Bike Finder · Instinctiv
Instinctiv Ocelot 135
Instinctiv
Ocelot 135 2026
CurrentLightweight eMTB🔥 Hot · 9/10iFreshness 9/10
Carbon 160/135 trail eMTB with Maxon AIR S bikedrive (90Nm/620W) and 400Wh battery
Motor
Maxon BIKEDRIVE AIR S · 90Nm · 620W
Battery
400Wh
Travel F/R
160/135mm
Wheels
29F/29R
Frame
Full carbon
Weight
17.7 kg
Price
£7,080
View the Instinctiv Ocelot 135 on Instinctiv’s site
Instinctiv Ocelot 135 2026
From £7,080
EMTB Forums verdict
The Instinctiv Ocelot 135 2026 is a boutique Swiss lightweight eMTB from a small-volume brand that uses Maxon's BIKEDRIVE AIR S motor (90 Nm, 250 W rated, 620 W peak, 2.0 kg) and a 400 Wh integrated battery. Travel is 160 mm front and 135 mm rear via Instinctiv's PUMA four-bar layout. The head angle is a properly slack 64.5°, and Instinctiv quotes a 20.6 kg ride weight. Base trim is €10,835 — premium pricing reflecting the small-batch boutique nature and the rare Maxon drive system. @CoolWetGrass notes "first bikes expected to ship Q1 2026; none in public circulation as of Oct 2025", so the Ocelot 135 is fundamentally an order-and-wait proposition.
Drive system and range. The Maxon BIKEDRIVE AIR S is the headline differentiator — a Swiss-made motor from the company that supplies drive systems to NASA's Perseverance rover. It produces 90 Nm of torque, 620 W peak power and weighs just 2.0 kg, with claimed drivetrain efficiency of 83% that places it among the strongest in the lightweight class. The 400 Wh internal pack is small by mainstream eMTB standards but sized to the bike's weight target. Real-world range data from the few pre-production rides points to 800-1,200 m of climbing per charge in trail mode. The Maxon ecosystem includes a phone app for ride mode customisation and over-the-air firmware updates.
Geometry and handling. Three sizes — S 430 mm, M 455 mm, L 480 mm reach — with a steady 25 mm progression. The head angle stays at 64.5° across the range, and chainstays are fixed at 445 mm. Wheelbase grows from 1,206 mm on the S to 1,265 mm on the L. The 77° effective seat tube angle is properly steep for modern climbing posture. Note there is no XL frame, so taller riders (above roughly 6'2") will be cramped on the L. The PUMA suspension layout is derived from Instinctiv's gearbox-platform Kodiak frame, and shares the same kinematic principles.
Build and value. The €10,835 base trim is a high-end specification — Instinctiv does not chase entry-level price points. Expect Fox Factory or RockShox Ultimate suspension, SRAM Eagle Transmission and premium DT Swiss or carbon wheels at this level. Frame variants in the Ocelot lineup include the Ocelot 125, 135 and 145, each with travel-matched suspension; the 135 sits in the middle as a true do-it-all trail bike. Instinctiv is a small Swiss operation, so build customisation is likely available and worth discussing direct with the factory. The brand's competitor on price is the Swiss-flag Kalkhoff or the German Niner-style direct brands, but the Maxon motor genuinely is rare.
Caveats and known gripes. No public-circulation owner experience exists yet on this exact model — at the time of writing the Ocelot 135 was a pre-order proposition with first deliveries expected Q1 2026. The €10,835 base price is bracingly high for a 400 Wh / 135 mm trail bike: Specialized Levo SL, Trek Fuel EXe and Whyte E-Lyte all undercut by several thousand euros. Maxon motor service network is much thinner than Bosch, Shimano or Specialized — buyers will need to factor in motor return-to-Switzerland service for major fixes. The 400 Wh battery is small, and there's no published range-extender option from Instinctiv at present. A previous Instinctiv issue with bonded headset bowls (reported by an unnamed rider on the forum) is worth checking with the factory before ordering.
Verdict. The Ocelot 135 is for the boutique-minded rider who wants something different: Swiss-built, Maxon-powered, light at 20.6 kg, and properly slack at 64.5°. It rewards buyers who value rarity, engineering provenance and direct-from-builder service over volume-brand convenience. It is not for buyers chasing value, big battery range, deep dealer support, or anyone over 6'2" given the missing XL frame. Production status is current with first deliveries expected Q1 2026.
Bike geometry diagram
SML
Toptube571 mm599 mm627 mm
Reach430 mm455 mm480 mm
Stack622 mm631 mm640 mm
Seattube390 mm410 mm430 mm
Chainstay445 mm445 mm445 mm
Headtube Angle64.5°64.5°64.5°
Seattube Angle (eff)77.21°77.15°77.09°
BB Drop26 mm26 mm26 mm
Wheelbase1206 mm1236 mm1265 mm
Headtube105 mm115 mm125 mm
BB Height346 mm346 mm346 mm
Standover694 mm702 mm710 mm
Front Centre761 mm791 mm820 mm
Trims · 1
Ocelot 135
£7,080
MotorMaxon BIKEDRIVE AIR S · 90 Nm
Battery400 Wh
Travel F/R160/135 mm
FrameCarbon fibre monocoque
ForkFox Float 36 Factory (160mm)
ShockFox Float X Factory
HeadsetAcros headset bearings
Stem77Designz One Piece Stem 35 mm
HandlebarRaceface Turbine R35 alloy, 8° backsweep, 20mm rise
GripsErgon GE1 MTB Enduro Evo
SeatpostOneUp V3 180mm dropper
BrakesMagura Louise Elite
Rear derailleurSRAM Eagle 90 Transmission
Cranke*thirteen Helix Core Alloy Cranks, 165 mm, 32T e*thirteen SRAM direct mount chainring
ShiftersSRAM Eagle 90 Transmission shifter (T-Type)
CassetteSRAM XS-1275 T-Type, 10-52T
ChainSRAM GX Eagle Transmission Flattop
DrivetrainSRAM Eagle 90 Transmission
WheelsDT Swiss H1900 Spline 29in aluminium or HXC 1501 carbon
TyresSchwalbe Albert Trail 63-622 29x2.50 front, Schwalbe Romy Gravity Pro 62-622 29x2.4 rear
Weight17.7 kg
Price£7,080
Spot a mistake?
