2019 Turbo Levo Upgrade TTX22M
AdrianWindo
45
25
Fitted this new shock today
AdrianWindo
45
25
High speed: Medium
Low speed: 2 / 3 clocks from fully clockwise
Rebound: 2 clicks from fully clockwise
Raknor
21
54
North East
Nice! Been thinking about dropping a coil on my 2020 expert. Is it worth the upgrade? How much better is it?
Could someone post the shock specs. Or a link to buy? ?
AdrianWindo
45
25
the small bump sensitivity is much better, almost a sense of the shock not being there. The bike feels more planted and gives great confidence.
To buy talk to TFTuned in Westbury Wiltshire. Ohlins - Shocks - TF Tuned
Ohlins have a version of the shock specifically for the Levo (210 x 52.5) so it’s a simple direct replacement.
TTX 22 M Stumpjumper, Levo (2019) SBC 1979
Available in in metric lengths and strokes as well as Trunnion mount, the TTX22M Custom aftermarket shock absorber is designed to handle the most challenging World Cup Downhill tracks while still providing pedal efficiency for the flat and uphill sections. The twin tube design allows the gas pressure to always backup the low-pressure side of the piston to keep pressure at a controlled level. This ensures consistent damping performance on all types of terrain and improves damping response to give outstanding control of the bike and tire movements.
Low and high speed compression and rebound damping are externally adjustable. Spherical bearings is offered as an option on widths up to 22 mm, reducing friction on the shock during side loads to improve small bump sensitivity. All shocks feature the stability mode. 3rd position on high speed adjuster increase compression damping to reduce suspension movements during less technical climbs.
Technical Specifications:
  • Twin-Tube-Technology (TTX)
  • Weight between 425 and 460 g (without spring)
  • Length 210 mm
  • Stroke 52,5 mm
  • Wheel size 27,5 (also 29 for Levo)
  • Aluminium design, hard anodized
  • Fully servicable and rebuildable
  • 2 years limited warranty
Adjustment:
  • 3 clicks high speed compression damping
  • 16 clicks low speed compression damping
  • 7 clicks rebound damping
Purchased parts package:
  • 1 shock absorber TTX22M
  • Model related parts for mounting
  • Owners manual
Spring is not included and needs to be ordered seperately.
Shock part no. SBC 1979 (SBC TTX22M SJ 27.5 MY19 AM)
