Macina Kapoho 2024
Carbon SLL mullet enduro on Bosch Performance CX Gen.4 + 750Wh
The KTM Macina Kapoho 2024 was KTM's carbon mullet enduro eMTB, built around the Bosch Performance Line CX Gen 4 motor (85 Nm torque, 250 W rated, 600 W manufacturer-claimed peak, 2.9 kg) and a 750 Wh Bosch PowerTube battery. Travel is 160 mm front and 160 mm rear on a Dimmix Performance carbon chassis with Straight-Line-Link (SLL) 4-bar suspension. Mixed wheels (29F/27.5R). Three sizes M/L/XL, reach 445-480 mm, head angle 65.0 degrees flat, chainstays 442 mm flat, wheelbase 1214-1259 mm. Claimed weight 25.9 kg. Single base trim at £5,899. The community read in one line: a properly aggressive Austrian carbon mullet enduro with the Bosch CX Gen 4 ecosystem and Dimmix tube technology, now discontinued and superseded by KTM's newer Macina Lycan/Prowler platforms.
Drive system and range. The Bosch CX Gen 4 is the predecessor to the current Gen 5, but remains a highly refined and well-supported motor — 85 Nm torque, smooth and quiet, with free OTA firmware updates via the eBike Flow app and the deepest dealer network in Europe. The 750 Wh Bosch PowerTube battery is removable for off-bike charging. Real-world range will sit in the 50 to 75 km territory in mixed terrain on Trail/eMTB mode, with extreme cases pushing further on Eco mode. The Bosch ecosystem remains the gold standard for motor support and longevity.
Geometry and handling. Modern mullet enduro. 65.0 degree head angle is right on the trail/enduro boundary — slacker than the Macina Lycan trail platform but not into super-slack DH territory. Reach progresses 445 mm (M), 463 mm (L), 480 mm (XL). Chainstays held at 442 mm flat across all three sizes. Mixed-wheel format (29F/27.5R) keeps the rear end agile while preserving the front wheel's rollover advantage. Wheelbase 1214 to 1259 mm.
Build and value. Single base trim at £5,899 (25.9 kg). Build varies across trim levels — entry gets RockShox 35 Silver TK fork, Fox Float X Performance rear shock, Shimano M4100/MT420 4-piston brakes, and Shimano Deore XT M8100 mixed drivetrain. Higher trims step up to Fox 38 Float Factory at 180 mm front. At under £6,000 for a Bosch CX Gen 4 carbon mullet enduro with 750 Wh battery, the Kapoho was a strong value play during its production run.
Community-verified strengths.
- Bosch CX Gen 4 motor and 750 Wh PowerTube ecosystem support is the longest-running and best-developed in the eMTB market.
- Carbon Dimmix Performance frame with Straight-Line-Link suspension is well-engineered Austrian quality.
- Mullet (29F/27.5R) format with 160/160 mm travel hits the sweet spot for trail-with-attitude riding.
Caveats and known gripes.
- Production status: discontinued. New buyers will be looking at second-hand examples or KTM's current Macina Lycan/Prowler successors.
- @RickBullotta documented weight balance issues on an older KTM Macina: "I almost killed myself on a big drop on my first eMTB (KTM Macina) because it was soooo nose heavy." Worth investigating on the specific Kapoho geometry.
- 25.9 kg claimed weight is heavy for a carbon enduro by 2024+ standards.
- Fixed 442 mm chainstays across all three sizes — no size-tuning.
- Bosch CX Gen 4 is now a generation behind the current CX Gen 5 (120 Nm) and CX-R race motor — replacement motors are still available but the platform feels less powerful versus 2025-2026 rivals.
- @RickBullotta's ownership progression: KTM Macina → Pivot Shuttle → Orbea Rise → Gen 3 Levo → Amflow PL Pro. The Macina was the starting point but not the destination.
Verdict. The KTM Macina Kapoho 2024 was a properly considered Austrian carbon mullet enduro for buyers who valued the Bosch CX Gen 4 ecosystem and KTM's engineering pedigree. As a current new purchase it's discontinued — used examples in good condition remain genuine bargains for buyers who want a 160/160 mm carbon mullet at strong used pricing. New buyers should look at the current KTM Macina Lycan trail platform, or rivals like the Canyon Spectral:ON, Cube AMS Hybrid 177 and Norco Sight VLT for similar travel categories. Production status: discontinued.
Frame
Macina Kapoho Dimmix Perf. Carbon, Straight-Line-Link (SLL) suspension, 160mm rear travel, DiMMiX 29in front / 27.5in rear mullet, UDH, internal cable routing
| M | L | XL | |
| Reach | 445 mm | 463 mm | 480 mm |
| Stack | 603 mm | 612 mm | 626 mm |
| Chainstay | 442 mm | 442 mm | 442 mm |
| Headtube Angle | 65° | 65° | 65° |
| Seattube Angle (eff) | 76° | 76° | 76° |
| Wheelbase | 1214 mm | 1236 mm | 1259 mm |
| Front Centre | 772 mm | 794 mm | 817 mm |
Trims · 2
Base £5,899 | Elite | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm · all trims | |
| Battery | Bosch PowerTube 750 · 750 Wh · all trims | |
| Travel F/R | 160/160 mm · all trims | |
| Frame | Carbon · all trims | |
| Fork | RockShox 35 Silver TK 29in 160mm 15x110 taper (Elite); FOX 38 Float 29in Factory 180mm on higher trims | RockShox 35 Silver TK 29in 160mm |
| Shock | FOX Float X Performance 250x70 · all trims | |
| Headset | Acros AICR internal 1.1/8in-1.5in angle limit | Acros AICR internal 1.1/8"-1.5" angle limit |
| Stem | KTM Team Trail35 | KTM TEAM II Trail35 |
| Handlebar | KTM Team Trail35 rizer25 800mm · all trims | |
| Grips | Ergon GA20 · all trims | |
| Saddle | Selle San Marco Ground Short Open Fit Narrow · all trims | |
| Seatpost | KTM Comp dropper internal | KTM COMP II dropper internal |
| Brakes | Shimano M4100 / MT420 4-piston with Shimano RT64 CL rotors | Shimano M4100/MT420 4-piston 203/180 |
| Rear derailleur | Shimano Deore XT M8100-12 SGS Shadow+ · all trims | |
| Crank | KTM E-TRAIL ISIS 160mm Q16 · all trims | |
| Shifters | Shimano Deore M6100-12 · all trims | |
| Cassette | Shimano Deore M6100-12 / 10-51 | Shimano Deore M6100-12, 10-51T |
| Chain | Shimano M6100-12 · all trims | |
| Drivetrain | 1x12 Shimano Deore XT / Deore | Shimano Deore XT M8100-12 SGS shadow+ |
| Wheels | 29in front / 27.5in rear DiMMiX mullet on Shimano MT410B hubs and Ambrosio E30/E35 rims | Ambrosio E30 Trail (front) / E35 Trail (rear) |
| Tyres | Maxxis Minion DHF 3C-MaxxTerra/EXO/TR 63-622 (f); Maxxis Minion DHR II 3C-MaxxTerra/EXO/TR 70-584 (r) | Maxxis Minion DHF / Minion DHR II |
| Weight | 25.9 kg | — |
| Price | £5,899 | — |
Spot a mistake?
