Bike Finder · Rocky Mountain
Rocky Mountain Altitude Powerplay
Rocky Mountain
Altitude Powerplay 2024
CurrentEnduro eMTBLegacy · 2.1/10iFreshness 2.1/10
Enduro eMTB with Rocky Mountain Dyname 4.0 motor (108Nm/700W) and 720Wh battery
Motor
Rocky Mountain Dyname 4.0 · 108Nm · 700W
Battery
Rocky Mountain Dyname 720 · 720Wh
Travel F/R
170/160mm
Wheels
29" (mullet conversion available)
Frame
Aluminium
Weight
24.1 kg
Price
£6,003
View the Rocky Mountain Altitude Powerplay on Rocky Mountain’s site
Rocky Mountain Altitude Powerplay 2024
From £6,003
EMTB Forums verdict
The Rocky Mountain Altitude Powerplay 2024 is the Canadian brand's long-running full-power enduro eMTB and the only major eMTB to use a proprietary in-house motor system. It is built around the Rocky Mountain Dyname 4.0 motor (108 Nm, 250 W rated, 700 W peak, 3.0 kg) and a removable 720 Wh battery, both designed and manufactured by Rocky Mountain. Travel is 170 mm front and 160 mm rear via Smoothlink four-bar suspension, head angle a properly slack 64.0°, and the bike is offered in aluminium and carbon frame variants. The community verdict on long-term durability is genuinely strong — @Flatslide has covered "14,000 km total (8,000 km original motor, 6,000 km replacement)" on a 2019 Altitude PowerPlay C50 with the 504 Wh battery "still at ~80% capacity after 14,000 km."
Drive system and range. The Dyname 4.0 is unique in the eMTB world: Rocky Mountain designed and built it in-house after departing from the Shimano/Bosch/DJI ecosystem. It produces 108 Nm of torque — properly competitive with the Bosch CX Gen 5 (120 Nm) and Shimano EP801 (85 Nm) — and benefits from a chainstay pivot positioned above the chainring per @Flatslide "to reduce mud accumulation in torque arm". The 720 Wh removable Dyname battery is generously sized; an Overtime range extender is available @JoeBlowfromIdaho ("DIY alternative possible as RM sell the connector cable separately for under $20"). Expect 1,200-1,600 m of climbing on a charge depending on terrain and assist mode.
Geometry and handling. A consistent 64.0° head angle pairs with reach progressing S 425 mm, M 450 mm, L 475 mm, XL 508 mm — a properly modern progression with a 33 mm jump from L to XL that accommodates taller riders. Chainstays scale with size: S 430 mm, M 433 mm, L 437 mm, XL 443 mm — Rocky Mountain were early advocates of size-specific rears. Wheelbase stretches 1,195-1,310 mm. The Ride9 geometry adjustment chip allows nine different head-angle/BB-height combinations per @Flatslide, with users typically running positions 1-3 for trail-to-enduro feel. @Phil M places the L chainstay (446 mm in the Altitude Powerplay Bullit variant) very close to the Levo Gen 4 in Long setting.
Build and value. Rocky Mountain offers the Altitude Powerplay in aluminium and carbon frame variants across multiple trims. The carbon frame is "approximately 3 pounds lighter than aluminum frame version" per @d3ftone — meaningful for those chasing weight. Higher trims include Fox Factory 38 forks, Fox Float X2 shocks, SRAM Code or Maven brakes and SRAM Eagle/XO Transmission. The proprietary Dyname motor means component pricing is independent of the major motor brand markups, which sometimes makes Rocky Mountain builds notable value at the upper end of the trim ladder.
Community-verified strengths. Motor longevity is well-documented — @Flatslide's 14,000 km on a 2019 platform proves the Dyname can endure. The size-specific chainstays and Ride9 adjustability draw consistent praise for fitting riders properly. @Phil M rates the bike's chainstay numbers competitive with the latest Specialized Levo Gen 4. The proprietary Canadian-engineered motor commands strong loyalty from Rocky Mountain owners.
Caveats and known gripes. The proprietary Dyname motor is also the biggest risk: service paths require returning the motor to Rocky Mountain's service centres, which limits options for European and UK buyers. @Flatslide's original motor was replaced after "transfer cog retaining nut wear on splined shaft" — a documented wear point. @Gigs found the L size cramped at 6ft / 180 cm, finding "Amflow XL fits well… feels perfect after previously finding a Rocky Mountain Altitude Powerplay Large cramped". @Suiso notes "no model weighs less than 23 kg", which is mid-pack rather than feathery. Rocky Mountain's UK and European dealer footprint is much thinner than mainstream brands. The dyname motor's 108 Nm is now mid-pack against DJI Avinox M2S (150 Nm).
Verdict. The Altitude Powerplay is for the rider who wants a proven Canadian-engineered enduro chassis, the proprietary Dyname motor's strong reliability story and Ride9 adjustability for fine-tuning geometry. It is not for buyers who need the latest 120-150 Nm motors, riders outside North American/Canadian dealer support, or anyone wanting the absolute lightest enduro eMTB. Production status is current and 2024-spec stock is available through Rocky Mountain dealers globally.
Bike geometry diagram
SMLXL
Reach425 mm450 mm475 mm508 mm
Stack629 mm628 mm638 mm652 mm
Chainstay430 mm433 mm437 mm443 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)76°76°76°76°
Wheelbase1195 mm1233 mm1268 mm1310 mm
Front Centre765 mm800 mm831 mm867 mm
Trims · 4
Altitude Powerplay Alloy 50
£6,003
Alloy 70
Altitude Powerplay A70
Altitude Powerplay Alloy 70
MotorRocky Mountain Dyname 4.0 · 108 Nm · all trims
BatteryRocky Mountain Dyname 720 · 720 Wh · all trims
Travel F/R170/160 mm · all trims
FrameAluminium · all trims
ForkRockShox Zeb Select RCRockShox Zeb Select RCFox 38 Float EVOL GRIP Performance SeriesFox 38 Float EVOL GRIP Performance Series
ShockFox Float X Performance · all trims
HeadsetFSA Orbit No.57EFSA Orbit No.57E, ZS44/ZS56FSA Orbit No.57E, ZS44/ZS56FSA Orbit No.57E, ZS44/ZS56
StemRocky Mountain 35 AM, 5deg riseRocky Mountain 35 AM, 40mm, 5deg riseRocky Mountain 35 AM, 40mm, 5deg riseRocky Mountain 35 AM, 40mm, 5deg rise
HandlebarRocky Mountain AM, 780mm, 38mm rise, 9deg backsweepRocky Mountain AM, 780mm, 38mm riseRocky Mountain AM, 780mm, 38mm riseRocky Mountain AM, 780mm, 38mm rise
GripsODI Elite Pro Lock On · all trims
SaddleWTB Volt Race 142 · all trims
SeatpostRocky Mountain Toonie Drop Alloy dropper, 30.9mmX-Fusion Manic Alloy dropper, 30.9mm, Shimano MT500 remoteX-Fusion Manic Alloy dropper, 30.9mm, Shimano MT500 remoteX-Fusion Manic Alloy dropper, 30.9mm, Shimano MT500 remote
BrakesShimano Deore Trail M6120, 4-piston, metal pads, 203/203mm rotorsShimano Deore XT Trail M8120, 4-piston, metal padsShimano MT6120 4-pistonShimano Deore XT Trail M8120, 4-piston, metal pads
Rear derailleurShimano XT, 12-speedShimano Deore XT M8100, 12-speedShimano Deore XT M8100, 12-speedShimano Deore XT M8100, 12-speed
CrankRace Face Ride CinchRace Face Aeffect Cinch, 34T, 24mm spindleRace Face Aeffect Cinch, 34T, 24mm spindleRace Face Aeffect Cinch, 34T, 24mm spindle
ShiftersShimano SLX, 12-speedShimano Deore XT M8100, 12-speedShimano Deore XT M8100, 12-speedShimano Deore XT M8100, 12-speed
CassetteShimano Deore, 12-speed, 10-51T · all trims
ChainShimano CN-M6100, 12-speedShimano M6100, 12-speedShimano M6100, 12-speedShimano M6100, 12-speed
DrivetrainShimano XT, 12-speed; Race Face Ride Cinch; Shimano SLX, 12-speed; Shimano Deore, 12-speed, 10-51T; Shimano CN-M6100, 12-speedSRAM Eagle 90 TransmissionShimano Deore XT M8100, 12-speed; Race Face Aeffect Cinch, 34T, 24mm spindle; Shimano Deore XT M8100, 12-speed; Shimano Deore, 12-speed, 10-51T; Shimano M6100, 12-speedShimano Deore XT M8100, 12-speed; Race Face Aeffect Cinch, 34T, 24mm spindle; Shimano Deore XT M8100, 12-speed; Shimano Deore, 12-speed, 10-51T; Shimano M6100, 12-speed
WheelsWTB ST i30 TCS 2.0 rims (32H, tubeless ready) on Shimano SLX Boost hubs, 29inWTB ST i30 TCS 2.0 rims (32H, tubeless ready); Rocky Mountain SL sealed Boost 15x110mm front hub, DT Swiss Hybrid 370 Boost 12x148mm rear hub, 29inWTB ST i30 TCS 2.0 rims (32H, tubeless ready); Rocky Mountain SL sealed Boost 15x110mm front hub, DT Swiss Hybrid 370 Boost 12x148mm rear hub, 29inWTB ST i30 TCS 2.0 rims (32H, tubeless ready); Rocky Mountain SL sealed Boost 15x110mm front hub, DT Swiss Hybrid 370 Boost 12x148mm rear hub, 29in
TyresMaxxis Assegai 29x2.5 WT 3C MaxxGrip DD front / Maxxis Minion DHR II 29x2.4 WT 3C MaxxTerra DD rearMaxxis Assegai 29x2.5 WT 3C MaxxGrip DD front / Maxxis Minion DHR II 29x2.4 WT 3C MaxxTerra DD rearMaxxis Assegai front / Minion DHR II rearMaxxis Assegai 29x2.5 WT 3C MaxxGrip DD front / Maxxis Minion DHR II 29x2.4 WT 3C MaxxTerra DD rear
Weight24.1 kg
Price£6,003
Spot a mistake?
