Bike Finder · Rotwild
Rotwild R.X750
Rotwild
R.X750 2024
CurrentTrail eMTBLegacy · 0.6/10iFreshness 0.6/10
Travel F/R
150/152mm
Wheels
29F/27.5R
Frame
Full carbon
Weight
23.8 kg
Price
£6,792
View the Rotwild R.X750 on Rotwild’s site
Rotwild R.X750 2024
From £6,792
EMTB Forums verdict
The Rotwild R.X750 2024 is the German brand's carbon trail eMTB: 150 mm of fork travel paired with 152 mm of rear, Brose Drive S Mag motor at 90 Nm of torque and 565 W peak, and a removable 720 Wh IPU battery. At a claimed 23.8 kg with a Horst Link suspension layout and €9,999 base price, the R.X750 sits firmly in the premium German trail bracket. The 66.0 degree head angle and 441 mm chainstays held constant across four sizes signal a balanced trail bike rather than an aggressive enduro sled.
Drive system and range. The Brose Drive S Mag is the distinctive technical story. Brose-built motors are less common than Bosch or Shimano units but have a strong reputation for quiet, smooth power delivery; the Drive S Mag delivers 90 Nm of torque, 565 W peak and a 2.9 kg unit weight. The Brose unit was the basis for early Specialized 2.2 motors in the original Levo, and the lineage is well understood by service technicians. The 720 Wh removable battery is generous — bigger than 600 Wh rivals and on par with 750 Wh Bosch builds — giving real-world range of approximately 1,300–1,700 m of climbing per charge depending on mode and terrain. Brose's ecosystem is smaller than Bosch's Smart System but offers solid app and display integration through the Rotwild interface.
Geometry and handling. A 66.0 degree head angle is conservative trail rather than aggressive enduro — steep by 2024 standards where 64–65 degrees has become the trail-bike norm. Reach progresses from 401 mm (S) through 433 mm (M), 464 mm (L) and 496 mm (XL). The 441 mm chainstay is held constant across sizes — short for a 150 mm trail bike, prioritising agility. Wheelbase grows 1,168 mm to 1,266 mm. The Horst Link suspension is the proven 4-bar layout. The bike's geometry suggests a calm, accessible trail companion rather than a bike for full-aggressive descending — comparable in intent to a Trek Top Fuel or Specialized Stumpjumper Trail.
Build and value. Only the €9,999 base trim is gold-listed. Rotwild specs the R.X750 with premium components typical of high-end German engineering: FOX or RockShox suspension, Shimano XT/XTR or SRAM X0 drivetrains and SRAM Code or Magura MT brakes. The €9,999 price tag is firmly halo territory — comparable to Specialized Levo SL Gen 2 S-Works or Trek Fuel EXe 9.9 trims with similar travel.
Caveats and known gripes. No curated owner quotes or forum excerpts exist for the R.X750 specifically — first-hand long-term ownership data is essentially absent on the eMTB forum. The Brose motor's UK dealer support is meaningfully smaller than Bosch or Shimano: warranty turnaround and spare-part lead times need careful checking. The 66 degree head angle is conservative for a 2024 platform competing with 64-degree rivals at similar money — buyers expecting modern descender-friendly geometry will find this dated. The 441 mm constant chainstay is short and doesn't progress with size, so XL riders with 496 mm reach get a proportionally short rear-centre. Rotwild's brand visibility outside Germany is modest; UK retail/distribution should be confirmed before ordering. At €9,999 you are paying boutique premium pricing for a motor system with limited mainstream service support.
Verdict. The Rotwild R.X750 is a precision-engineered carbon trail eMTB for buyers who value German engineering heritage and the distinctive Brose Drive S Mag drive system. It will suit riders coming from analogue Rotwild platforms who prioritise refined ride character, a generous 720 Wh removable battery and balanced trail geometry over the slackest possible descending geometry. Buyers wanting modern 64-degree head angles, the latest Bosch CX Gen 5 ecosystem, established UK dealer support or community-proven ownership data should look at the Trek Fuel+ EX, Cube AMS Hybrid or Specialized Levo SL Gen 2. Production status: current.
💬 Forum discussion
Rotwild RX750 Ultra - Brose Mag S, 750WH
12 replies · 11.3k views · last reply 79 months ago
Join the discussion →
“Looks like its not only Specilized bringing it with the new Mag S, Rotwild coming in with all guns blazing on this one. 22.6 KG, mixed size DT Swiss carbon wheels, massive battery, full carbon frame, 12 speed XTR, Eightpins frame…”
— R120 · ♥ 14 · most-liked post
Bike geometry diagram
SMLXL
Reach401 mm433 mm464 mm496 mm
Stack606 mm613 mm633 mm644 mm
Chainstay441 mm441 mm441 mm441 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)74°74°74°74°
Wheelbase1168 mm1194 mm1232 mm1266 mm
Front Centre727 mm753 mm791 mm825 mm
Trims · 1
PRO
£6,792
MotorBrose Drive S Mag · 90 Nm
BatteryIPU 720Wh · 720 Wh
Travel F/R150/152 mm
FrameCarbon
ForkFOX 36 Float Factory Kashima
ShockFOX Float X Factory Kashima
HeadsetAcros RW750 1.5
StemROTWILD S140 AL7075, 50 mm, Ø35 mm
HandlebarROTWILD B220 Carbon, 35 mm, 15 mm Rise, 780 mm Width
GripsErgon GD10 Slim Factory Frozen
SaddleERGON SM Pro
Seatpost8PINS H01, Ø34.9 mm, 25 mm offset
BrakesSHIMANO XT 8120
Rear derailleurSHIMANO XT 8100
Cranke*thirteen Race Carbon
ShiftersSHIMANO XT 8100
CassetteSHIMANO CS 7100 10-51T 12-speed
ChainSHIMANO HG 7100 12-speed
DrivetrainSHIMANO XT 8100 12-speed
WheelsDT SWISS HX1501 SPLINE1 (30)
TyresSCHWALBE Magic Mary Evo 29x2.4 (front) / SCHWALBE Hans Dampf Evo 27.5x2.6 (rear)
Weight23.8 kg
Price£6,792
Rides similarly
Spot a mistake?
