Bike Finder · Orbea
Orbea Rise
Orbea
Rise 2025
CurrentLightweight eMTBMature · 5.2/10iFreshness 5.2/10
Motor
Shimano EP801 RS · 85Nm · 600W
Battery
Orbea RS 420 · 420Wh
Travel F/R
140/140mm
Wheels
29F/29R (MX option)
Frame
Full carbon
Weight
16.32 kg
Price
From £4,199
View the Orbea Rise on Orbea’s site
Orbea Rise 2025
From £4,199
EMTB Forums verdict
The Orbea Rise 2025 is the original lightweight eMTB, refreshed for 2025 with the Shimano EP801 RS detuned motor and an integrated 420 Wh battery in a 140/140 mm carbon chassis. Headline numbers: 18.8 kg claimed on the M-Team and base trims (down to 16.32 kg on the SL hardtail), an 85 Nm motor rated capability detuned in software to deliver Orbea's signature natural-feeling power, a 64.5 to 65.5 degree size-tuned head angle and a reach span of 425 mm on S to 515 mm on XL across an exceptional 20-size matrix. The community framing is consistent: this is the bike that made the lightweight eMTB category mainstream, and the 2025 refinements keep it competitive.
Drive system and range. The Shimano EP801 RS is a "Rider Synergy" detuned version of the standard EP801, configured to deliver a 60 Nm trail-feeling default power profile rather than the full 85 Nm Boost. @Smeer documents the practical 60 Nm number versus the Trek Fuel EXe's 50 Nm. @Roaming50 confirms a typical 42 Nm and 250 W trail-assist setup in real use, which is the sweet spot for natural ride feel. The 420 Wh integrated battery is the trade for the lightweight chassis. @GunnarNyb records 124 Wh/hr consumption across 2.9 hours moving time and 7.7 Wh/km on a 47 km ride with 800 m of vertical, on the prior 360 Wh M20: scale up to 420 Wh and you have 60 to 80 km of mixed-assist range. A range-extender ships separately to push deeper days. @ep8-rs flags the EP801 RS does not have overrun capability.
Geometry and handling. A 64.5 to 65.5 degree size-tuned head angle is unusual: Orbea slacken the angle on smaller frames (65.5 degrees on S) and steepen on the larger XL configurations, which is opposite to the typical industry approach. Reach steps clean 425 mm on S, 455 mm on M and up to 515 mm on XL, with chainstays growing 435 mm on S, 445 mm on M, and 448 mm on larger frames. The wheelbase progression 1185 mm to 1320 mm is wide for a lightweight bike and reflects Orbea's commitment to size-by-rider geometry rather than one-frame-fits-all. Owners praise the natural lightweight ride feel: @CrashMaster compares the Rise M10 directly with the Trek Fuel EXe, with both bikes feeling natural in their power delivery.
Build and value. Eight trims from £3299 to £10999 is the broadest single-platform range in the lightweight category. The H10 alloy hardtail at £3299. The H30 alloy at £4499. The SL hardtail at £4999 and an exceptional 16.32 kg. The M-Team at £6500. The M10 at £6999. The M20 at £7999. The base "M-XX trim" at £8999 and the M-LTD top-spec at £10999. Value pick is the M-Team at £6500 with the same 18.8 kg as the higher-priced builds.
Community-verified strengths. Three things owners praise. The carbon chassis quality and ride feel: @jka reports nearly a year of M10 ownership with no regrets. The size-tuned chassis and ability to fit shorter and taller riders properly: @ebsocalmtb compares an XL with a medium across the family. And Orbea's wide trim ladder lets buyers pick their price point on the same chassis: @ebsocalmtb highlights the value of being able to "tailor the weight of the bike to match the ride".
Caveats and known gripes. Three honest flags. The 420 Wh integrated battery is the obvious trade for the lightweight brief: @GunnarNyb's prior 360 Wh consumption data shows long-day rides need a range extender. @skizzian flags headset cable routing on the Rise LT family as problematic, requiring special handlebars that accept cabling under the grips. And the EP801 RS motor character has been described as less smooth than the TQ HPR50 or full-power EP801 by some side-by-side testers, with @Zimmerframe calling the Rise a detuned EP8 that gives away the magic when you turn up assistance.
Verdict. The Orbea Rise 2025 is for the rider who wants the original, properly engineered lightweight eMTB with a 140/140 mm chassis, the most refined Shimano EP801 RS tune, an 18.8 kg claimed weight and Orbea's industry-leading size matrix. If you want full-power assistance or a removable battery, look at the Orbea Wild or Specialized Levo. Production status is current.
Bike geometry diagram
SMLXL
Reach425 mm455 mm480 mm505 mm
Stack600 mm623 mm633 mm643 mm
Seattube
Chainstay435 mm445 mm445 mm445 mm
Headtube Angle65.5°65°65°65°
Seattube Angle (eff)77.5°77°77°77°
BB Drop27 mm28 mm28 mm28 mm
Wheelbase1185 mm1260 mm1285 mm1310 mm
Front Centre750 mm815 mm840 mm865 mm
Trims · 7
H30
£4,199
SL
£4,999
H10
£5,199
M20
£6,099
M10
£7,499
M-LTD
£9,999
M-Team
£10,031
MotorShimano EP801 RS · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 NmShimano EP801 RS · 85 NmShimano EP801 RS · 85 NmShimano EP801 RS · 85 NmShimano EP801 RS · 85 Nm
BatteryOrbea RS 420 · 420 WhOrbea RS 420 · 420 WhOrbea Internal 420Wh · 420 WhOrbea RS 420 · 420 WhOrbea RS 420 · 420 WhOrbea 420 · 420 WhOrbea 420 · 420 Wh
Travel F/R140/140 mm · all trims
FrameCarbon · all trims
ForkFOX 34 AWL - RAIL 140 mmFOX 36 SL PERFORMANCE - GRIP 140 mm 3-PosFOX 36 SL PERFORMANCE - GRIP 140 mm 3-PosFOX 36 FACTORY - GRIP XFOX 36 FACTORY - GRIP XFox 36 Float Factory 160, Grip X, QR15x110, Kashima
ShockFox Float Performance 2-Pos Evol LV custom tune 210x50mmFox Float Performance 2-Pos Evol LV custom tune 210x50mmFOX FLOAT PERFORMANCE 2pos-AdjFOX FLOAT FACTORY 2pos-AdjFOX FLOAT FACTORY 2pos-AdjFOX DHX FACTORY
HeadsetOrbea ICR HS02, alloy, oxidated bearings, SIC (Sealed Internal Cables)Orbea ICR HS02, alloy, oxidated bearings, SIC (Sealed Internal Cables)Orbea ICR HS02, alloy, oxidated bearings, SIC (Sealed Internal Cables)Orbea ICR HS02, alloy, oxidated bearings, SIC (Sealed Internal Cables)Orbea ICR HS02, alloy, oxidated bearings, SIC (Sealed Internal Cables)Orbea ICR HS02, alloy, oxidated bearings, SIC (Sealed Internal Cables)
StemOC Stem MC20OC Stem MC20OC Stem MC20OC Stem MC20OC Alu SL Stem MC11OC Alu SL Stem MC11
HandlebarOC Handlebar MC31 Rise 20OC Handlebar MC31 Rise 20OC Handlebar MC31 Rise 20OC Alu SL Handlebar MC21 Rise 20OC Carbon Handlebar MC10 Rise 20OC Carbon Handlebar MC10 Rise 20
GripsOC, lock-onOC, lock-onOC, lock-onFoamErgon GE10
SaddleFizik Terra Ridon X5 145mmFizik Terra Ridon X5 145mmFizik Terra Ridon X5 145mmFizik Terra Ridon X5 145mmFizik Terra Ridon X1 145mmFizik Terra Ridon X1 145mm
SeatpostOC Mountain Control MC22OC Mountain Control MC22OC Mountain Control MC22OC Dropper Post MC10OC Dropper Post MC10OC Dropper Post MC10
BrakesShimano MT201 Hydraulic DiscShimano M6120 Hydraulic DiscShimano M6120 Hydraulic DiscShimano XTR 9220 Hydraulic DiscShimano XTR 9220 Hydraulic Disc
Rear derailleurShimano Deore M6100 SGS Shadow PlusShimano XT M8100 SGS Shadow PlusShimano SLX M7100 SGS Shadow PlusShimano XT M8260 SGSShimano XTR M9260 12sShimano XTR M9260 12s
CrankShimano Steps EM600Shimano Steps EM600Shimano Steps EM600Shimano Steps EM600Shimano Steps EM900Shimano Steps EM900
ShiftersShimano Deore M6100Shimano SLX M7100 I-Spec EVShimano SLX M7100 I-Spec EVShimano XT M8250Shimano XTR M9250Shimano XTR M9250
CassetteShimano CS-M6100 10-51t 12-SpeedShimano CS-M7100 10-51t 12-SpeedShimano CS-M7100 10-51t 12-SpeedShimano CS-M7100 10-51t 12-SpeedShimano CS-M9200 10-51t 12-SpeedShimano CS-M9200 10-51t 12-Speed
ChainShimano M6100Shimano M6100Shimano M6100Shimano M7100Shimano CN-9100Shimano CN-9100
DrivetrainShimano Deore M6100 SGS Shadow Plus; Shimano Steps EM600; Shimano Deore M6100; Shimano CS-M6100 10-51t 12-Speed; Shimano M6100Shimano XT M8100 SGS Shadow Plus; Shimano Steps EM600; Shimano SLX M7100 I-Spec EV; Shimano CS-M7100 10-51t 12-Speed; Shimano M6100Shimano SLX M7100 SGS Shadow Plus; Shimano Steps EM600; Shimano SLX M7100 I-Spec EV; Shimano CS-M7100 10-51t 12-Speed; Shimano M6100Shimano XT M8260 SGS; Shimano Steps EM600; Shimano XT M8250; Shimano CS-M7100 10-51t 12-Speed; Shimano M7100Shimano XTR M9260 12s; Shimano Steps EM900; Shimano XTR M9250; Shimano CS-M9200 10-51t 12-Speed; Shimano CN-9100Shimano XTR M9260 12s; Shimano Steps EM900; Shimano XTR M9250; Shimano CS-M9200 10-51t 12-Speed; Shimano CN-9100
WheelsAlloy, 29mm inner width, 32 hole, tubeless readyRace Face AR 30c Tubeless ReadyRace Face AR 30c Tubeless ReadyOQUO MC32TEAMOQUO MC32LTDOQUO MC32LTD
TyresSchwalbe Wicked Will Super RaceSchwalbe Wicked Will Super RaceSchwalbe Wicked Will Super RaceSchwalbe Wicked Will Super RaceSchwalbe Wicked Will Super RaceMaxxis Assegai DH TR
Weight16.32 kg19.8 kg18.8 kg18.8 kg
Price£4,199£4,999£5,199£6,099£7,499£9,999£10,031
Spot a mistake?
