Good luck with that . I will be looking forward to see if the volspeed works. If it doesn't work will you get a refund?I am still waiting for the Volspeed 2 to turn up.
Apparently it was sent from Germany and there are delays in delivery.
Thank you for your feedback. I bought a wolf warrior 11 scooter for a blast and it is absolutely awesome!Well
Received Volspeed this morning and guess what.
It didn't work so was advised to put bike back together go for a little ride and re-install the unit.
Did this and it still didn't work.
First thing I am going to do is email volspeed with my software info and what was tried and see what they come back with as I can't see both speedbox and Volspeed being faulty.
I can only suggest it may be the latest software installed. Here is a pic of software installed on my bike. I would suggest to not try installing any chip with this software unless proven by somebody unless you have time to waste.
Hope this helps
This is typical seeing they have your moneyThis is the reply I got from Volspeed....
Hi, we are not aware of that problem. But it seems that the tuning can't read the button press events of your charge display. Most likely the software version of the motor is not the problem here.. Could you please check if there is a purchase number on the back of your display? I have two charge displays here, but both are not capable of setting the "automatic" mode. Most likely this newer version is the reason for that problem. But I'm wondering why nobody reported this problem until now. I would try to get one of those displays as fast as i can and then would try to update the tuning chip software. Unfortunately, I can't make any promises. Best regards Tobias Lindermayr
Hi Dee I have come across some new information for your speedbox.This is typical seeing they have your money
Press walk and then press the up power button straight away let me know how you go cheers Jeff
I have finally resolved the issue.Jeff
Sorry for late reply that did not work and Volspeed finally found out what the problem was. They asked me to send them a picture of my display details and found out that my display is a version 4. For some reason the version 4 is not responding to the button commands through the volspeed or speedbox. They tried to buy a version 4 to re-write the chip but were unfortunately sent a version 5 which is a later version which worked with the original software. The gladly offered me a refund instantly but I refused it as I had already ordered an upgrade to a Evo display from Germany and told them I would inform them what version I was sent so they would check this against there software to make sure there are no issues before they send it out.
To be fair they have actually been super helpful and understanding.
Will update you when I have installed my new display.
