Maxle
DaiGaled
Pencoed
Hi does anyone know the exact size of the front ‘maxle’ and if there are any aftermarket versions that will fit a turbo levo 2018? Thanks
Thanks for the link. Apparently I need the exact thread pitch/length according to wiggle. I’m new to this after years of being ‘out of the game’ and things have changed a lot lol.
Since you have said Maxle I'm assuming you are talking for a RockShox Fork. Aftermarket you can get 15x110mm (Boost) front axles by "Wolf Tooth", "OneUp Components", and "Brand X". There are probably others but these are the ones I know of. RockShox also do a "Maxle Stealth" that is much cheaper than their "Maxle Ultimate"
Thank you so much. I told the guy in wiggle that the 15 x110mm brand x would fit but he said no he needed actual specs. You sir are a lifesaver.
Thank you Mike. I’m armed with enough info to order a new one now. So bloody many out there lol
If you are looking at "Brand X" you will need this one:
RockShox 15x110mm 158mm 11mm M15x1.5
Source: The table on the Wiggle Website for the Brand-X Bolt Thru Axle.
