Bike Finder · Specialized
Specialized Levo R
Specialized
Levo R 2026
CurrenttrailCurrent · 7.6/10iFreshness 7.6/10
Lightweight e-downcountry/trail with 600/840Wh modular battery
Travel F/R
140/130mm
Wheels
29F/29R
Frame
Full carbon
Weight
21.16 kg
Price
From £5,499
View the Specialized Levo R on Specialized’s site
Specialized Levo R 2026
From £5,499
EMTB Forums verdict
The Specialized Levo R 2026 is the sport-trail platform in Specialized's revamped Levo line for 2026, a full 29er carbon trail-eMTB powered by the new Specialized 3.1 motor with 105 to 111 Nm of torque and 810 to 850 W of peak power. Headline numbers: 140 mm of fork travel, 130 mm at the rear, a 64.8 to 65 degree size-tuned head angle, the broadest 6-size matrix in the Specialized eMTB line (S1 through S6 from 400 mm to 525 mm reach) and a sub-£5500 entry price on the Comp Alloy. The community framing is mixed but practical: @erider1 highlights the Levo R as offering more aggressive XC-leaning geometry and 29er wheels compared to the longer-travel Levo 4 Carbon Comp.
Drive system and range. The Specialized 3.1 motor delivers 105 Nm of torque and an 810 W manufacturer-claimed peak on the Comp and Expert trims, stepping up to 111 Nm and 850 W on the S-Works (post-OTA tune). The motor weighs 3.15 kg, which is heavier than the Bosch CX Gen 5 (2.8 kg) or Avinox M2 (2.52 kg) but is offset by Specialized's exceptionally clean integration. Battery capacity is not specified in the gold facts but the platform inherits the proven Specialized integrated-battery design. @BrunoSln documents an S-Works owner seeking 600 Wh battery compatibility, suggesting that the stock battery is smaller than the 800 Wh class.
Geometry and handling. A 64.8 to 65 degree size-tuned head angle is moderate trail (slacker than typical 66 degree trail rivals), with the smaller S1 size getting the 64.8 figure. Reach progression is exceptional: S1 at 400 mm, S2 at 420 mm, S3 at 450 mm, S4 at 475 mm, S5 at 500 mm and S6 at 525 mm. This is one of the few platforms with a 125 mm reach span: genuinely small (sub-160 cm) and very tall (over 195 cm) riders are both accommodated. The 447 mm chainstay is held constant across all six sizes. Wheelbases run 1160 to 1309 mm, again with the widest span in the eMTB market.
Build and value. Four trims with proper price discipline. Comp Alloy at £5499. Comp at £6799. Expert at £8499. S-Works at £12499. @Zimmerframe documents a major US pricing reset: Levo R S-Works MSRP reduced from $15650 to $11500, in line with Specialized's "operational improvements" pricing strategy for 2026 to recover competitiveness against Amflow and Avinox-powered rivals. The S-Works gets the higher 111 Nm / 850 W tune via post-OTA software, the lower trims sit at 105 Nm / 810 W. Value pick is the Comp at £6799: full carbon frame, Specialized 3.1 motor and modern geometry.
Community-verified strengths. Three things owners praise. Specialized's clean integration and motor refinement: the 3.1 motor is the smoothest in the lineup and the cleanest visual integration in mainstream eMTBs. Long-term reliability is generally strong: @rydeezie documents Specialized Rider Care offering a fresh 2-year warranty on replacement motors. And the 6-size matrix from 400 mm S1 to 525 mm S6 is industry-leading for size accommodation.
Caveats and known gripes. Three honest flags. @Ndanger documents the wider community concern around Specialized's positioning of the higher-spec bikes as "elite status trophy" rather than functional product. @salko notes the broader Levo 4 family was felt to be "kinda outdated design compared to previous gen and especially to all the competition out there" before the price reset, and gating S-Works's extra power behind a software paywall was unpopular. And @WestCoastRider flags a workshop friction point: routing the rear brake hose through the down tube requires dropping the motor on prior Levo generations, which may carry forward.
Verdict. The Specialized Levo R 2026 is for the trail-bike rider who wants a sport-focused 140/130 mm eMTB with the Specialized 3.1 motor's 105 to 111 Nm of torque, the deepest dealer network in the market and one of the widest size matrixes (S1 to S6). If you want longer travel, more battery range or the absolute lightest weight, look at the Levo (full-power) or Levo SL families. Production status is current.
💬 Forum discussion
Specialized Levo R: We Rode It. Here's What You Need to Know
196 replies · 14.6k views · last reply 2 months ago
Join the discussion →
“To me, that S-Works in the Gloss Silver Speckle Over Carbon color looks like a park bench covered in bird droppings.”
— NervousFan · ♥ 28 · most-liked post
OWNERS’ REPORT
Specialized Levo 4 (2025+) — what owners actually know
7,850 posts · 570 owners · data through Jun 2026
4Battery-nest disconnects and dowel rattle (THE Gen 4 cluster) - fixed by the spring-loaded cradle · typical onset: First months; rough-terrain dependent
3New-bike rattle chasing beyond the nest (SWAT, display, cables, bolts) · typical onset: First weeks
0No frame-issue cluster in 14 months
'The best Turbo Levo ever made, and I say this having owned all the previous models' - bought as a 25%-off demo
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
S1S2S3S4S5S6
Reach400 mm420 mm450 mm475 mm500 mm525 mm
Stack602 mm607 mm616 mm630 mm644 mm657 mm
Chainstay447 mm447 mm447 mm447 mm447 mm447 mm
Headtube Angle64.8°65°65°65°65°65°
Seattube Angle (eff)77°77°77°77°77°77°
Wheelbase1160 mm1181 mm1215 mm1246 mm1277 mm1309 mm
Headtube95 mm100 mm110 mm125 mm140 mm155 mm
BB Height339 mm339 mm339 mm339 mm339 mm339 mm
Front Centre713 mm734 mm768 mm799 mm830 mm862 mm
Trims · 4
Comp Alloy
£5,499
Comp
£6,799
Expert
£8,499
S-Works
£12,499
MotorSpecialized 3.1 · 105 Nm · all trims
Travel F/R140/130 mm · all trims
FrameCarbon · all trims
ForkFOX 36 SL Performance, GRIP Damper, 140mm travel, 44mm offset, 15x110mmFOX 36 SL Performance, GRIP Damper, 140mm travel, 44mm offset, 15x110mmFOX 36 SL Performance Elite, GRIP X Damper, HSC, LSC, LSR adjust, 140mm travel, 44mm offset, 15x110mmFOX 36 SL Factory, GRIP X Damper, HSC, LSC, LSR adjust, 140mm travel, 44mm offset, 15x110mm
ShockFOX FLOAT Performance GENIE, Ride Dynamics Developed, 2-position compression adjust, 190x45mmFOX FLOAT Performance GENIE, Ride Dynamics Developed, 2-position compression adjust, 190x45mmFOX FLOAT Performance Elite GENIE, Ride Dynamics Developed, 2-position compression adjust, 190x45mmFOX FLOAT Factory GENIE, Ride Dynamics Developed, 2-position compression adjust, 190x45mm
StemAlloy Trail Stem, 35mm bar boreAlloy Trail Stem, 35mm bar boreAlloy Trail Stem, 35mm bar bore
HandlebarSpecialized Alloy, 30mm/40mm rise, 35mm, 800mm wideSpecialized Alloy, 30mm/40mm rise, 35mm, 800mm wideSpecialized Alloy, 30mm/40mm rise, 35mm, 800mm wideRoval Control SL RISE Integrated cockpit, 50mm integrated stem, 8-degree backsweep, 2 degree upsweep, 780mm wide
GripsSpecialized Trail Grips · all trims
SaddleBody Geometry Power Comp, steel railsBody Geometry Power Comp, steel railsBody Geometry Power Comp, steel railsSpecialized Power Mirror Pro, 143mm/155mm
SeatpostX-Fusion Manic, 34.9, S1-S2: 125mm, S3: 150mm, S4: 170mm, S5-S6: 190mm Travel, 0mm offsetX-Fusion Manic, 34.9, S1-S2: 125mm, S3: 150mm, S4: 170mm, S5-S6: 190mm Travel, 0mm offsetX-Fusion Manic, 34.9, S1-S2: 125mm, S3: 150mm, S4: 170mm, S5-S6: 190mm Travel, 0mm offsetRockShox Reverb AXS, 34.9mm, S2: 125mm, S3: 150mm, S4-6: 200mm
BrakesSRAM Motive BronzeSRAM Motive BronzeSRAM Motive BronzeSRAM Motive Ultimate
Rear derailleurSRAM Eagle 90 T-TypeSRAM S1000 Eagle AXSSRAM GX Eagle AXS TransmissionSRAM XX SL Eagle AXS
CrankSRAM Eagle 70, BROSE/ISIS, 160mm, 32TSRAM Eagle 70, BROSE/ISIS, 160mm, 32TSRAM GX Eagle, BROSE/ISIS, 160mm, 32TSRAM XX Carbon crank, 160mm, ISIS interface
ShiftersSRAM Eagle 90T, single click, with MMXSRAM AXS POD ControllerSRAM AXS POD ControllerSRAM AXS POD Ultimate Controller
CassetteSRAM GX Transmission, XS 1275, 10-52tSRAM GX Transmission, XS 1275, 10-52tSRAM GX Transmission, XS 1275, 10-52tSRAM XX Transmission, XS 1297, 10-52t
ChainSRAM 70 Transmission 12-Speed Flattop ChainSRAM GX Eagle Transmission 12-Speed Flattop ChainSRAM GX Eagle Transmission 12-Speed Flattop ChainSRAM XX, T-Type
DrivetrainSRAM Eagle 90 T-Type; SRAM Eagle 70, BROSE/ISIS, 160mm, 32T; SRAM Eagle 90T, single click, with MMX; SRAM GX Transmission, XS 1275, 10-52t; SRAM 70 Transmission 12-Speed Flattop ChainSRAM S1000 Eagle AXS; SRAM Eagle 70, BROSE/ISIS, 160mm, 32T; SRAM AXS POD Controller; SRAM GX Transmission, XS 1275, 10-52t; SRAM GX Eagle Transmission 12-Speed Flattop ChainSRAM GX Eagle AXS Transmission; SRAM GX Eagle, BROSE/ISIS, 160mm, 32T; SRAM AXS POD Controller; SRAM GX Transmission, XS 1275, 10-52t; SRAM GX Eagle Transmission 12-Speed Flattop ChainSRAM XX Transmission AXS
WheelsSpecialized Alloy Wheels — Specialized hookless alloy rims, 30mm inner width, tubeless ready, 6-bolt, 15x110mm front / 12x148mm rear, 32H, DT Swiss Elemental spokesRims: Specialized, hookless alloy, 30mm inner width, tubeless ready. Front hub: sealed cartridge bearings, 6-bolt, 15x110mm thru-axle, 32h. Rear hub: Specialized Alloy Rear Hub Disc, sealed cartridge bearings, 6-bolt, 12x148mm thru-axle, 32H, XD steel FHB. Spokes: DT Swiss ElementalRoval Traverse SL II, hookless carbon, 30mm inner width, tubeless ready, 29", Industry 9 1/1 Hub, Sapim D-Light SpokesRoval Traverse SL II, hookless carbon, 30mm inner width, tubeless ready, 29", Industry 9 Hydra 2 Hub, DT Swiss Revolite Spokes
TyresFront: Specialized Purgatory, GRID Casing, T9 Compound, 29x2.4; Rear: Specialized Purgatory, GRID Trail Casing, T7 Compound, 29x2.4 (S1 27.5x2.4)Front: Specialized Purgatory, GRID Casing, T9 Compound, 29x2.4; Rear: Specialized Purgatory, GRID Trail Casing, T7 Compound, 29x2.4 (S1 27.5x2.4)Front: Specialized Purgatory, GRID Casing, T9 Compound, 29x2.4; Rear: Specialized Purgatory, GRID Trail Casing, T7 Compound, 29x2.4 (S1 27.5x2.4)Front: Specialized Purgatory, GRID Casing, T9 Compound, 29x2.4; Rear: Specialized Purgatory, GRID Trail Casing, T9 Compound, 29x2.4
Weight22.34 kg21.5 kg21.16 kg
Price£5,499£6,799£8,499£12,499
Rides similarly
Spot a mistake?
