The 2.6 e-Wilds arrived this weekend and are now on the Stilus, although I’ve only had a short ride so far. I’ll be able to give a better review/comparison later in the week.
Initial thoughts:
Pro’s:
- rubber seems stickier than stock Smart Sams with a much more aggressive trend pattern
- Incredibly quiet given the more aggressive tread pattern. Really impressed in that regard
- Seems to roll well so far
- Easy enough to inflate tubeless without a high pressure hose
Cons:
- Initially hard to physically get the tyre over the edges of the rim to seat. Top Tip for newbies, ensure you squeeze the tyre so it sits in the middle part of the rim where the circumference is at its smallest, then you can get the final part of the tyre bead over the edge of the rim
- Now this one is interesting and totally unexpected. The rolling circumference of the e-wild is noticeably smaller than the Smart Sam stock tyre. With one wheel running the new tyre and one still on the old, the diameter of the wheel/tyre looked around a couple of centimetres smaller on the e-wild! I’ve never seen this mentioned anywhere before in any of the reviews. Net net the wheel circumference is definitely smaller with the e-wild tyre setup.
- Related to the above no doubt. On the Smart Sams the engine was slowing its power delivery after 15.5mph and stopping completely at 17mph. With the e-Wilds the motor stops completely at 16mph.
- Clearly the larger the circumference, the better it rolls hence people’s love of 29’ers so you lose a chunk of this on the e-wilds from my initial view
The reason I brought new tyres is when riding over in Epping Forest where the terrain can be loose, loose over hard pack or muddy I was consistently lacking cornering grip compared to the guys I’m riding with on Magic Mary’s.
I’ll give it a go and see how they ride but maybe as winter comes, will switch the front to a Magic Mary which I believe has the same circumference as the Smart Sam and in effect create a “Baby Mullet” setup (must patent that term ?). This setup of Magic Mary front and e-Wild rear has broken numerous enduro time trial records as reported on this forum earlier so is maybe the way to go.
Once I get back over there I’ll be able to compare the grip of the new e-wilds over the stock Smart Sams...
