How to use this section. To the thread starter: Once you are satisfied with the answer that youve been given, click the Trophy on the left hand side of the message. This will rate this answer as the 'Best Answer' and will change the question status from 'Unanswerd' to 'Answered'. All members can also upvote an answer with the 'Up' arrow, this will help identify the best answer.
I think the best advice with all the motors is to check and clean all the wiring connections including battery contacts , and use some sort of lube to seal them . Second is check speed sensor and magnet set up is ok .
