Husky430
After falling off a piece on 'north shore' a couple of days back, I now seem to have some shifting problems with my electronic derailer.
Works fine in the higher gears 6-11, but when changing down to the lower ones it starts clicking as though it wants to change to the next gear and if you go all the way down to 1st the chain jumps off the sprocket and jams in between the back of the sprocket and the spokes. Will also, when in 4th and change to 5th not change at all and then with another change, jump to 6th. You can then shift back the other way to get 5th, all a bit inconvenient and time consuming.
A mate has exactly the same bike e160 900E and I'm planning on taking it around to his place just to see the angle the hanger is sitting on. Might just need a gentle 'tweak' left or right.
Thought I'd throw it out there to see if anyone else had problems in this department before, cheers Steve
