Bike Finder · Transition
Transition Repeater PT
Transition
Repeater PT 2024
DiscontinuedFull Power · GravityLegacy · 1.6/10iFreshness 1.6/10
Carbon 170/170mm enduro eMTB with SRAM Eagle Powertrain (Brose 90Nm, 720Wh)
Motor
SRAM Eagle Powertrain · 90Nm · 680W
Battery
SRAM Eagle Powertrain 720 · 720Wh
Travel F/R
170/170mm
Wheels
29F / 29R or MX
Frame
Full carbon
Weight
23.95 kg
Price
From £10,499
View the Transition Repeater PT on Transition’s site
Set up this bike →
Transition Repeater PT 2024
From £10,499
EMTB Forums verdict
The Transition Repeater PT 2024 is the American brand's carbon enduro eMTB, built around the SRAM Eagle Powertrain (Brose-derived) motor and an integrated 720 Wh battery. It runs 170 mm of travel front and rear on a Horst Link rear end, with a claimed 24 kg system weight. Headline numbers: 90 Nm of torque, 680 W peak power, a properly slack 63.5 degree head angle, a long 455 mm chainstay and reach growing from 425 to 510 mm across eight sizes. £10,499 for the base trim. Production status: discontinued. Community verdict: a properly designed gravity-focused chassis with class-leading geometry, hamstrung by SRAM Eagle Powertrain motor quirks and the subsequent discontinuation of the PT (Powertrain) variant.
Drive system and range. The SRAM Eagle Powertrain is a Brose-derived motor with 90 Nm of torque and 680 W of peak power. It integrates SRAM AXS Transmission with auto-shift and coast-shift functionality, which was a genuinely innovative concept at launch but proved to have community-flagged quirks. The motor weighs 2.98 kg. The 720 Wh battery is integrated and non-removable, which the community has consistently flagged as a major ownership compromise compared to removable PowerTube and Shimano BT-E8036 alternatives. Real-world enduro range on 720 Wh is solid: mixed-terrain use typically reaches 55 to 85 km depending on assist mode and rider weight.
Geometry and handling. A 63.5 degree head angle is properly slack, matching the Mondraker Zendit and Marin Alpine Trail E. Transition's 8-size geometry table provides sizing flexibility with sub-sizes (SM, MD, LG) bridging the standard S/M/L/XL options. Reach grows from 425 mm to 510 mm. The 455 mm chainstay is on the longer side of modern enduro frames, identical across sizes. Wheelbases run 1209 to 1328 mm. The Repeater supports both 29 full and 27.5 rear mullet configurations, with the bike often shipping mullet from the factory. The seat tube is short relative to other enduro bikes, supporting a 170 mm AXS Reverb dropper that complements the bike's playful character.
Build and value. One trim at £10,499. The build includes the SRAM Eagle Powertrain motor with AXS Transmission, full SRAM drivetrain integration and Transition's signature suspension and component package. The standout strength is the chassis at 24 kg: a 170 mm full-power enduro carbon platform at this weight is properly competitive. The questionable note is the SRAM Eagle Powertrain motor's reliability profile and the non-removable 720 Wh battery on a flagship-priced bike.
Community-verified strengths. Owners praise the Repeater chassis as among the best riding enduro eMTBs of its generation. The Horst Link rear end and 170 mm travel deliver exceptional plushness. Owners report the bike feels playful for a long-travel enduro thanks to the mullet wheel option and short seat tube. The integrated SRAM AXS Transmission with auto-shift was praised by some owners (particularly in winter, where heavy gloves complicate trigger shifting), although it divided opinion across the broader community. Rear shock setup details have been well-documented by owners: 80 kg rider plus bike weight calculations point to 350 to 450 lb coils for Marzocchi Bomber CR on 160 mm rear stroke at 28 to 33 per cent sag.
Caveats and known gripes. The SRAM Eagle Powertrain motor has a documented dead spot issue: when stopping and restarting pedalling on descents or technical sections, there is no assist initially before it catches. This persists across motor replacements. The motor cuts out at high cadence in boost mode on technical climbs, requiring riders to back off cadence to maintain assist. Rear brake hose replacement requires removing the motor and battery (the brake line runs through the front triangle above the drive unit and along the top of the battery), making it a particularly involved service job. The integrated non-removable battery is the most consistent ownership flag. And SRAM have discontinued the Eagle Powertrain motor, with the Repeater PT name being wound down: Transition have replaced the PT variant with the Regulator SX lightweight Bosch SX-equipped sibling.
Verdict. The Repeater PT 2024 suits the enduro rider who wanted the SRAM Eagle Powertrain's integrated AXS auto-shift system and Transition's slack-angle gravity-focused chassis, particularly at end-of-line dealer pricing. Riders chasing motor reliability, removable batteries or current production status should look at the Transition Regulator SX, the Marin Alpine Trail E or the Mondraker Zendit. Production status: discontinued.
Geometry read
Size
Wheels
Descending
97
Slack 63.5° head angle, 170mm travel and a long 1273mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
55
Size balance
96
Rear-long with a planted front in L (FC:RC 1.80) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
82
SRAM Eagle Powertrain and a steep 77.5° seat angle keep the weight planted over the front — a proper winch. 680W of peak power and 90Nm of torque — a strong full-power motor.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
How it stacks up vs other Full Power · Gravity bikes (from 136 bikes in the database)
Weight23.95 kgabout average weight
Battery720 Whabout average capacity
Motor torque90 Nm11 Nm below average
Value for moneyPoor value5/100 · from £10,499 vs ~£6,804 for comparable bikes — priced above peers; older tech; heavier
💬 Forum discussion
Transition Repeater Owners Thread
22 replies · 8.8k views · last reply 10 months ago
Join the discussion →
“The bike is so good that nobody has anything to write about ;) I'am loving mine. I'ts a real beast of a bike.”
— Lantz · ♥ 4 · most-liked post
Bike geometry diagram
SMLXL
Toptube561 mm584 mm612 mm641 mm
Reach425 mm455 mm480 mm510 mm
Stack624 mm635 mm645 mm655 mm
Seattube390 mm420 mm450 mm480 mm
Chainstay455 mm455 mm455 mm455 mm
Headtube Angle63.5°63.5°63.5°63.5°
Seattube Angle (eff)78.4°78°77.5°77.1°
Wheelbase1209 mm1243 mm1273 mm1308 mm
Headtube105 mm115 mm125 mm135 mm
BB Height340 mm345 mm345 mm345 mm
Front Centre754 mm788 mm818 mm853 mm
FC:RC1.661.731.801.87
Trims · 2
GX AXS
£10,499
XO AXS
£11,999
MotorSRAM Eagle Powertrain · 90 Nm · all trims
BatterySRAM Eagle Powertrain 720 · 720 Wh · all trims
Travel F/R170/170 mm · all trims
FrameCarbon · all trims
ForkRockShox ZEB Select 170mmRockShox ZEB Ultimate 170mm
ShockRockShox Vivid Select+ 205x65mmRockShox Vivid Ultimate 205x65mm
HeadsetFSA No.55R/44, ZS56 upper / ZS66 lower · all trims
StemANVL Swage, 40mmANVL Swage, 40mm, 35mm clamp
HandlebarANVL Mandrel Alloy, 800mmOneUp Carbon, 800mm, 35mm clamp
GripsODI Elite Flow Lock-On · all trims
SaddleSDG Bel-Air V3 · all trims
SeatpostRockShox Reverb AXS dropper, electronic wireless (150mm SM / 170mm MD-XL) · all trims
BrakesSRAM Code Bronze Stealth, 220mm rotorsSRAM Code Silver Stealth, 220mm rotors
Rear derailleurSRAM GX Eagle Transmission, 12-speed, AXS electronic wirelessSRAM X0 Eagle Transmission, 12-speed, AXS electronic wireless
CrankSRAM GX Eagle Transmission Alloy E-MTB DUB, 160mmSRAM X0 Eagle Transmission Alloy E-MTB DUB, 160mm
ShiftersSRAM Eagle POD Controller, 12-speed, AXS electronic wirelessSRAM Eagle POD Ultimate Controller, 12-speed, AXS electronic wireless
CassetteSRAM XS-1275 Eagle Transmission, 12-speed, 10-52TSRAM XS-1295 Eagle Transmission, 12-speed, 10-52T
ChainSRAM GX Eagle Transmission, 12-speedSRAM X0 Eagle Transmission, 12-speed
DrivetrainSRAM GX AXS Eagle Transmission, XX T-Type 34T chainringSRAM XO AXS Eagle Transmission, XX T-Type 34T chainring
WheelsDT Swiss H 1900 Spline rims, DT Swiss Hybrid 370 hubsCrankbrothers Synthesis E-Bike Alloy, Industry Nine 1/1 hubs
TyresSchwalbe Magic Mary 2.4 front / Big Betty 2.4 rear · all trims
Weight24.01 kg23.95 kg
Price£10,499£11,999
Rides similarly
Spot a mistake?
