Bike Finder · MAXX
MAXX FAB.4 ELA
MAXX
FAB.4 ELA 2026
CurrentEnduro🔥 Hot · 10/10iFreshness 10/10
Avinox-powered carbon enduro eMTB with 130Nm motor and 600/800Wh battery
Motor
Avinox M2S · 150Nm · 1500W
Battery
Avinox RS600 · 600Wh
Travel F/R
170/160mm
Wheels
29F/29R
Frame
Full carbon
Weight
23.43 kg
Price
£5,694
View the MAXX FAB.4 ELA on MAXX’s site
MAXX FAB.4 ELA 2026
From £5,694
EMTB Forums verdict
The MAXX FAB.4 ELA 2026 is a Bavarian carbon full-suspension e-enduro built around the DJI Avinox M2S motor, with a 50-colour factory paint programme and customisable components as the standout USPs. Headline numbers: 150 Nm of torque, 1,500 W manufacturer-claimed peak, 600 Wh removable DJI Avinox battery, 170 mm front / 160 mm rear travel, a 65.0 degree head angle and a €6,699 base. There are no curated community quotes on file yet, so this verdict draws on the gold spec sheet and the DJI Avinox M2S platform context.
Drive system and range. The DJI Avinox M2S is currently one of the most powerful and most-discussed motors in the segment, delivering 150 Nm of torque and a 1,500 W manufacturer-claimed peak at a class-leading 2.63 kg motor weight. As of April 2026 the M2S is used across 60-plus brands including Commencal, Forbidden, Unno, Megamo and Pivot Shuttle AMP'd, so the unit has graduated from exotic to mainstream. The 600 Wh DJI Avinox battery is removable and is on the modest side for a full-power enduro — riders should expect three to four hours of mixed-trail riding before reserves bite. With a manufacturer-claimed peak of 1,500 W, this is among the highest-output mainstream motors on sale.
Geometry and handling. The FAB.4 ELA runs five sizes (S, M, L, XL, XXL), with reach progressing from 427 mm (S) through 460 mm (M), 490 mm (L), 510 mm (XL) and topping at 525 mm in XXL. The head angle is fixed at 65.0 degrees across the range, with a 455 mm chainstay and wheelbase that grows from 1,222 mm to 1,346 mm. By 2026 enduro-eMTB standards the 65 degree HA is on the conservative side compared to genuinely slack 64 degree rivals, but the long reach progression and XXL size option will appeal to taller riders specifically. The full-suspension layout uses a Horst Link with 170/160 mm travel split — biased slightly more towards descending than the symmetrical-travel rivals.
Build and value. Only the base trim is on file at €6,699, with the carbon frame, DJI Avinox M2S motor, removable 600 Wh battery, and the headline MAXX wet-paint workshop offering: ex-works customisable colours and component finishes (matte or glossy) via the brand's facility in Rosenheim, Germany. This makes the FAB.4 ELA effectively the only DJI Avinox-equipped factory custom-paint eMTB on the market — a meaningful differentiator for buyers willing to wait for a build.
Verdict. The MAXX FAB.4 ELA 2026 suits buyers who specifically want the DJI Avinox M2S motor in a Bavarian-built carbon enduro chassis, factory-custom paint and component finish, and the long-range geometry that includes an XXL size. Less suitable for riders who need the absolute slackest enduro geometry, the largest available battery capacities, or a mainstream-brand dealer network with established UK presence. Production status: current. Without a published trim ladder above the base or any community feedback, demo and direct dealer engagement are essential before committing.
Frame
Carbon full-suspension enduro frame with Horst-Link suspension, 170mm front / 160mm rear travel, 29in wheels, removable Avinox battery; ex-works customisable colour and components (matte or glossy) via MAXX wet-paint workshop in Rosenheim.
Bike geometry diagram
SMLXLXXL
Toptube591 mm618 mm638 mm671 mm703 mm
Reach427 mm453 mm470 mm498 mm525 mm
Stack634 mm639 mm652 mm670 mm688 mm
Seattube380 mm420 mm460 mm500 mm540 mm
Chainstay455 mm455 mm455 mm455 mm455 mm
Headtube Angle65°65°65°65°65°
Seattube Angle (eff)75°75°75°75°75°
BB Drop23 mm23 mm23 mm23 mm23 mm
Wheelbase1222 mm1251 mm1274 mm1310 mm1346 mm
Headtube115 mm120 mm135 mm155 mm175 mm
BB Height355 mm355 mm355 mm355 mm355 mm
Front Centre767 mm796 mm819 mm855 mm891 mm
Trims · 4
FAB.4 ELA
£5,694
FAB.4 ELA 600Wh
FAB.4 ELA 800Wh
Standard
MotorAvinox M2S · 150 Nm · all trims
BatteryAvinox RS600 · 600 Wh · all trims
Travel F/R170/160 mm · all trims
FrameCarbon · all trims
ForkRockShox Lyrik Select, 160mm, 29" · all trims
ShockRockShox Deluxe Select Plus TR 205x65 · all trims
HeadsetFSA Block-Lock 150°, ZS56/28.6 | ZS44 · all trims
StemFSA Comet 0°, 35mm, Ø35mm · all trims
HandlebarFSA Comet Riser, Ø35mm, 800mm width, 25mm rise, 8° · all trims
GripsMAXX Race Grip Lock-On · all trims
SaddleErgon SMC10, 149mm, black · all trims
SeatpostM-Wave Dropper Post 150mm, 31.6mm, w/lever · all trims
BrakesShimano Deore BL-M6100/BR-M6120 · all trims
Rear derailleurSRAM S1000 Eagle Transmission 1x12 · all trims
CrankSRAM Eagle TR 38T 104 BCD steel (Avinox) · all trims
ShiftersSRAM AXS Pod Controller (right) · all trims
CassetteSRAM XS-1270 12-speed 10-52T · all trims
ChainSRAM GX Eagle TR Flattop 12-speed · all trims
DrivetrainSRAM S1000 Eagle Transmission 1x12 · all trims
WheelsNewmen Beskar 30 (front Light / rear Base XD), 28/29" · all trims
TyresSchwalbe Nobby Nic 29x2.4" Performance folding · all trims
Weight23.43 kg24.3 kg
Price£5,694
Spot a mistake?
