Bike Finder · Rotwild
Rotwild R.X750
Rotwild
R.X750 2022
DiscontinuedFull Power · TrailLegacy · 0.2/10iFreshness 0.2/10
Quiet Brose-powered full-carbon all-mountain bike for long trail days
Travel F/R
150/152mm
Wheels
MX (29F / 27.5R)
Frame
Carbon front, aluminium rear / Full carbon
Weight
Price
From €7,499
View the Rotwild R.X750 on Rotwild’s site
Rotwild R.X750 2022
EMTB Forums verdict
The R.X750 was the flagship of Rotwild's 'Big Mountain' category for 2022: a handmade full carbon 150/152 mm mixed-wheel eMTB built around the Brose Drive S Mag motor and the brand's own quick release IPU750 750 Wh battery. It sat between the lighter all-mountain R.X375 and the enduro R.E750 in the German range, pitched at technical alpine climbing and descending.
All three trims shared the frame, motor, battery and Schwalbe Magic Mary/Hans Dampf tyre pairing, so the money went on suspension and drivetrain. The Core (7,499 euro) ran Fox Performance dampers, Shimano XT shifting and Magura MT5 brakes; the Pro (8,999 euro) added XT four-piston brakes, DT Swiss HX 1501 wheels and an Eightpins H01 dropper; the Ultra (11,999 euro) topped out with Factory Kashima suspension, full XTR, carbon DT Swiss HXC 1501 wheels and the longer stroke Eightpins NGS 2 post.
Geometry is moderate rather than radical, with a 66 degree head angle, 445 mm chainstays and a 437 mm reach in M, plus a usefully low 750 mm standover across all four sizes. The bike is discontinued: Rotwild relaunched the R.X750 name on a redesigned platform for 2023.
Geometry read
Size
Descending
56
A solid all-round descender (66° head angle, 152mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
62
Size balance
98
Rear-long with a planted front in L (FC:RC 1.78) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
67
Climbs well — a 74° seat keeps the front planted. 560W of peak power and 90Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Trail bikes (from 271 bikes in the database)
Battery750 Whabout average capacity
Motor torque90 Nm8 Nm below average
💬 Forum discussion
Rotwild RX750 Ultra - Brose Mag S, 750WH
12 replies · 11.4k views · last reply 80 months ago
Join the discussion →
“Looks like its not only Specilized bringing it with the new Mag S, Rotwild coming in with all guns blazing on this one. 22.6 KG, mixed size DT Swiss carbon wheels, massive battery, full carbon frame, 12 speed XTR, Eightpins frame…”
— R120 · ♥ 14 · most-liked post
Bike geometry diagram
SMLXL
Reach405 mm437 mm468 mm500 mm
Stack610 mm617 mm637 mm648 mm
Seattube413 mm444 mm473 mm509 mm
Chainstay445 mm445 mm445 mm445 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)74°74°74°74°
Wheelbase1172 mm1198 mm1236 mm1270 mm
Headtube110 mm110 mm130 mm140 mm
BB Height350 mm350 mm350 mm350 mm
Standover750 mm750 mm750 mm750 mm
Front Centre727 mm*753 mm*791 mm*825 mm*
FC:RC1.631.691.781.85
Trims · 3
Core
€7,499
Pro
€8,999
Ultra
€11,999
MotorBrose Drive S Mag · 90 Nm · all trims
BatteryRotwild IPU750 750Wh · 750 Wh · all trims
Travel F/R150/152 mm · all trims
FrameFull carbon with aluminium inserts in structural areasFull carbon with aluminium inserts in structural areasFull carbon, high-modulus fibre; carbon linkage and shock yoke
ForkFox 36 Float Performance, 150 mm, FIT GRIP 3-pos micro adjust, E-Bike+, OD crown, 44 mm offsetFox 36 Float Performance, 150 mm, FIT GRIP 3-pos micro adjust, E-Bike+, OD crown, 44 mm offsetFox 36 Float Factory Kashima, 150 mm, FIT4 3-pos adjust, E-Bike+, OD crown, 44 mm offset
ShockFox Float X Performance, 205x60 mm trunnion, 2-pos, EVOL LVFox Float X Performance, 205x60 mm trunnion, 2-pos, EVOL LVFox Float X Factory Kashima, 205x60 mm trunnion, 3-pos adjust, EVOL LV
HeadsetAcros RW750 1.5 headset with Blocklock · all trims
StemRotwild S140 AL7075, 35 mm clamp, 50 mm, MonkeyLink interface · all trims
HandlebarRotwild B280 AL7075, 35 mm clamp, 15 mm rise, 780 mmRotwild B220 Carbon, 35 mm clamp, 15 mm rise, 780 mmRotwild B220 Carbon, 35 mm clamp, 15 mm rise, 780 mm
GripsErgon GD10 Slim Factory Frozen · all trims
SaddleErgon SM · all trims
Seatposte*thirteen Vario Covert Infinite dropper, individually adjustable up to 260 mm (XL)Eightpins H01 dropper, 34.9 mm, 25 mm offset, 145 mm (S) / 160 mm (M) / 180 mm (L) / 200 mm (XL)Eightpins NGS 2 dropper, 34.9 mm, 25 mm offset, 170 mm (S) / 190 mm (M) / 210 mm (L) / 230 mm (XL)
BrakesMagura MT5 HC-W 4-piston, ShiftmixShimano XT M8120 4-piston, fin padsShimano XTR M9120 4-piston, fin pads
Rear derailleurShimano XT M8100 12-speedShimano XT M8100 12-speedShimano XTR M9100 12-speed
Cranke*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL)e*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL)e*thirteen Race Carbon, 160 mm (S) / 165 mm (M, L) / 170 mm (XL)
ShiftersShimano XT I-Spec EVShimano XT I-Spec EVShimano XTR I-Spec EV
CassetteShimano CS-M6100 10-51T 12-speedShimano CS-M7100 10-51T 12-speedShimano XTR M9100 10-51T 12-speed
DrivetrainShimano XT M8100 12-speed; e*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); Shimano XT I-Spec EV; Shimano CS-M6100 10-51T 12-speedShimano XT M8100 12-speed; e*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); Shimano XT I-Spec EV; Shimano CS-M7100 10-51T 12-speedShimano XTR M9100 12-speed; e*thirteen Race Carbon, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); Shimano XTR I-Spec EV; Shimano XTR M9100 10-51T 12-speed
WheelsDT Swiss H 1900 Spline 30, Ratchet LN 18, 6-boltDT Swiss HX 1501 Spline One 30, Ratchet EXP OS, CenterlockDT Swiss HXC 1501 Spline One 30 carbon, Ratchet EXP OS, Centerlock
TyresSchwalbe Magic Mary / Hans Dampf Evo, Super Ground, Trail TLE Soft, 29x2.40 / 27.5x2.60 · all trims
Price€7,499€8,999€11,999
Rides similarly
Spot a mistake?
