Bike Finder · Husqvarna
Husqvarna Light Cross LC6
Husqvarna
Light Cross LC6 2024
CurrentTrail eMTBLegacy · 2.7/10iFreshness 2.7/10
Carbon Light Cross XC/trail eMTB with Shimano motor (85Nm/250W)
Motor
Shimano EP801 · 85Nm · 600W
Battery
720Wh
Travel F/R
130/120mm
Wheels
Mullet
Frame
Full carbon
Weight
23.2 kg
Price
£6,030
View the Husqvarna Light Cross LC6 on Husqvarna’s site
Husqvarna Light Cross LC6 2024
From £6,030
EMTB Forums verdict
The Husqvarna Light Cross LC6 2024 is a carbon trail eMTB sitting in the higher tier of Husqvarna's Light Cross lineup. Headline numbers: 130mm fork, 120mm rear, Shimano EP801 motor at 85Nm and a 600W peak with a 2.7kg motor mass, a 720Wh battery, 66.0 to 66.5 degree head angle and reach 428 to 513mm across S, M, L and XL. Husqvarna is the Pierer Mobility/KTM-group sister brand to GasGas and KTM; the Light Cross line shares engineering DNA with the KTM Macina Prowler family but with its own carbon frame moulds and a more trail-leaning geometry brief. With no curated Husqvarna-specific community quotes on file, this verdict draws on the gold spec and known platform behaviour.
Drive system and range. The Shimano EP801 is one of the most refined full-power motors on the market: 85Nm of torque, a 600W peak, a 2.7kg motor mass and Shimano's signature smooth-bite power delivery. Compared to the previous EP8 the 801 brings better thermal management and improved firmware mode tuning, and pairs with Shimano's well-mapped E-Tube app for personalisation. A 720Wh battery is generous for a 130/120mm trail platform: expect 1,500 to 1,800m of vertical and three to four hours of mixed trail riding in Trail/Boost modes. Battery removability is not in the gold spec: buyers should confirm with their Husqvarna dealer.
Geometry and handling. 66.0 degrees on the S, settling to 66.5 degrees on M, L and XL is on the conservative side of modern trail eMTB geometry: steeper than a Levo SL or Trek Fuel EXe and biased toward XC-leaning use. Reach steps cleanly: 428 (S), 463 (M), 488 (L), 513 (XL): a healthy 35mm jump between S and M for fit flexibility. Chainstays are a uniform 445mm and wheelbase tops out at 1270mm on XL. The package suits riders who prioritise efficient pedalling and trail/XC use over slack-and-low descent capability.
Build and value. The gold spec lists a single base trim; Husqvarna's Light Cross LC6 sits above the LC4 and below the top-tier LC7/8 variants in its catalogue, with a high-quality carbon frame, Shimano EP801 motor and the larger 720Wh battery as standard. Build kit on a higher-tier Light Cross typically pairs Fox 34/36 Performance or Factory suspension with Shimano XT 4-piston brakes and an XT 1x12 drivetrain: properly capable for the travel envelope. Standout: the 720Wh battery is generous for the segment. Questionable: the geometry is conservative versus 2025/2026 trail bike conventions.
Caveats and known gripes.
  • Conservative geometry. 66.0 to 66.5 degree head angle is steep by 2025 trail eMTB standards; riders coming from a slacker bike will need to re-learn line choice on steeper descents.
  • Limited UK dealer network. Husqvarna bicycles are well-distributed in Germany, Austria and Italy but thinner in the UK and US; warranty routing is via local Husqvarna powersport dealers in some markets.
  • Battery removability not confirmed. Confirm at point of sale: integrated batteries impact storage and travel logistics.
  • Light on community signal. The Light Cross has very limited owner reporting on the eMTB Forums community as of 2026; long-term motor and frame reliability data is yet to mature.
  • Trail-not-enduro travel. 130/120mm is firmly in the XC-trail bracket; bigger hits and longer descents will ask more of the rider.
  • Brand price premium. Husqvarna is a premium-positioned brand in central Europe; the Light Cross LC6 typically sits at the upper end of equivalently-specced rivals from Cube, Canyon and Whyte.
Verdict. The Light Cross LC6 is a Shimano-powered carbon trail eMTB with a generous 720Wh battery, conservative-but-honest trail geometry and the engineering credibility of the Pierer Mobility group behind it. It suits riders who want a Shimano EP801-powered carbon trail bike, who ride mostly XC, trail centres and moderate natural terrain, and who can access Husqvarna dealer support. Buyers chasing slacker geometry, enduro-grade travel or a more established eMTB community footprint should look at the Specialized Levo, Trek Fuel EXe or Whyte E-160 lineups instead. Production status: current.
Bike geometry diagram
SMLXL
Reach428 mm463 mm488 mm513 mm
Stack607 mm623 mm636 mm650 mm
Chainstay445 mm445 mm445 mm445 mm
Headtube Angle66°66.5°66.5°66.5°
Seattube Angle (eff)78.6°78.3°78.2°78°
BB Drop23 mm23 mm23 mm23 mm
Wheelbase1174 mm1208 mm1239 mm1270 mm
Headtube130 mm135 mm140 mm145 mm
Front Centre729 mm763 mm794 mm825 mm
Trims · 1
Light Cross LC6
£6,030
MotorShimano EP801 · 85 Nm
Battery720 Wh
Travel F/R130/120 mm
FrameCarbon
ForkRockShox Pike Select, DebonAir, Air, 130 mm, tapered
ShockRockShox SIDLuxe Select+
HeadsetAcros ICR, blocklock, ZS56/ZS56
StemHusqvarna 35, 0°, Ahead
HandlebarHusqvarna Riser 35 mm, 780 mm, Sweep 9°, Rise 20 mm
GripsHusqvarna MTB, Lock-on grips
SaddleHusqvarna MTB
SeatpostHusqvarna Pro, 31.6 mm, Dropper post
DrivetrainSRAM X01 Eagle 12-speed
Wheels27.5" Aluminium; Husqvarna DA210F front / DA210R rear hubs
Weight23.2 kg
Price£6,030
Spot a mistake?
