Bike Finder · Specialized
Specialized Levo 4 Carbon
Specialized
Levo 4 Carbon 2025
CurrentFull Power · TrailCurrent · 7.6/10iFreshness 7.6/10
Full-power 160/150mm mullet trail eMTB with Specialized 3.1 motor (101Nm/666W std; 111Nm/720W S-Works), 840Wh battery, Fox Genie shock, 12-point adjustable geometry
Motor
Specialized 3.1 · 105Nm · 810W
Battery
Specialized M50-840 · 840Wh
Travel F/R
160/150mm
Wheels
MX (29F / 27.5R)
Frame
Full carbon
Weight
23.68 kg
Price
From £6,799
View the Specialized Levo 4 Carbon on Specialized’s site
Specialized Levo 4 Carbon 2025
From £6,799
EMTB Forums verdict
The Specialized Turbo Levo (Gen 4) 2025 is the brand's flagship full-power eMTB, built around the new Specialized 3.1 motor, the 840 Wh M50 battery and an industry-leading 12-position adjustable geometry programme. Headline numbers: 105 Nm of torque (101 Nm/666 W standard; 111 Nm/720 W S-Works post-OTA), 810 W manufacturer-claimed peak, 160 mm front / 150 mm rear travel, mullet wheels, a 63.5 to 65.5 degree head angle range, 24.42 kg claimed and a £6,799 base. The community read on the Gen 4 is polarising — strong on motor power and integration, but with vocal critics among Gen 3 owners.
Drive system and range. The Specialized 3.1 motor is the brand's first major drivetrain upgrade since the Gen 3 launch, delivering 105 Nm of torque and an 810 W manufacturer-claimed peak (figures climb to 111 Nm/720 W on S-Works trim post-OTA firmware update). The 840 Wh M50 battery is removable via side-load cradle and is the segment's largest, comfortably outpacing the Bosch 800 Wh PowerTube. Idlefrog notes the headline comparison: "Levo 4 has 666W motor vs Bosch Gen 4 600W (10% more powerful), 840Wh battery vs Bosch 750Wh (12% larger)". The Dynamic MicroTune electronic mode gives genuinely granular power-mode adjustment. Jeff McD measures a stock 2024 Comp Gen 4 size S at "54.2 lb" (24.6 kg).
Geometry and handling. The Levo 4 runs five sizes (S2 through S6) with reach progressing from 435 mm to 535 mm. The headline geometry feature is the 12-setting adjustable system: offset headset cups for head angle (63.5° / 64.5° / 65.5°), shock-mount flip chip for BB height (-6 mm in low), and Horst-link flip chip for chainstay length (435 mm short / 444 mm long). The fact that BB height and chainstay are now decoupled (unlike Gen 3) is genuinely meaningful and adds real tuning depth. The mullet (29F/27.5R) wheel layout is fixed, and the Horst Link suspension provides 150 mm rear travel.
Build and value. Five trims are on file: Comp Carbon (base £6,799), Expert, Pro, S-Works and S-Works LTD. Zimmerframe notes "Levo R S-Works MSRP reduced from $15,650 to $11,500" in US/Canada — meaningful dealer pricing flexibility. Ou812 details the suspension link options: "Evo link costs $70 vs Cascade link at $370, uses 230x62.5 shock", with "Levo 4 Evo link 13% progression vs Cascade link 30% progression" — direct kinematics intel for buyers chasing progressive curves.
Community-verified strengths. First, motor power: Idlefrog rates the Specialized 3.1 as 10% more powerful than Bosch Gen 4. Second, battery capacity: 840 Wh is class-leading among full-power rivals. Third, 12-position geometry programme. Fourth, SWAT downtube storage with magnetic pouch is genuinely useful.
Caveats and known gripes. First, vocal Gen 3 critics: forum sentiment on the Gen 4 launch has been mixed, with some owners feeling the upgrade is iterative rather than transformative. Second, the linkage progressiveness is conservative at 13% in stock form — the Evo or Cascade link upgrade is essentially required if you want a properly progressive ramp. Third, pricing positions the Levo 4 firmly at the premium end of the segment.
Verdict. The Specialized Turbo Levo (Gen 4) 2025 suits buyers who want the most refined full-power eMTB platform in the segment, with class-leading 840 Wh battery, the new 3.1 motor (105 to 111 Nm peak), industry-leading 12-position adjustable geometry, SWAT storage and SBC mode tuning depth. Less suitable for value-led buyers (£6,799 base is firmly premium), Bosch ecosystem loyalists, or riders who prefer simple non-adjustable geometry. Production status: current.
Geometry read
Size
Descending
64
A solid all-round descender (64.5° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
57
Size balance
82
Balanced front-to-rear in S4 (FC:RC 1.86) — weight sits evenly between the wheels. Custom dropouts adjust the chainstay 435–444mm (scored here at the 440mm mid-point): run it long for a planted, balanced 1.84 FC:RC, or short for a livelier 1.88 and quicker handling.
Technical climbing
66
Climbs well — a 77° seat keeps the front planted. 810W of peak power and 105Nm of torque — among the most powerful e-bike motors made.
Watch out forNo major red flags in the S4 geometry.
How it stacks up vs other Full Power · Trail bikes (from 223 bikes in the database)
Weight23.68 kgabout average weight
Battery840 Wh133 Wh above average
Motor torque105 Nmabout average torque
Value for money38/100from £6,799 · comparable bikes ~£6,299
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
💬 Forum discussion
Specialized Gen 4 Levo - Official Thread
2.4k replies · 393.1k views · last reply 3 weeks ago
Join the discussion →
“As a Gen 3 owner, I refuse to drink the Specialized Kool-Aid. There's nothing “Super” about the Gen 4. It’s overhyped, overweight and late to the party. Pretty disappointing, to be honest. I’ll keep my current pimped-out Levo with its…”
— BikeBert · ♥ 21 · most-liked post
OWNERS’ REPORT
Specialized Levo 4 (2025+) — what owners actually know
7,850 posts · 570 owners · data through Jun 2026
4Battery-nest disconnects and dowel rattle (THE Gen 4 cluster) - fixed by the spring-loaded cradle · typical onset: First months; rough-terrain dependent
3New-bike rattle chasing beyond the nest (SWAT, display, cables, bolts) · typical onset: First weeks
0No frame-issue cluster in 14 months
'The best Turbo Levo ever made, and I say this having owned all the previous models' - bought as a 25%-off demo
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Frame
FACT 11m carbon front + rear triangle, SWAT downtube storage, sealed cartridge-bearing Horst-link pivots, side-load battery cradle, internal cable routing
Bike geometry diagram
S2S3S4S5S6
Toptube578 mm599 mm627 mm655 mm689 mm
Reach435 mm455 mm480 mm505 mm535 mm
Stack618 mm626 mm638 mm652 mm667 mm
Seattube390 mm405 mm425 mm445 mm465 mm
Chainstay435 mm435 mm435 mm435 mm435 mm
Headtube Angle64.5°64.5°64.5°64.5°64.5°
Seattube Angle (eff)77°77°77°77°77°
BB Drop29 mm29 mm29 mm29 mm29 mm
Wheelbase1200 mm1223 mm1254 mm1286 mm1323 mm
Headtube95 mm103 mm117 mm132 mm149 mm
BB Height350 mm350 mm350 mm350 mm350 mm
Standover753 mm754 mm753 mm758 mm761 mm
Front Centre765 mm788 mm819 mm851 mm888 mm
FC:RC1.761.811.881.962.04
Trims · 5
Comp Carbon
£6,799
Expert
£8,499
Pro
£10,299
S-Works
£12,499
S-Works LTD
£16,999
MotorSpecialized 3.1 · 105 Nm · all trims
BatterySpecialized M50-840 · 840 Wh · all trims
Travel F/R160/150 mm · all trims
FrameCarbon · all trims
ForkFox Float 36 Rhythm 160mm, GRIP damper, 44mm offset, 15x110mmFox Float 38 Performance Elite 160mm, GRIP X2 damper, 44mm offsetFox Float 38 Factory 160mm, GRIP X2, HS/LS, 44mm offsetFox Float 38 Factory 160mm, GRIP X2, 44mm offsetFox Podium Factory inverted 160mm
ShockFox Float X Performance with Specialized Genie Shock Tech, 210x55mmFox Float X Performance Elite with Specialized Genie, 210x55mmFox Float X Factory with Specialized Genie, 210x55mmFox Float X Factory with Specialized Genie, 210x55mmFox Float X Factory with Specialized Genie, 210x55mm
HeadsetSpecialized offset headset (adjustable cups)Specialized offset headset (adjustable cups)Specialized offset headset (adjustable cups)Specialized offset headsetSpecialized offset headset
StemAlloy Trail stem 40mmSpecialized Trail alloy 40mmIndustry Nine A35 40mmIndustry Nine A35Industry Nine A35
HandlebarSpecialized 6000-series alloy 800mmSpecialized alloy 800mmRace Face Era carbon 800mmRace Face Era carbon riser 800mmRace Face Era carbon 800mm
GripsSpecialized Trail Grip · all trims
SaddleSpecialized Bridge CompSpecialized Bridge CompSpecialized Bridge Mimic ExpertSpecialized Bridge Mimic ExpertSpecialized Power Pro Mirror w/ hollow titanium rails
SeatpostX-Fusion Manic dropper 34.9mmPNW Loam dropper 34.9mmBike Yoke Revive Max 3.0 dropperFox Transfer Neo Factory wireless electronic dropperFox Transfer Neo Factory wireless
BrakesSRAM Maven Bronze 4-pistonSRAM Maven Silver 4-pistonSRAM Maven Silver 4-pistonSRAM Maven Ultimate 4-piston + SRAM HS2 220mm/200mm rotorsTrickstuff Maxima 4-piston + 223mm rotors front and rear
Rear derailleurSRAM S1000 Eagle TransmissionSRAM GX Eagle TransmissionSRAM X0 Eagle TransmissionSRAM XX Eagle TransmissionSRAM XX Eagle Transmission
CrankSRAM S1000 155mm 34TSRAM GX Eagle Transmission 32TSRAM X0 alloy 155mmSRAM XX Eagle Transmission 160mm 34TCane Creek eeWings Electric titanium
ShiftersSRAM AXS POD ControllerSRAM AXS POD ControllerSRAM AXS POD ControllerSRAM AXS POD Ultimate ControllerSRAM AXS POD Ultimate Controller
CassetteSRAM XS-1270 Transmission 10-52TSRAM GX Eagle Transmission 10-52TSRAM XS-1295 X0 Eagle 10-52TSRAM XX Eagle Transmission XS-1299 10-52TSRAM XX Eagle Transmission XS-1299 10-52T
ChainSRAM GX Eagle Transmission FlattopSRAM GX Eagle Transmission FlattopSRAM X0 Eagle Transmission FlattopSRAM XX Eagle Transmission FlattopSRAM XX Eagle Transmission Flattop
DrivetrainSRAM S1000 Eagle Transmission AXS 1x12SRAM GX Eagle Transmission AXS 1x12SRAM X0 Eagle Transmission AXS 1x12SRAM XX Eagle Transmission AXS 1x12SRAM XX Eagle Transmission AXS 1x12 + Cane Creek eeWings cranks
WheelsSpecialized 30mm alloy mulletSpecialized 30mm alloy mulletRoval Traverse HD carbon mulletRoval Traverse HD carbon mulletRoval Traverse HD carbon w/ I9 Hydra 2 hubs, mullet
TyresSpecialized Butcher GRID GRAVITY T9 29x2.3 / 27.5x2.3 · all trims
Weight24.42 kg24.41 kg23.94 kg23.68 kg24 kg
Price£6,799£8,499£10,299£12,499£16,999
Rides similarly
Spot a mistake?
