Waynemarlow
412
123
Bucks
Ride
Whyte T129 with TSDZ
new higher density 21700 cells now available ( 39 cells v 60 18650 cells )?
from where you get that?
Look up Samsung 21700 50E and Samsung 18650 35E specs , 2 of probably the best batteries out there and then you maybe can work it out. Report back with your findings ?
aviserated
54
8
Oxford GA
Ride
Rail 5
This is aimed at new emtb riders/ buyers. It is not worth upgrading from my 2020 gen 4 to this model with same power output.
So a "TCU" without lights ...
Yet .... it gives to possibility that it will/could have mode/power lights - like a Spesh TCU - which means there might be a handlebar controller due down the line without the unnecessary items like bow thruster control and quick dial.
It seems as if the "+"-button doubles as light switch (image below).
The left/right arrows are for swiping left or right on Tinder.
Philly G
573
153
New Zealand
Ride
Trek Rail 7
I agree that the fact the motor is essentially unchanged makes upgrading less attractive to existing gen 4 owners. I'm not sure if I would bother with customizing the modes either, for myself I find EMTB perfect right out of the box. I would however love to be able to update the firmware myself, and I think this is something Bosch could have made available for the existing Kiox with a simple software update.
Hamina
366
203
FIN
Ride
Trek Rail 5 2020
What if it was mandatory to change all electronics in the drive unit to make the over-the-air updating possible?
I don't know what problems I would currently solve on my Bosch CX 4 by updating the firmware. There has been no real changes in the last two-three updates.
BBear
83
78
Bristol
Ride
Focus Jam2
As I’ve just bought a new Trek Rail my first reaction when Rob posted this up was ‘bloody hell’. Now having thought it through and seen what it all means and what the reaction has been I’m not at all bothered.
Bigger battery is too heavy - I’m happy with 625, esp compared to the 378 I had on my old Focus Jam2. If I get a new bike in the future I want it to be lighter not heavier.
Controller - looks like something out of Star Trek. No thanks.
Kiox display - looks like the old one. I quite like the Kiox on my Rail as I like having all the info tho I appreciate not for everyone.
App - this is useful for tweaking, but tbo I’m quite happy with emtb mode and I don’t feel a desperate need to change anything.
knut7
568
233
Norway
It's difficult to say how much heavier the 750Wh battery really is. Unless I'm mistaken, the frame lock mechanism is integrated in the battery. Or possibly just parts of the mechanism. That means fewer parts in the frame and reduced weight. But the Powertube 750 will of course be at least 500 grams heavier due to more cells.
RustyMTB
810
233
Ride
Zesty 527am
The 750 is 900g more than the 625. The 625 is 3.3kg, so the 750 comes in about 4.2kg give or take.
Same as Bbear. While the Purion is a wart. Otoh when I ride, I'm focused on where I'm going, what the bike is doing beneath me & all the rest of it. Also never felt the need to customise the modes, EMTB is decent off the shelf & mixing tour & EMTB, my 25kg push iron with a 625 is good for 50 miles, more than enough for a big day out. Nice things are nice to have but for me this solves a problem I don't really have.
sunstoner
166
98
Nottinghamshire
I've never been bothered by the purion display tbh but I wouldve loved the ability to customise the power modes. Seems theres a few things that can be tampered with and not just how much power each mode has.
  • Agree
Reactions: Philly G
Tubby G
1,055
303
North Yorkshire
Ride
Haibike AllMtn 4
There’s a new Yamaha motor too, the PW-X3 with upgraded controller
Jimbo Vills
620
223
Kent
Ride
Tbc
The 750 battery is 4.4KG
That's some weight gain on the battery. Although looking online 'claimed weight' for the 2021 Cube 160 HPC Action Team Spec bike
625wh - 24.1kg
750wh - 24.3kg
So that gain has been offset a fair bit. Mainly down to the fixed battery but guessing elsewhere too.
How that weight is placed and handles time will tell, but that extra battery and 200g of weight will surely see a range improvement on what is already a very efficient system from what i've seen.
443
Ride
Kenevo 1.3 / Jam 6.9
And for reference, the Spesh 500wh weighs 3135g.
So in terms of comparison :
Bosch 500wh - 2.9kg's , Spesh 500wh 3.135kg's
Spesh 700wh : 3.840kg.
Bosch 625wh : 3.5kg's
Bosch 750wh : 4.4 kg's.
The Spesh 500wh uses 18650 cells. The 700wh uses 21700 cells. If the 700wh used the same cells as the 500wh then proportionally, it would be about 4.4kg's. Likewise, if Spesh made a 21700 cell 500wh battery, it should be about 2.75kg's instead of the 18650's 3135g - but they don't.
  • Helpful
Reactions: Frank_Denmark
Tubby G
1,055
303
North Yorkshire
Ride
Haibike AllMtn 4
This controller seems far more discreet
Philly G
573
153
New Zealand
Ride
Trek Rail 7
I was meaning version updates, and the new modes like Emtb Lite, Tour+...it would be great to be able to experiment with these without having to take the bike into the shop, as well as being able to change wheel size, crank length etc yourself
  • Agree
Reactions: PetrD and Hamina
knut7
568
233
Norway
Yeah, I didn't intend to ask about the weight of the 750 :) The point was the weight isn't comparable. To my understanding, components for the lock mechanism has been moved from the frame to the battery. This makes the frame lighter and the battery heavier. So the net weight increase should be way less than 900g.
  • Agree
Reactions: Jimbo Vills
Jimbo Vills
620
223
Kent
Ride
Tbc
Yeah, I didn't intend to ask about the weight of the 750 :) The point was the weight isn't comparable. To my understanding, components for the lock mechanism has been moved from the frame to the battery. This makes the frame lighter and the frame heavier. So the net weight increase should be way less than 900g.
200g looking at the Cube as an example ?
sunstoner
166
98
Nottinghamshire
It’d be great if Kawasaki, Honda & Suzuki started making e-motors too and the Japanese manufacturers made some emtb’s. Partnered with Shimano components. Maybe in 5-10 years they will, time will tell
I suppose if motorbikes are going to be all electrified up at somepoint then possibly Honda, Kawasaki et al might reach a little further into emtbs as theyd already have a similar(ish) tech on their mainstream bikes right!?
  • Like
Reactions: Philly G
Hamina
366
203
FIN
Ride
Trek Rail 5 2020
It could be be possible that by fully redesigning the whole system it's now possible to introduce new controllers in the future.
Tubby G
1,055
303
North Yorkshire
Ride
Haibike AllMtn 4
No idea, I just thought a Kawasaki Ninja ZX-EMTB would be cool as f*** ?
Rusty
E*POWAH BOSS
Jul 17, 2019
1,371
423
New Zealand
Ride
2019 Levo Comp
One look at that controller and I already know that I will not have a Bosch powered bike for my next one.
That is the crappy controller on the G4 KIOX and it is forking less than useless when compared to other current offerings.
Don't mind the KIOX display too much, but that controller is SHITE.
443
Ride
You don't like it then ??
Lets be glad Who ever does "Controls" at Bosch Bikes, doesn't make gear systems. Imagine the Bosch 12 Speed - you'd just have 12 levers hanging off the bars to select the gear you want. Except they wouldn't move very nicely and they'd all have a flush smooth finish so you'd have no idea which lever you had your finger on. They might combine it with an enormous Gear Display screen, which just shows a horizontal bar rather than the gear number.
  • Haha
Reactions: Rusty and Doomanic
