Loose battery?
Noobster
23
36
Yorkshire
Just got my vitus e sentier a few days ago and took it for its first little off-road experience today. Small jumps and bumps. But the battery sounds wobbly and after some jumps and drops the bike would litterlaly just shut off like I had removed the battery.
I've seen alot of people with this problem but no one seems to say specifically which bolts I need to tighten or.loosen?
I really don't want to take it to LBS if it's a 2 min Jon with Allen keys.
If someone could explain to me what to do I would be more than grateful.
Thanks all and happy riding
Gary
Old Tartan Bollocks
10,496
10,690
the internet
  • Remove the battery using the key
  • next remove the upper battery mount plastic casing screws and remove the casing
  • underneath you will see the top mounting bracket/mechanism and the screws which hold it in position.
  • losen those screws just enough until you can move the mount up or down.
  • position the bracket until it holds the battery in place with no play.
  • This will take a little trial and error and you'll also need to place the plastic cover back on to check positioning (but you don't need to replace it's retaining screws until you're happy it's in the correct position)
  • when you're happy with the position torque the mounting screws properly and replace the plastic cover, screw that down too and replace your now securely fitting battery.
DrStupid
1,464
2,128
Pleasureville Ky
Thanks for the nice write up. My wife's (hehe) BMC Speedfox battery doesn't seem to pull in far enough, and is creaky. Its tight up down, that's for sure, but not flush... anybody else seen this?
