Ride Control lights blinking
vickriz
7
West Coast Canada
2020 Trance
Has anyone else seen this? The lights are blinking. I can still change assist modes but the display no longer accurately displays current mode nor battery level.
20210103_224406000_iOS.MOV
A simple restart fixes it. My LBS has sent it off to Giant Canada to see what they know about it.
Crawford919
113
122
You have somehow definitely activated the ejection seat launch mode. The only way to get the light to go off is to proceed with the ejection sequence. Step one: find a strip on concrete and pedal up to 10 to 15 mph but not higher with the dropper post all the way down. Then simultaneously pull the front brake hard and push the dropper button at same time while leaning forward. Step two: The bike will endo and flip down the pavement violently. Step three: If the lights are still on then repeat until they go out. ?
But in all seriousness it probably has a wet connection. Take off the bottom motor protector and unplug all the connectors, blow the dry gently and apply dielectric greese. Probably will fix it. Or something has damaged the speed sensor magnet or pick up.
521K
