• Warning!!
    UK Pedelec Law
    Worldwide Laws
2019 Turbo Levo geared mechanical speed increase
BigFoot
91
46
Bethesda, Maryland USA
Is there 2 companies selling the plastic planetary Gear that will increase speed? (I believe it slow the rear magnet down) I only can find one, but thought I saw another brand a month ago?
If there are 2 which one works better?
jd_3d
279
341
California
Hi @BigFoot, I created the LSS (I'm not a company or anything just a member on this forum) and have a ton more info here including how to buy it:
I created a purely mechanical Turbo Levo speed limit increase - EMTB Forums
I'm not aware of anyone else that has yet copied my design and is selling it, but if you do find someone who has copied it I would be interested in hearing about it. So for now there is only 1 (and I hope it stays that way) :). Let me know if you have any questions.
BigFoot
91
46
3 questions
Will this work with 2019 turbo Levo expert original wheel set ?
And will I work with a wheel set that I built that uses DT Swiss 240s center lock Boost hub and Shimano rotors?
Where do I order the magnet and mechanical unit?
jd_3d
279
341
California
3 questions
Hi @BigFoot, yes the LSS DT will work with the Levo Expert and you can order it here:
LSS DT - Planetary Gear Set by JD_3D on Shapeways
The LSS and LSS DT are designed for the stock brake rotor so the clip mechanism doesn't work on other rotors, however a few people are running aftermarket rotors and have used screws to affix the gear housing (ring gear) to the rotor such as this:
The magnet you can buy at Amazon, for instance I got these:
Install instructions here:
LSS Installation Instructions
Cheers,
JD
522K
