Levo 2018
Gen 1 (2016-2018) - original FSR Levo on 27.5+ wheels
The Specialized Turbo Levo 2018 is the original first-generation FSR Levo: an aluminium 4-bar trail eMTB with 140 mm of travel front and rear, the Specialized Turbo 1.3 motor (Brose-built), and 27.5+ wheels. This is the bike that defined the modern full-power eMTB category when launched in 2016, and the 2018 model year was the final Gen 1 iteration before the Gen 2 redesign. Production status is gold-listed as discontinued — the Levo is now in its fourth generation (Gen 4 launched 2025), and the 2018 model is firmly a used-market purchase.
Drive system and range. The Specialized Turbo 1.3 was the first-generation Brose-derived motor with around 90 Nm of torque in its later firmware. It was distinctive for its quiet operation — one of the smoothest and most natural-feeling motors of its era — and for its silent freehub. Battery capacities on Gen 1 Levos ranged from 460 Wh to 504 Wh depending on trim and year. The motor's main weakness was a known firmware-update issue causing power dropouts under sustained high loads. Specialized's Mission Control app and Mastermind TCU dashboard arrived in later years; the Gen 1 Levo used a simpler TCU display.
Geometry and handling. A 66.5 degree head angle is firmly steep by 2026 standards — trail geometry rather than enduro. Reach progresses modestly: 415 mm (S), 435 mm (M), 455 mm (L), 480 mm (XL). The 455 mm chainstay is held constant across sizes and is long for a 140 mm trail bike — prioritising climbing traction and stability. The 27.5+ wheel format (typically 2.6"–3.0" tyres) gives the bike a distinctive cushioned, grippy feel but adds rolling resistance and weight versus modern 29er mullet configurations. The geometry is firmly of its era — modern 64.5-degree, longer-reach Gen 4 Levos are markedly different bikes.
Build and value. No current trim is gold-listed (production-discontinued). Historical 2018 Levo trims spanned Comp Alloy at around £4,500, Expert Carbon at £6,000 and S-Works Carbon at £9,000+ depending on market. On the used market in 2026, a 2018 Levo in good condition typically sells for £1,500–£2,500, depending on motor condition (a critical buyer-check item), battery health and overall condition.
Community-verified strengths. The Gen 1 Levo built a strong forum following — @BikeBert (a Gen 3 owner) explicitly references "my current pimped-out Levo with its freshly rebuilt motor" as worth keeping over the Gen 4 — signalling that long-term Levo owners value the platform's parts ecosystem and refinement potential. Specialized's UK dealer network is one of the most extensive in cycling.
Caveats and known gripes. Motor reliability is the headline concern for any used Gen 1 Levo purchase. Specialized 1.3 motors have a known failure profile and rebuilds are essentially mandatory for any high-mileage used purchase. Battery capacity degradation after 6+ years is a real factor — a 504 Wh original capacity at 80% health is around 400 Wh effective. The 66.5 degree head angle and 27.5+ wheels are firmly of their era and will feel dated against any modern trail-geometry alternative. @Idlefrog notes the Levo Gen 4 has stepped up to 666 W motor and 840 Wh battery — the technology curve has moved meaningfully since 2018. Original FSR linkage parts and Specialized-proprietary components can be expensive to source for older platforms.
Verdict. The Specialized Turbo Levo 2018 was the bike that defined the modern full-power eMTB segment, and remains a competent trail platform on the used market for buyers who understand the technology compromises of its era. It will suit budget-constrained buyers who want into eMTB ownership for under £2,500 and are comfortable with the motor-refurbishment and battery-health checks required on any 2018 used purchase. Anyone wanting current motor power, modern geometry, fresh battery capacity or full manufacturer warranty should look at the current Levo Gen 4, the Levo SL Gen 2, or the value-leading Canyon Grand Canyon:ON 2026 / Cube Stereo Hybrid One77 SLX alternatives. Production status: discontinued.
| S | M | L | XL | |
| Reach | 415 mm | 435 mm | 455 mm | 480 mm |
| Stack | 606 mm | 606 mm | 634 mm | 647 mm |
| Chainstay | 455 mm | 455 mm | 455 mm | 455 mm |
| Headtube Angle | 66.5° | 66.5° | 66.5° | 66.5° |
| Seattube Angle (eff) | 75° | 75° | 75° | 75° |
| BB Drop | 27 mm | 27 mm | 27 mm | 27 mm |
Trims · 5
Base £4,000 | Comp £4,999 | Comp Carbon £5,999 | Expert £7,250 | S-Works £9,999 | |
| Motor | Specialized Turbo 1.3 · all trims | ||||
| Travel F/R | 140/140 mm · all trims | ||||
| Frame | Aluminium · all trims | ||||
| Fork | RockShox Reba RL 29, 51mm offset, 150mm of travel | RockShox Revelation RC 6Fattie/29, 51mm offset, 34mm stanchions, 150mm of travel | RockShox Revelation RC 6Fattie/29, 51mm offset, 34mm stanchions, 150mm of travel | Öhlins RXF 36, 6Fattie/29, Single-Tube design, air spring w/ adjustable 3rd chamber, adjustable low speed compression, adjustable rebound, 15x110mm thru-axle, 51mm offset, 150mm of travel | Öhlins RXF 36, 29/6Fattie, Twin-Tube design, air spring w/ adjustable 3rd chamber, adjustable high and low speed compression, adjustable rebound, 15x110mm thru-axle, 51mm offset, 150mm of travel |
| Shock | RockShox Monarch RT, Rx Trail Tune, AUTOSAG, rebound and 2-position compression adjust, 197x48mm | RockShox Monarch RT, Rx Trail Tune, AUTOSAG, rebound and 2-position compression adjust, 197x48mm | RockShox Monarch RT, Rx Trail Tune, AUTOSAG, rebound and 2-position compression adjust, 197x48mm | RockShox Monarch RT3, Rx Trail Tune, AUTOSAG, rebound and 3-position compression adjust, 197x48mm | RockShox Monarch RT3, Rx Trail Tune, AUTOSAG, rebound and 3-position compression adjust, 197x48mm |
| Headset | 1 1/8" Campagnolo Standard compatible upper bearing, 1.5" lower bearing, 45x45° | 1 1/8" Campagnolo Standard compatible upper bearing, 1.5" lower bearing, 45x45 deg | 1 1/8" Campagnolo Standard compatible upper bearing, 1.5" lower bearing, 45x45 deg | 1 1/8" Campagnolo Standard compatible upper bearing, 1.5" lower bearing, 45x45 deg | 1 1/8" Campagnolo Standard compatible upper bearing, 1.5" lower bearing, 45x45 deg |
| Stem | Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise | Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise | Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise | Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise | Syntace F109, 6-degree rise, 31.8mm clamp |
| Handlebar | Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm width | Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm width | Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm width | Specialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp | Specialized Trail, FACT carbon, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm, 31.8mm |
| Grips | Specialized Sip Grip, half-waffle, regular/XL thickness by size | Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, L/XL: XL thickness | Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, L/XL: XL thickness | Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, L/XL: XL thickness | Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, L/XL: XL thickness |
| Saddle | Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm | Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm | Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm | Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm | Body Geometry Henge Expert, hollow Ti rails, 143mm |
| Seatpost | Specialized 2-bolt head, forged alloy, 8mm offset, micro-adjust, 30.9mm | Command Post IRcc, 12-position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, S: 100mm / M/L/XL: 125mm travel | Command Post IRcc, 12-position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, S: 100mm / M/L/XL: 125mm travel | Command Post IRcc, 12-position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, S: 100mm / M/L/XL: 125mm travel | Command Post IRcc, 12-position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, S: 100mm / M/L/XL: 125mm travel |
| Brakes | SRAM Level T | SRAM Guide RE | SRAM Guide RE | SRAM Code R | SRAM Code RSC |
| Rear derailleur | SRAM NX, 11-speed | SRAM GX, long cage, 11-speed | SRAM GX, long cage, 11-speed | SRAM X01, 11-speed | SRAM XX1, 11-speed |
| Crank | Custom alloy crankarms, Forged steel 32T chainring · all trims | ||||
| Shifters | SRAM GXe, one-click lever | SRAM GXe, one-click lever | SRAM GXe, one-click lever | SRAM X1, trigger, 11-speed | SRAM XX1, 11-speed |
| Cassette | SRAM PG-1130, 11-speed, 11-42t | SRAM PG-1130, 11-speed, 11-42t | SRAM PG-1130, 11-speed, 11-42t | SRAM XG-1175, 11-speed, 10-42t | SRAM XG1199, XD, 11-speed, 10-42t |
| Chain | KMC X11ES, 11-speed with missing link | KMC X11ET, 11-speed w/ Missing Link | KMC X11ET, 11-speed w/ Missing Link | KMC X11ET, 11-speed w/ Missing Link | SRAM XX1, 11-speed w/ PowerLink |
| Drivetrain | SRAM one-by 11-speed | SRAM one-by 11-speed (GX) | SRAM GX one-by 11-speed | SRAM X01 one-by 11-speed | SRAM XX1 one-by 11-speed |
| Wheels | Roval Traverse 27.5, hookless alloy, 38mm inner width, 24 front / 28 rear spoke count, tubeless ready, hand-built | Roval Traverse 27.5, hookless alloy, 38mm inner width, 24 front / 28 rear spoke count, tubeless ready, hand-built | Roval Traverse 27.5, hookless alloy, 38mm inner width, 24/28h, tubeless ready | Roval Traverse Carbon 27.5, hookless carbon, 38mm inner width, 24 front / 28 rear spoke count, tubeless ready, hand-built | Roval Traverse SL 27.5 hookless carbon rims, Roval Traverse front / Traverse SL DT Swiss Star Ratchet rear hubs, DT Swiss Revolution spokes |
| Tyres | Butcher, GRID casing, GRIPTON compound, 2Bliss Ready, 27.5 x 2.8" (front and rear) · all trims | ||||
| Price | £4,000 | £4,999 | £5,999 | £7,250 | £9,999 |
Rides similarly
Spot a mistake?
