Levo SL Gen 1 220mm front disc on SL 2020 expert carbon?
Mossbo
Sweden
Hi, bike is in the mountains so I would need some help please.
Have a Turbo Levo with 220mm disc in front, and will now use the studded tire set from that one on my Levo SL Expert Carbon.
What adapter do I need to fit the disc on my Expert Levo SL 2020?, it has a Fox 34mm fork, original type.
Fork:
FOX Performance 34 FLOAT 29, GRIP damper, 51mm offset, 3-position adjustment, 15x110mm, tapered alloy steerer, 150mm of travel.
Front Brake:
SRAM G2 RSC, 4-piston caliper, hydraulic disc, 200mm
Shjay
835
488
Kent
I wouldn’t run a 220 rotor on a 34 fork too big could cause damage to fork
522K
