Macina Lycan 2024
All-mountain eMTB with Bosch Performance CX Gen4 Smart System (85Nm) and 750Wh battery
The KTM Macina Lycan 2024 is an Austrian-built aluminium trail eMTB that pairs Yamaha's PW-X3 drive with a removable 720 Wh battery, on a Straight-Line-Link rear end and 27.5-inch wheels. Travel runs 170 mm at the fork and 140 mm rear, the chassis weighs 25.7 kg system, and headline numbers include 85 Nm of torque, 500 W peak power, a 66 to 67 degree size-specific head angle and a 397 to 468 mm reach range across four sizes. £4,859 for the base trim. Community verdict: an honest, well-priced KTM trail tool that delivers a Yamaha-flavoured ride feel for buyers who want an alternative to the Bosch CX hegemony.
Drive system and range. The Yamaha PW-X3 is one of the lightest full-power motors at 2.75 kg, with 85 Nm of torque and 500 W of peak power. It is known for a responsive natural feel at high cadence and a satisfying click off the line. The Yamaha unit benefits from a robust factory warranty and worldwide Yamaha service network. The removable 720 Wh battery on the Lycan delivers strong all-day range, with mixed trail use typically reaching 50 to 80 km depending on terrain and rider weight. KTM's Power Tube Top Loader (PTTL) battery access system speeds removal compared to side-loading or downtube-door designs.
Geometry and handling. A 66 degree head angle on size S and 67 degrees on M to XL is steeper than the modern trail norm, which keeps the Lycan playful and responsive on tight, technical singletrack but limits aggressive descending compared to a 64 degree all-mountain rival. Reach grows from 397 mm in S to 468 mm in XL. The 450 mm chainstay is identical across sizes, which keeps the bike agile on size M and L. Wheelbases run 1151 to 1218 mm, which is notably shorter than modern 29er trail bikes thanks to the 27.5-inch wheel choice. That short wheelbase suits tight trail riding and bike-park playfulness, but limits high-speed stability.
Build and value. One trim, £4,859. Build runs an SR Suntour XCR34 Air fork at 140 mm, RockShox Deluxe Select+ rear shock, Tektro HD-M750 four-piston brakes with 203 mm front and 180 mm rear rotors, and Shimano CUES Di2 11-speed or Deore 11-speed depending on configuration. The standout strength is the 720 Wh battery on an entry-level trim, where most rivals at this price step buyers down to 500 to 625 Wh. The questionable note is the SR Suntour fork on a 170 mm front-travel chassis, plus the 11-speed drivetrain that sits a generation behind modern 1x12 builds.
Community-verified strengths. Owners praise Yamaha PW-X3 reliability and the Lycan's stout aluminium chassis. The PTTL top-loading battery design is repeatedly highlighted as easier than side-door systems, especially in cold or muddy conditions. KTM's broader dealer network across Europe gives buyers genuine option for warranty and motor service compared to the smaller boutique Austrian brands.
Caveats and known gripes. The Lycan has been called nose-heavy by owners who have progressed through later-generation eMTBs from Specialized, Orbea and Amflow, which makes drops and steep terrain feel less confident than newer carbon flagships with better weight distribution. The SR Suntour fork is functional but a long way from the RockShox Lyrik or FOX 38 you would get on a £5,500+ rival. 27.5-inch wheels limit speed and roll-over compared to 29ers, and short wheelbases on bigger sizes (XL at only 1218 mm) feel cramped for taller riders. The 11-speed CUES or Deore drivetrain is dependable but offers limited gear range compared to modern 1x12.
Verdict. The Macina Lycan 2024 suits the value-led trail rider who wants Yamaha PW-X3 reliability on a removable 720 Wh battery in a sub-£5,000 alloy chassis, particularly if they favour 27.5-inch wheels for playful trail riding. Riders chasing modern geometry, 29-inch stability or higher-end suspension should look at the Cube Stereo Hybrid 140, the Cannondale Moterra Neo or the Mondraker Crafty. Production status: current.
Frame
Macina Lycan aluminium 6061 alloy, Straight-Line-Link (SLL) suspension, 140mm rear travel, 27.5in wheels, Power Tube Top Loader (PTTL) battery access
| S | M | L | XL | |
| Reach | 397 mm | 418 mm | 442 mm | 468 mm |
| Stack | 600 mm | 602 mm | 612 mm | 621 mm |
| Chainstay | 450 mm | 450 mm | 450 mm | 450 mm |
| Headtube Angle | 66° | 67° | 67° | 67° |
| Seattube Angle (eff) | 74° | 74° | 74° | 74° |
| Wheelbase | 1151 mm | 1165 mm | 1192 mm | 1218 mm |
| Front Centre | 701 mm | 715 mm | 742 mm | 768 mm |
Trims · 2
Base £4,859 | Macina Lycan 772 | |
| Motor | Yamaha PW-X3 · 85 Nm · all trims | |
| Battery | Bosch PowerTube 750Wh · 750 Wh · all trims | |
| Travel F/R | 140/140 mm · all trims | |
| Frame | Aluminium · all trims | |
| Fork | Suntour XCR34 Air 2CR 27.5in 140mm 15AH2 | Suntour XCR 34 Air 27.5" LOR 140mm 15x110 taper |
| Shock | RockShox Deluxe Select+ 230x62.5 · all trims | |
| Headset | Acros AICR internal 1.1/8in-1.5in angle limit | Acros AICR internal 1.1/8"-1.5" angle limit |
| Stem | KTM TEAM Trail35 | KTM TEAM II Trail35 |
| Handlebar | KTM COMP Trail35 rizer15 760mm | KTM COMP II Trail35 rizer15 760mm |
| Grips | KTM COMP Lock · all trims | |
| Saddle | KTM Line Sport · all trims | |
| Seatpost | KTM COMP dropper internal 30.9 | KTM COMP II dropper internal |
| Brakes | Tektro HD-M750 / E730 4-piston (some trims Tektro HD-M535) with 203mm front / 180mm rear rotors | Tektro HD-M535 4-piston disc |
| Rear derailleur | Shimano CUES Di2 U8050-11 SGS Shadow (771) / Shimano Deore 11-speed (772) | Shimano Deore M5100-11 SGS shadow+ |
| Crank | KTM E-TRAIL ISIS 170mm Q16 | KTM E-TRAIL ISIS 170mm Q16, FSA steel 36T Direct Mount chainring |
| Shifters | Shimano CUES Di2 EN605 Switch (771) / Shimano Deore (772) | Shimano Deore M5100-11 |
| Cassette | Shimano LG400-11 / 11-50 | Shimano Deore M5100-11, 11-51 |
| Chain | KMC e11 Sport EPT e-bike · all trims | |
| Drivetrain | 1x11 Shimano CUES Di2 / Deore | Shimano Deore M5100-11 SGS shadow+; KTM E-TRAIL ISIS 170mm Q16, FSA steel 36T Direct Mount chainring; Shimano Deore M5100-11; Shimano Deore M5100-11, 11-51; KMC e11 Sport EPT e-bike |
| Wheels | 27.5in Ambrosio E30/E35 Trail 32H wheelset | Shimano MT410B front / MT400B rear hubs, 32H, on Ambrosio E30 Trail rims, 27.5" |
| Tyres | Schwalbe Nobby Nic Performance Folding 65-584 | Schwalbe Nobby Nic Performance |
| Weight | 25.7 kg | — |
| Price | £4,859 | — |
Spot a mistake?
