Capacity test?
Russell
211
149
Iow
Is there anyway to test the capacity of the Bosch battery? I've more or less done 2000 miles now and I think it may be running out slightly earlier than when new.
Wiltshire Warrior
563
228
Poole
bike shop can provide a print out for you
MattyB
1,266
1,279
Herts, UK
The only way to get an accurate capacity is to do a full charge and discharge cycle against a known, representative load (I.e. a 1/2C discharge over 2hrs). I doubt most (or even any) LBS have the kit needed to do that given the onboard BMS almost certainly prevents discharging against dummy loads off the bike like heater elements or lamps.
522K
