Phase Evo 2026
Second-tier Phase Avinox trim (£8,250 GBP)
The Orange Phase Evo 2026 is the UK brand's flagship full-power eMTB, hand-formed in Halifax around the DJI Avinox M2S motor (150 Nm peak torque, 250 W rated, 1500 W manufacturer-claimed peak, 2.63 kg) and an integrated 800 Wh Avinox FP800 battery. Travel is 160 mm front and 160 mm rear on a 6061-T6 monocoque aluminium chassis with Orange's signature single pivot suspension. Mixed wheels (29F/27.5R), four trims from £7,500 to €10,250. Six size/configuration combinations with flip-chip giving 63.0 to 64.0 degree head angles, chainstays 447-448 mm, reach 464-500 mm. Claimed weight 19.5 kg. The community read in one line: Yorkshire-built single pivot enduro on the most powerful production eMTB motor available, with the trade-off being a non-removable battery and Orange's traditional single pivot kinematics.
Drive system and range. The DJI Avinox M2S is the second-generation Avinox motor and currently the most powerful production eMTB drive: 150 Nm peak torque, 1500 W manufacturer-claimed peak, all in 2.63 kg. Massive smartphone tuning ecosystem via the Avinox app, GPS, 4G connectivity and anti-theft features via the touchscreen display. The 800 Wh battery is integrated and NOT user-removable, which is the major trade-off — charging happens on the bike via a discreet port. Real-world range will sit in the 45 to 75 km territory in mixed terrain on Trail/Boost mode.
Geometry and handling. Modern enduro geometry with flip-chip adjustability. 63.0 to 64.0 degree head angle depending on flip-chip position, reach progressing 464 mm (M) through 500 mm (XL), chainstays 447-448 mm flat. Wheelbase 1259 to 1310 mm. The single pivot suspension is the Orange signature — predictable, simple, requires fewer bearings than four-bar, but doesn't have the progressive ramp-up of more complex layouts. @The undecided on the older Phase EVO LE: "geometry and fit praised for tight technical riding."
Build and value. Four trims, well-spaced. DJI at £7,500 (19.5 kg) gets Fox 38 Factory GRIP X2 Kashima fork, Fox Float X2 Factory shock, SRAM Maven Silver brakes, and SRAM Eagle 90 Transmission. The base trim at £8,250 (19.5 kg) downgrades the suspension to RockShox Zeb Select+ and Super Deluxe Select+ but keeps the same brakes and drivetrain. Factory at €10,250 and RS at €9,700 are the premium trims. The DJI trim with Fox Factory suspension at £7,500 is the standout value play in the entire 2026 Avinox M2S lineup.
Community-verified strengths.
- @The undecided notes the previous gen Orange Phase Evo "doesn't flop at slow speeds like slacker bikes" — single pivot kinematics combined with mixed wheels keep the bike controlled at low speed.
- Hand-formed in Halifax, UK from 6061-T6 monocoque aluminium tubing. Proper Yorkshire engineering, unusual at this price.
- The DJI Avinox M2S is the headline. @Rob Rides EMTB documented the comparison: DJI provides 66.7% more power than the Bosch CX Gen 5 (1000 W vs 600 W), 41.2% more torque (120 vs 85 Nm), and is 10% lighter at 2.52 kg vs 2.8 kg. The M2S goes further still.
Caveats and known gripes.
- Battery is NOT user-removable. Charging happens on the bike, you cannot carry a spare, and replacement requires a workshop visit.
- Single pivot suspension at 160 mm rear travel is unconventional. Most enduro eMTBs use four-bar Horst Link or similar progressive layouts. Some riders will prefer the more progressive feel.
- Orange's dealer network is small. Strong in the UK but thin internationally — warranty work outside the UK depends on Orange's remote support.
- Frame design is more functional than refined. Orange's tube-form aesthetic is divisive and the bike doesn't have the sleek lines of carbon competitors.
Verdict. The Orange Phase Evo 2026 is a genuinely interesting Yorkshire-built eMTB that pairs the most powerful production motor on the market with Orange's signature single pivot chassis at properly competitive pricing. It suits UK riders who appreciate Orange's hand-built ethos, who want bleeding-edge DJI motor power in a 19.5 kg aluminium chassis, and who can live with the non-removable battery. Look elsewhere if you want a removable battery, a progressive four-bar suspension, or a carbon chassis. Production status: current, four trims, six size/configuration combinations.
Frame
6061-T6 Monocoque UK-formed custom aluminium tubing, made in Halifax UK; 160mm rear travel, MX (29F/27.5R)
| M | L | XL | |
| Toptube | 635 mm | 635 mm | 665 mm |
| Reach | 464 mm | 477 mm | 500 mm |
| Stack | 642 mm | 649 mm | 659 mm |
| Seattube | 431 mm | 440 mm | — |
| Chainstay | 448 mm | 447 mm | 448 mm |
| Headtube Angle | 63° | 63.2° | 64° |
| Seattube Angle (eff) | 76° | 75.6° | 76° |
| BB Drop | 27 mm | 27 mm | -11 mm |
| Wheelbase | 1276 mm | 1289 mm | 1303 mm |
| Headtube | 120 mm | 120 mm | 150 mm |
| Front Centre | 828 mm | 842 mm | 855 mm |
Trims · 2
RS £7,500 | Factory £8,250 | |
| Motor | Avinox M2S · 150 Nm · all trims | |
| Battery | Avinox FP800 · 800 Wh · all trims | |
| Travel F/R | 160/160 mm · all trims | |
| Frame | Aluminium · all trims | |
| Fork | RockShox Zeb Select+ 29x160mm | Fox 38 Factory GRIP X2 Kashima 29x160mm |
| Shock | RockShox Super Deluxe Select+ 205x65mm | Fox Float X2 Factory 205x65mm Trunnion |
| Headset | Cane Creek ZS49/ZS56 · all trims | |
| Stem | Burgtec Enduro 40mm · all trims | |
| Handlebar | Burgtec Ridewide 800mm x 30mm rise · all trims | |
| Grips | Strange Grappler lock-on · all trims | |
| Saddle | SDG Bel Air III · all trims | |
| Seatpost | KS Rage-i 170mm dropper | Fox Transfer Factory Kashima dropper |
| Brakes | SRAM Maven Silver 4-piston hydraulic disc · all trims | |
| Rear derailleur | SRAM Eagle 90 Transmission, 12-speed · all trims | |
| Crank | SRAM Eagle 90 Transmission, 165mm, 34T · all trims | |
| Shifters | SRAM Eagle 90 Transmission Pod controller · all trims | |
| Cassette | SRAM XS-1270 Eagle Transmission, 10-52T, 12-speed · all trims | |
| Chain | SRAM Eagle 70 Transmission Flattop, 12-speed · all trims | |
| Drivetrain | SRAM Eagle 90 Transmission, 12-speed · all trims | |
| Wheels | Hope Pro 5 hubs with Stan's Flow S2 rims, MX 29/27.5 | Hope Pro 5 hubs with Stan's Flow MK4 rims, MX 29/27.5 |
| Tyres | Continental Kryptotal Soft 2.4" · all trims | |
| Weight | 24.34 kg · all trims | |
| Price | £7,500 | £8,250 |
Spot a mistake?
