to finalise these options. Please bare with me.Hi, any update on the possibility of a tec compatible extender?
Thanks.
Sorry it’s a crazy start to 2020.Bumpity bump
Any updates Mr Trailwatts?![]()
Should get out with the 378wh early next week.Is this to do with the Focus shimano system?
I estimate 18-20 miles in boost depending on temperature, wind and muddy trails ?View attachment 51599
This was a boost mode only ride, bike derestricted and 252wh extender.
Going out with 378wh plus 252wh in backpack this weekend so 1008wh of fun.You managed to get hold of a Focus then ? Will be keeping an eye on this.
252wh is 1.4kg, 19cm tall with 7.6cm diameter.
How does that work for you? I know the travel path of the shock is fairly vertical, but it does move outwards. That looks awfully close to colliding with the TEC pack on full compression. Have you already moved the TEC mounting rail further up the downtube into the Sam2 position? Have you tried the mounting the shock upside down?
Thanks for the info, I will back up a fake and see if it fits.252wh is 1.4kg, 19cm tall with 7.6cm diameter.
I'm interested because I'm hoping to fit a shock with an external reservoir (when DVO can be arsed to actually make and ship it!)
How inconvenient! Have you tried moving the TEC pack rail up the downtube into the Sam2 position? It's only a couple of bolts, takes a few mins. That gives enough room on the Sam2 for the coil shock and it will give enough room for me to install my DVO Topaz shock when it arrives. The power cable still fits OK, tighter curve but perfectly OK. Or maybe mount the shock upside down, does that work any better?Hi Steve, it basically doesn't work at all! my frame is a medium and I can't even sit on the bike (80kg) without it touching. if I want to do a bigger day I just swap out the shock back to standard and use the tec pack.
I would rather have shorter rides as the tec pack makes the bike feel horrible anyway so fingers crossed the trail watts system fits and its light at 1.4kg.
As soon as supplies are secured, I will run 100 units on a pre-order basis with a target date for completion and distribution.
60x 252wh packs and 40x 378wh packs.
