Bike Finder · Specialized
Specialized Levo 4 Alloy
Specialized
Levo 4 Alloy 2025
CurrentFull Power eMTBCurrent · 8.6/10iFreshness 8.6/10
Full-power 160/150mm mullet trail eMTB with Specialized 3.1 motor (101Nm/666W std; 111Nm/720W S-Works), 840Wh battery, Fox Genie shock, 12-point adjustable geometry
Motor
Specialized 2.2 · 90Nm · 565W
Battery
Specialized M3-700 · 700Wh
Travel F/R
160/150mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
26.05 kg
Price
£5,999
View the Specialized Levo 4 Alloy on Specialized’s site
Specialized Levo 4 Alloy 2025
From £5,999
EMTB Forums verdict
The Specialized Turbo Levo 4 Alloy 2025 is the aluminium version of the all-new Gen 4 Levo platform, built around the Specialized 3.1 motor (105 Nm torque, 250 W rated, 810 W manufacturer-claimed peak, 3.15 kg motor weight) and an 840 Wh removable Specialized M50-840 battery. Travel is 160 mm front and 150 mm rear on an FSR 4-bar chassis with mixed wheels (29F/27.5R). Two trims — Base at £5,199 and Comp Alloy at £5,999 (26.05 kg). Six sizes from S1 to S6, reach 407-535 mm, head angle 64.5 degrees (adjustable ±1 degree via offset headset cups), 435 mm chainstays in short position (adjustable to 444 mm long). The community read in one line: a thoroughly refined Gen 4 Levo platform with the best in-house Specialized motor yet, the largest battery and best frame storage in the category, brought to a competitive aluminium price point.
Drive system and range. The Specialized 3.1 motor is built by Brose to Specialized's spec — 105 Nm torque, 810 W peak, 3.15 kg. @Idlefrog documents the comparison: 666 W vs Bosch Gen 4's 600 W (10% more), 840 Wh vs Bosch's 750 Wh (12% larger). Real-world range is genuinely strong — @Mikerb's 75-year-old rider on a similar Levo Comp Gen 3 finished a 25-mile ride with 1,800 ft elevation with 50% battery remaining. @Jeff McD notes the 2024 Levo Comp Gen 4 S frame weighs 54.2 lbs stock; with a 600 Wh battery and lightweight wheelset, under 48 lbs at 155 lb rider.
Geometry and handling. The most adjustable geometry in the category. Three independent adjustments give 12 combined settings: (1) offset headset cups for head angle 63.5° / 64.5° / 65.5°; (2) shock-mount flip chip for BB height -6mm; (3) Horst-link flip chip for chainstay 435mm short / 444mm long. Unlike Gen 3, BB and chainstay are decoupled. Reach progresses through six S-sizes: 407 mm (S1), 435 mm (S2), 455 mm (S3), 480 mm (S4), 505 mm (S5), and a properly long 535 mm (S6). Wheelbase 1200-1323 mm. @WatermanJim on his first ride on the green expert (Gen 4 carbon equivalent): "Much faster and smoother while also being more lively and maneuverable and thank god it's quiet."
Build and value. Two well-priced alloy trims. Base at £5,199 lands you a Marzocchi Bomber Z1 160mm fork, Marzocchi Bomber Inline rear shock, SRAM DB8 Stealth 4-piston brakes, and Specialized 30mm alloy mullet wheels. Comp Alloy at £5,999 (26.05 kg) upgrades to Fox Float 36 Rhythm with GRIP damper, Fox Float X Performance with Specialized Genie tuning, and SRAM Maven Bronze 4-piston brakes. Both ship with SWAT downtube storage (magnetic pouch), MasterMind T-series colour display, Turbo Connect Remote, and the side-load removable 840 Wh battery. £5,199 for a Gen 4 Levo platform with 840 Wh battery and SWAT storage is the value play of the entire 2025 full-power lineup.
Community-verified strengths.
  • @Desert_Turtle: "This new chassis is way better than the other 3 generations. Not only is it stiffer and stronger, it's incredibly adjustable." The 12-position geometry adjustment is genuinely useful.
  • @Power1tobe 25+ years of MTB experience: detailed long-term review confirms the Gen 4 Levo delivers across mixed terrain.
  • The combination of 840 Wh battery, SWAT storage, MasterMind display, Class 1/Class 3 toggle and Dynamic MicroTune electronic mode is the most complete integrated package in the category.
Caveats and known gripes.
  • @BikeBert bluntly: "There's nothing 'Super' about the Gen 4. It's overhyped, overweight and late to the party. Pretty disappointing." Some Gen 3 owners feel the Gen 4 isn't a meaningful step.
  • @Zimmerframe echoes the disappointment: "I'm still suffering from PTSD (Pretty Thorough Specialized Disappointment)." Gen 4 is great but didn't shock the market.
  • 26.05 kg claimed weight on the Comp Alloy is heavy. Lighter alternatives (Cube AMS Hybrid 177 at 21.7 kg, Norco Range VLT at 23.8 kg) exist at higher price points.
  • 105 Nm torque is below the headline category leaders (DJI Avinox M2S at 150 Nm, Bosch CX Gen 5 at 120 Nm).
  • @Zimmerframe notes the recent Levo price reduction applies to US and Canada only — UK and EU buyers haven't seen the same discount.
Verdict. The Specialized Turbo Levo 4 Alloy 2025 is one of the best-engineered and most thoroughly integrated full-power eMTB platforms on the market at a properly competitive aluminium price point. It suits riders who value the 12-position adjustable geometry, the SWAT downtube storage, the 840 Wh battery, and the strong Specialized dealer network. The Base at £5,199 is the value pick for the entire 2025 full-power lineup. Look elsewhere if you want sub-23 kg weight, the absolute newest motor tech (DJI Avinox M2S, Bosch CX Gen 5), or a carbon chassis. Production status: current, two alloy trims, six sizes.
Frame
M5 asymmetric aluminium front + rear triangle, SWAT downtube storage, Horst-link pivots, S1 small size adds 150mm fork option
Bike geometry diagram
SS1S2MS3LS4XLS5S6
Toptube578 mm599 mm627 mm655 mm689 mm
Reach450 mm407 mm435 mm475 mm455 mm500 mm480 mm525 mm505 mm535 mm
Stack620 mm609 mm618 mm630 mm626 mm640 mm638 mm650 mm652 mm667 mm
Seattube390 mm405 mm425 mm445 mm465 mm
Chainstay446 mm435 mm435 mm448 mm435 mm453 mm435 mm453 mm435 mm435 mm
Headtube Angle63.5°64.5°64.5°63.5°64.5°63.5°64.5°63.5°64.5°64.5°
Seattube Angle (eff)77°77°77°77°77°77°77°77°77°77°
BB Drop35 mm29 mm29 mm35 mm29 mm35 mm29 mm35 mm29 mm29 mm
Wheelbase1255 mm1200 mm1280 mm1223 mm1305 mm1254 mm1330 mm1286 mm1323 mm
Headtube95 mm103 mm117 mm132 mm149 mm
BB Height350 mm350 mm350 mm350 mm350 mm350 mm
Standover753 mm754 mm753 mm758 mm761 mm
Front Centre809 mm765 mm832 mm788 mm852 mm819 mm877 mm851 mm888 mm
Trims · 1
Comp Alloy
£5,999
MotorSpecialized 2.2 · 90 Nm
BatterySpecialized M3-700 · 700 Wh
Travel F/R160/150 mm
FrameAluminium
ForkFox Float 36 Rhythm 160mm, GRIP damper, 44mm offset
ShockFox Float X Performance with Specialized Genie, 210x55mm
HeadsetSpecialized offset headset
StemAlloy Trail stem
HandlebarSpecialized 6000-series alloy 800mm
GripsSpecialized Trail Grip
SaddleSpecialized Bridge Comp
SeatpostX-Fusion Manic dropper 34.9mm
BrakesSRAM Maven Bronze 4-piston
Rear derailleurSRAM Eagle 90 T-Type
CrankSRAM S1000 155mm 34T
ShiftersSRAM GX Eagle trigger
CassetteSRAM XS-1270 Transmission 10-52T
ChainSRAM GX Eagle 12-spd
DrivetrainSRAM Eagle 90 T-Type mechanical 1x12
WheelsSpecialized 30mm alloy mullet
TyresSpecialized Butcher GRID GRAVITY T9 29x2.3 / Butcher GRID TRAIL T9 27.5x2.3
Weight26.05 kg
Price£5,999
Spot a mistake?
