Trance e+ power
Silato
128
73
Manchester UK
Hi.
I've had my trance e+ a week now, I'd used it Tuesday and Wednesday and had 66% battery left so removed battery and stored it in room temp room.
Today I've put it on the bike and it works fine on ride to work but when I power down it turns back on by its self. Any ideas?
Battery is now 33% after ride if that matters.
When it powers back on all lights light up then just the usual battery and power mode.
JandeMan
27
32
netherlands
Hi.
I had the same problem with my last Full E 2018 model. So I went to my LBS for check.. It took 2 days before i had time.. in the meantime I removed the battery. But when I got to the LBS..the problem disappeared and all was working fine. And it never game back. I think maybe somewere there is some moisture that makes the problem.
Silato
128
73
Manchester UK
That makes sense, it will turn off if I hold a power mode button after the on/off, but switches back on after a few minutes. System check via app states no issues. Maybe some moisture in one control maybe. I'll get an air dryer on it see if that sorts it.
Thanks for reply.
Lee67
195
205
Yorkshire
Yep normally water ingress in the controller... tho ive had mine 10 weeks and its got wet and not done that...
JandeMan
27
32
netherlands
I had only one time in the beginning a problem with the Full E 2018, but after that, with the same controler....never again (y)
Silato
128
73
Manchester UK
seems like moisture egress is an issue with the controller. but i havent had any issues since it was replaced
To be honest I've still not taken it to have it replaced yet and not had any issues since and I've been out in wetter conditions than before I had the issue?
522K
