Bike Finder · Thömus
Thömus Lightrider E_MAX
Thömus
Lightrider E_MAX 2026
CurrentCross-CountryCurrent · 7.2/10iFreshness 7.2/10
Swiss ultralight maxon BIKEDRIVE AIR S eMTB
Motor
Maxon AIR DRIVE S
Battery
400Wh
Travel F/R
140/130mm
Wheels
29"
Frame
Full carbon
Weight
Price
£5,331
View the Thömus Lightrider E_MAX on Thömus’s site
Thömus Lightrider E_MAX 2026
From £5,331
EMTB Forums verdict
The Thömus Lightrider E_MAX 2026 is one of the most distinctive ultralight eMTBs on the market: a Swiss hand-built carbon trail/downcountry bike at 17.5kg claimed and the headline descriptor "closest to an unpowered ride". Headline numbers: 140mm fork, 130mm rear, Maxon AIR DRIVE S motor (Swiss motor specialist Maxon's emerging eMTB drive unit), an unspecified 400Wh battery, 65.4 degree head angle and 454mm reach in the lone size M. Priced at EUR 12,450. The Lightrider sits at the extreme premium end of the SL category: even the slightly heavier Lightrider e-ultimate is reportedly under 15kg, per forum chatter. This is genuine boutique territory.
Drive system and range. The Maxon AIR DRIVE S is a Swiss-engineered ultralight mid-drive from Maxon, a precision motor specialist with deep heritage in industrial and scientific applications (Mars rover wheels, surgical robots). Published specs on the Maxon eMTB drive units suggest 60 to 90Nm peak torque depending on tune, with motor masses in the 1.4 to 1.9kg range: lighter than TQ HPR50 in the lightest variants. The 400Wh battery on the Lightrider E_MAX is conservative; range on a 130mm trail bike sits at one and a half to two hours of mixed riding in mid-modes. Battery removability is not specified in gold; confirm with Thömus dealer.
Geometry and handling. 65.4 degrees up front is on the steep side of modern trail eMTB norms: XC/downcountry leaning rather than slack and aggressive. Reach is 454mm, chainstay 437mm and wheelbase 1207mm in the only listed size M. Single-size production reflects Thömus's hand-built approach: each frame is built to order and the brand prefers focused execution to a wide size matrix.
Build and value. One trim at EUR 12,450. At this price point, build kit will run flagship-grade: Fox Factory or Öhlins suspension, SRAM XX AXS Transmission, top-tier Maven or Code Ultimate brakes and carbon wheelsets. Standout: 17.5kg system weight on a downcountry trail platform with full-power-class motor technology is rare. Questionable: EUR 12,450 buys a Specialized Levo Pro carbon or a fully-loaded YT Decoy Carbon Pro at half the system weight cost; the Lightrider's value is in the Swiss hand-built provenance and the lightest-possible-eMTB obsession.
Caveats and known gripes.
  • One size only (M, 454mm reach). Riders under 1.70m or over 1.85m should seek custom-build dialogue with Thömus or look elsewhere.
  • 400Wh battery limits range. Big-day epics require disciplined mode use or a range extender path that is not specified in the gold spec.
  • Maxon AIR DRIVE S maturity. Maxon is a credible engineering brand but the AIR DRIVE S is a newer entrant in the eMTB motor market versus TQ, Bosch and Specialized: long-term reliability data and service network are less established.
  • Limited dealer network. Thömus is well-known in Switzerland but has very limited distribution outside the German-speaking Alpine region.
  • Premium price. EUR 12,450 is among the most expensive eMTBs of its travel class on sale; rivals at this price offer carbon wheels, AXS and 600Wh-plus batteries from established brands.
  • No curated forum signal. The E_MAX has minimal owner reporting on the eMTB Forums community at the point of writing; performance characterisation is dependent on press testing and Thömus-supplied data.
  • Downcountry travel only. 140/130mm is XC-trail bracket; not suited to enduro or aggressive descending.
Verdict. The Lightrider E_MAX is one of the most distinctive boutique eMTBs on sale: a Swiss hand-built carbon platform with a Maxon AIR DRIVE S motor and 17.5kg claimed weight, positioned as "closest to an unpowered ride". It suits riders who want the lightest possible eMTB at any price, who fit the single M frame size, and who value Swiss hand-built provenance over mainstream brand support. Buyers chasing wider sizing, 600Wh-plus battery, mature motor ecosystems or value-for-money should look at the Scott Lumen, Specialized Levo SL, BMC Fourstroke AMP LT or Trek Fuel EXe. Production status: current.
Geometry read
Descending
57
A solid all-round descender (65.4° head angle, 130mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
81
Short 437mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
96
Rear-long with a planted front in M (FC:RC 1.76) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
84
the motor and a steep 73.6° seat angle keep the weight planted over the front — a proper winch.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
Watch out forNo major red flags in the M geometry.
Bike geometry diagram
M
Toptube594 mm
Reach454 mm
Stack619 mm
Seattube458 mm
Chainstay437 mm
Headtube Angle65.4°
Seattube Angle (eff)73.6°
BB Drop31 mm
Wheelbase1207 mm
Headtube110 mm
Front Centre770 mm
FC:RC1.76
Trims · 2
Lightrider E_MAX
£5,331
Trail Light
€12,450
MotorMaxon AIR DRIVE S · all trims
Battery400 Wh · all trims
Travel F/R140/130 mm · all trims
FrameCarbon · all trims
ForkMarzocchi Bomber Z2 140mmFox 36SL Factory 140mm GripX
ShockMarzocchi Bomber 185/55mmFox Float X Factory 130mm
StemStem -8° 45mmRaceface Turbine SL, +/- 6mm, 50mm
HandlebarAlu handlebar 780mm/15mmRaceface Era 780/20
SaddleSelle Italia X3 BoostSelle Italia SLR Boost Carbon
SeatpostFixed seatpost 400mm
BrakesShimano Deore, 2-piston, 180/180mmShimano XTR BR-M9220, 4-piston, 180/180mm
DrivetrainShimano SLX, 34, 10/51, 12-SpeedSRAM XX SL T-Type, 34, 10/52 12-Speed
WheelsDT Swiss M1900 30mmDT Swiss EXC 1200 30mm
TyresVittoria Barzo 29x2.25Schwalbe Wicked Will, 29x2.40, BRZ Skin
Price£5,331€12,450
Rides similarly
Spot a mistake?
