Bike Finder · Orbea
Orbea Rise
Orbea
Rise 2023
DiscontinuedLightweight · TrailLegacy · 2.1/10iFreshness 2.1/10
Motor
Shimano EP801 RS · 60Nm · 600W
Battery
Orbea integrated 360Wh
Travel F/R
140/140mm
Wheels
29F / 29R
Frame
Aluminium / Full carbon
Weight
15.9 kg
Price
From £4,999
View the Orbea Rise on Orbea’s site
Orbea Rise 2023
From £4,999
EMTB Forums verdict
The 2023 Orbea Rise was the updated version of Orbea's class-defining lightweight trail eMTB, built around the "more bike, less E" idea. It pairs 140mm of rear travel and a 140 or 150mm fork on 29in wheels with a usefully modern but still trail-friendly stance: a 66 degree head angle, 77 degree effective seat angle and 474mm reach in size L, on 445mm chainstays across every size.
The defining feature is the drive system. The carbon M-series (M-LTD, M-Team, M10, M20) and the top alloy H10 run the Shimano EP801-RS, while the cheaper alloy H20 and H30 use the EP601-RS (also badged EP6 RS). Both are Orbea Rider Synergy tunes that cap torque at 60Nm and tune the assistance for a natural, range-focused feel rather than raw shove, with optimal cadence quoted at 75 to 90rpm. A compact 360Wh pack is standard on the carbon bikes, with a 540Wh option; the alloy H bikes carry the 540Wh pack as standard with a 360Wh option, and a 252Wh range extender bolts on for longer days, taking the system to as much as 792Wh.
On value, the M10 at GBP 7,999 has historically been the sweet spot, with Fox Factory suspension and a mostly Deore XT drivetrain. The M-Team adds XT Di2 electronic shifting, and the GBP 9,999 M-LTD chases minimum weight at 15.9kg with XTR and a lighter Fox 34 build. The alloy H range opens the platform up from GBP 4,999, with the H30 bringing a Marzocchi Bomber Z2 fork.
This 2023 model is discontinued. It was superseded by the heavily revised Rise of late 2023, and later by the Rise SL and Rise LT, which moved to a new frame with updated geometry and larger battery options, so newer Rise generations are not directly cross-compatible on battery or some fit numbers.
Geometry read
Size
Descending
60
A solid all-round descender (66° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
98
Short 445mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
96
Rear-long with a planted front in L (FC:RC 1.76) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
79
Shimano EP801 RS and a steep 77° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Lightweight · Trail bikes (from 87 bikes in the database)
Weight15.9 kg3.0 kg lighter than average
Battery360 Wh74 Wh below average
Motor torque60 Nmabout average torque
Value for money50/100from £4,999 · comparable bikes ~£4,999
💬 Forum discussion
Orbea Rise , anyone seen one yet ?
876 replies · 203.9k views · last reply 57 months ago
Join the discussion →
“So it arrived yesterday...M10 large...fit and finish is really solid. There is def a rattle from the motor but only rode it briefly. The power to weight ratio feels good actually better than i expected. I need to play with the E-TUBE…”
— Cbmojo · ♥ 20 · most-liked post
OWNERS’ REPORT
Orbea Rise — what owners actually know
9,830 posts · 1,336 owners · data through May 2026
35GEN 1: battery mortality and the no-replacement-outside-warranty problem · typical onset: 2-4 years.
30GEN 1: pivot bearing and linkage wear (the signature maintenance issue) · typical onset: 6-18 months of real use; faster in wet climates.
28GEN 1: charging/connection faults via the head-tube wiring · typical onset: New-bike assembly faults or post-crash/post-service.
4,223 miles on a 2023 Rise EP801 posted into a 'Scared about reliability' thread as the reassurance case.
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
SMLXL
Reach425 mm450 mm474 mm500 mm
Stack604 mm613 mm627 mm646 mm
Seattube381 mm419 mm457 mm508 mm
Chainstay445 mm445 mm445 mm445 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)77°77°77°77°
Wheelbase1180 mm1205 mm1229 mm1255 mm
Headtube95 mm105 mm120 mm140 mm
BB Height336 mm336 mm336 mm336 mm
Standover710 mm736 mm766 mm776 mm
Front Centre735 mm*760 mm*784 mm*810 mm*
FC:RC1.651.711.761.82
Trims · 7
H30
£4,999
H20
£5,499
H10
£6,299
M20
£6,499
M10
£7,999
M-Team
£9,299
M-LTD
£9,999
MotorShimano EP6 (DU-EP600) · 60 NmShimano EP6 (DU-EP600) · 60 NmShimano EP801 RS · 60 NmShimano EP801 RS · 60 NmShimano EP801 RS · 60 NmShimano EP801 RS · 60 NmShimano EP801 RS · 60 Nm
BatteryOrbea integrated 360Wh · 360 Wh · all trims
Travel F/R140/140 mm · all trims
FrameHydroformed alloy, triple-butted tubes, molded chainstay and seatstay protectionHydroformed alloy, triple-butted tubes, molded chainstay and seatstay protectionHydroformed alloy, triple-butted tubes, molded chainstay and seatstay protectionOMR CarbonOMR CarbonOMR CarbonOMR Carbon
ForkMarzocchi Bomber Z2, GRIP damper, 44mm offset (options: FOX FLOAT 34 or 36 Performance)FOX FLOAT 34 Performance, GRIP damper, 3-position compression lever, 44mm offset (option: FOX FLOAT 36 Performance)FOX FLOAT 36 Performance, GRIP damper, 44mm offset (Factory option available)FOX FLOAT 34 Performance, GRIP damper, 3-position compression lever, 44mm offsetFOX FLOAT 36 Factory, GRIP2 damper, Kashima coating, 44mm offset (option: FOX FLOAT 34)FOX FLOAT 36 Factory, GRIP2 damper, Kashima coating, 44mm offset (option: FOX FLOAT 34 Factory)FOX FLOAT 34 Factory, FIT4 damper, 3-position compression lever, Kashima coating, 44mm offset (option: FOX FLOAT 36 Factory, GRIP2 damper)
ShockFOX FLOAT DPS Performance, EVOL, 3-position compression lever, custom tune, trunnion mount, 210mm x 55mmFOX FLOAT DPS Performance, EVOL, 3-position compression lever, custom tune, trunnion mount, 210mm x 55mm (option: FLOAT X Performance)FOX FLOAT X Performance, EVOL LV, 2-position compression lever, custom tune, trunnion mount, 210mm x 55mmFOX FLOAT DPS Performance, EVOL, 3-position compression lever, custom tune, trunnion mount, 210mm x 55mmFOX FLOAT X Factory, EVOL LV, 2-position compression lever (option: FOX FLOAT DPS)FOX FLOAT X Factory, EVOL LV, 2-position compression lever, Kashima coating, custom tune, trunnion mount, 210mm x 55mmFOX FLOAT DPS Factory, EVOL, 3-position compression lever, Kashima coating, custom tune, trunnion mount, 210mm x 55mm (option: FOX FLOAT X Factory)
HeadsetOrbea SIC (Sealed Internal Cables); Spin Block rotation limiter · all trims
StemOC Mountain Control MC20, 0° riseOC Mountain Control MC20, 0° riseOC Mountain Control MC10 Alu SL, 0° riseOC Mountain Control MC20, 0° riseOC Mountain Control MC20OC Mountain Control MC10 Alu SL, 0° riseOC Mountain Control MC10 Alu SL, 0° rise
HandlebarOC Mountain Control MC31, 800mm width, 20mm riseOC Mountain Control MC31, 800mm width, 20mm riseOC Mountain Control MC21 Alu SL, 800mm width, 20mm riseOC Mountain Control MC21 Alu SL, 800mm width, 20mm riseOC Mountain Control MC10 Carbon, 800mm widthOC Mountain Control MC10 Carbon, 800mm widthOC Mountain Control MC10 Carbon, 800mm width, 20mm or 35mm rise options
SaddleSelle Italia Model X, FecAlloy rails, 145mm width, 248mm lengthfi'zi:k Taiga, S-Alloy rails, 142mm widthfi'zi:k Taiga, S-Alloy rails, 142mm widthfi'zi:k Taiga, S-Alloy rails, 142mm widthfi'zi:k Taiga (options)fi'zi:k Taiga, Kium rails, 142mm widthfi'zi:k Antares R1, 142mm width (option: fi'zi:k Taiga, Kium rails)
SeatpostOC Mountain Control MC20 dropper, Shimano MT500 remote leverOC Mountain Control MC20 dropper, Shimano MT500 I-SPEC EV remote leverOC Mountain Control MC20 dropper, Shimano MT500 I-SPEC EV remote leverOC Mountain Control MC20 dropper, Shimano MT500 I-SPEC EV remote leverOC Mountain Control MC20 dropperFOX Transfer Factory dropper, Kashima coatingFOX Transfer SL Factory dropper, Kashima coating (option: FOX Transfer Factory)
BrakesShimano MT410, 2-piston (option: Shimano Deore M6100)Shimano Deore M6120, 4-pistonShimano Deore M6120, 4-piston (option: XT M8120)Shimano Deore M6100, 2-pistonShimano Deore M6120, 4-piston (option: XT M8120)Shimano Deore XT M8120, 4-pistonShimano XTR M9100, 2-piston (option: Shimano XTR M9120, 4-piston)
Rear derailleurShimano Deore M6100, 12-speed, SGS cage, SHADOW RD+Shimano Deore XT M8100, 12-speed, SGS cage, SHADOW RD+Shimano Deore XT M8100, 12-speed, SGS cage, SHADOW RD+Shimano SLX M7100, 12-speed, SGS cage, SHADOW RD+Shimano Deore XT M8100, 12-speed, SGS cage, SHADOW RD+Shimano Deore XT Di2 M8150, 12-speed, electronic, SGS cage, SHADOW RD+Shimano XTR M9100, 12-speed, SGS cage, SHADOW RD+
CrankShimano STEPS EM600Shimano STEPS EM600Shimano STEPS EM600Shimano STEPS EM600Shimano STEPS EM600Shimano STEPS EM900Shimano STEPS EM900
ShiftersShimano Deore M6100, 12-speedShimano SLX M7100, 12-speed, I-SPEC EV mounting bracketShimano Deore XT M8100, 12-speed, I-SPEC EV mounting bracketShimano SLX M7100, 12-speed, I-SPEC EV mounting bracketShimano Deore XT M8100, 12-speedShimano Deore XT Di2 M8150, 12-speed, electronicShimano XTR M9100, 12-speed
CassetteShimano Deore M6100, 12-speed, 10-51 toothShimano SLX M7100, 12-speed, 10-51 toothShimano SLX M7100, 12-speed, 10-51 toothShimano SLX M7100, 12-speed, 10-51 toothShimano SLX M7100, 12-speed, 10-51 toothShimano Deore XT M8100, 12-speed, 10-51 toothShimano XTR M9100, 12-speed, 10-51 tooth
ChainShimano Deore M6100, 12-speedShimano Deore M6100, 12-speedShimano SLX M7100, 12-speedShimano Deore M6100, 12-speedShimano SLX M7100Shimano Deore XT M8100, 12-speedShimano XTR M9100, 12-speed
DrivetrainShimano Deore M6100, 12-speed, SGS cage, SHADOW RD+; Shimano STEPS EM600; Shimano Deore M6100, 12-speed; Shimano Deore M6100, 12-speed, 10-51 tooth; Shimano Deore M6100, 12-speedShimano Deore XT M8100, 12-speed, SGS cage, SHADOW RD+; Shimano STEPS EM600; Shimano SLX M7100, 12-speed, I-SPEC EV mounting bracket; Shimano SLX M7100, 12-speed, 10-51 tooth; Shimano Deore M6100, 12-speedShimano Deore XT M8100, 12-speed, SGS cage, SHADOW RD+; Shimano STEPS EM600; Shimano Deore XT M8100, 12-speed, I-SPEC EV mounting bracket; Shimano SLX M7100, 12-speed, 10-51 tooth; Shimano SLX M7100, 12-speedShimano SLX M7100, 12-speed, SGS cage, SHADOW RD+; Shimano STEPS EM600; Shimano SLX M7100, 12-speed, I-SPEC EV mounting bracket; Shimano SLX M7100, 12-speed, 10-51 tooth; Shimano Deore M6100, 12-speedShimano Deore XT M8100, 12-speed, SGS cage, SHADOW RD+; Shimano STEPS EM600; Shimano Deore XT M8100, 12-speed; Shimano SLX M7100, 12-speed, 10-51 tooth; Shimano SLX M7100Shimano Deore XT Di2 M8150, 12-speed, electronic, SGS cage, SHADOW RD+; Shimano STEPS EM900; Shimano Deore XT Di2 M8150, 12-speed, electronic; Shimano Deore XT M8100, 12-speed, 10-51 tooth; Shimano Deore XT M8100, 12-speedShimano XTR M9100, 12-speed, SGS cage, SHADOW RD+; Shimano STEPS EM900; Shimano XTR M9100, 12-speed; Shimano XTR M9100, 12-speed, 10-51 tooth; Shimano XTR M9100, 12-speed
WheelsAlloy, 29mm inner width, 32 hole, tubeless ready, Boost hubsRace Face AR 30c wheelset (option: OQUO Mountain Control MC32Team)OQUO Mountain Control MC32Team; 15mm x 110mm (Boost) front, 12mm x 148mm (Boost) rearRace Face AR 30c wheelsetOQUO Mountain Control MC32Team (option: carbon)OQUO Mountain Control MC32LTD wheelsetOQUO Mountain Performance MP30LTD wheelset (option: OQUO Mountain Control MC32LTD Carbon)
TyresFront: Maxxis Dissector, 3C MaxxTerra, EXO casing, TR, 60 TPI, 29" x 2.4"; Rear: Maxxis Rekon, 3C MaxxTerra, EXO+, 120 TPI, 29" x 2.4"Front: Maxxis Dissector, 3C MaxxTerra, EXO casing, TR, 60 TPI, 29" x 2.4"; Rear: Maxxis Rekon, 3C MaxxTerra, EXO+, 120 TPI, 29" x 2.4"Maxxis Dissector, 3C MaxxTerra, EXO+ casing, TR, 120 TPI, 29" x 2.4" (front and rear, options listed)Front: Maxxis Dissector, 3C MaxxTerra, EXO casing, TR, 60 TPI, 29" x 2.4"; Rear: Maxxis Rekon, 3C MaxxTerra, EXO+, 120 TPI, 29" x 2.4"Maxxis Dissector front / Maxxis Dissector rear (various options)Front: Maxxis Dissector, 29" x 2.4"; Rear: Maxxis Rekon (or Minion DHR II option), 29" x 2.4"Front: Maxxis Rekon, 3C MaxxTerra, EXO casing, TR, 120 TPI, 29" x 2.6"; Rear: Maxxis Rekon, Dual compound, EXO casing, TR, 60 TPI, 29" x 2.4"
Weight15.9 kg
Price£4,999£5,499£6,299£6,499£7,999£9,299£9,999
Rides similarly
Spot a mistake?
