Bent crank arm! Need replacement ASAP. What are my options?
The Flying Dutchman
340
555
Wellington NZ
Got a little carried away yesterday and now have a bent crank arm #NoRegrets
It's not clear to me what replacement arms are compatible with my Giant Trance so I'm asking all you internet experts.
Was looking at these: Aeffect e-Bike Crank Arm
Will they fit????
20,481
My bike came with 175, after 2 months i moved for 165. Here it makes a big improvement.
It should be noted that red is presently looking for even shorter cranks to try.
There are quite a few threads on here about people putting shorter cranks on their emtb's. There's also lots of theoretical views on why it would be worse .. I put 150's on my Shimano and its' great. Seems faster uphill and downhill ..
33red
137
Quebec, Canada
excuse the personal question but how tall are you? Did you notice a drop in power output?
I am 61 YO. now 5 11 with 34.5 inseems. I noticed 1 thing, less strikes wich is safer. The side effect is more flow. We adapt maybe i use different gears but who cares. I still have a good position sitting or not. Usualy shorter is better to climb, less dead spot, but i was OK so no improvement. Less power is a myth. The transmission does the job, it happens naturally. I understand 175 for road, not mountain. If mountain was first 175 would not be an option, it was imported.
522K
