Bike Finder · Haibike
Haibike Lyke
Haibike
Lyke 2026
CurrenteMTB SL / lightweight full-suspension trailLegacy · 2.4/10iFreshness 2.4/10
Motor
Fazua Ride 60 · 60Nm · 450W
Battery
Fazua Energy InTube · 480Wh
Travel F/R
140/140mm
Wheels
MX (29F / 27.5R)
Frame
Carbon front, aluminium rear
Weight
18.5 kg
Price
From £5,899
View the Haibike Lyke on Haibike’s site
Haibike Lyke 2026
From £5,899
Bike geometry diagram
SMLXL
Reach424 mm452 mm479 mm506 mm
Stack611 mm620 mm629 mm638 mm
Chainstay450 mm450 mm450 mm450 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)77.3°77.3°77.3°77.3°
Trims · 3
Lyke CF 10
£5,899
Lyke CF 11
£6,799
Lyke CF SE
£9,999
MotorFazua Ride 60 · 60 Nm · all trims
BatteryFazua Energy InTube · 480 Wh · all trims
Travel F/R140/140 mm · all trims
FrameCarbon (CF) with alloy rocker · all trims
ForkRockShox Pike Select+ Charger 3.1 RC2, DebonAir+, 140mm, 44mm offsetFox 36 Float Performance Air, 140mmRockShox Pike Ultimate Flight Attendant, 140mm
ShockRockShox Deluxe Select+ 210x52.5mm, DebonAir+Fox Float Performance DPS EVOL AirRockShox Super Deluxe Ultimate Flight Attendant
HeadsetAcros ICR, ZS56/ZS56, Semi-Integrated, BlockLockAcros BlockLock, Aluminium
StemXLC ST-M50, 35 mmRace Face Aeffect R, 35 mm, 40 mm
HandlebarXLC HB-M34, 35 mm, Rise 20 mm, backsweep 9°, 800 mmRace Face Turbine R Riser Bar, 35 mm, Rise 20 mm
GripsXLC GR-S34 Gravity Grip
SaddlePrologo Proxim W450 PerformanceSelle Italia Model X Black
SeatpostLimotec A1H DropperLimotec A1H Dropper, 31.6 mm, Travel 125 mm
BrakesSRAM DB8 hydraulic discShimano Deore XT M8120 4-pistonSRAM (T-Type build)
Rear derailleurSRAM Eagle 90 T-Type 12-speedShimano Deore XT M8100 12-speedSRAM XX Eagle T-Type 12-speed (wireless)
CrankRotor Crankset for Fazua, 165 mmRotor E-Kapic Crankset + DM Chainring for Fazua Ride 60
ShiftersSRAM Eagle 90 T-Type 12-speedShimano SLX SL-M7100-IR Rapidfire+ Trigger shifter
CassetteSRAM XS-1270 Eagle T-Type 12-speedShimano SLX CS-M7100-12, 10-51T
ChainSRAM Eagle 70 T-TypeShimano SLX CN-M7100 SIL-TECH
DrivetrainSRAM Eagle 90 T-Type 12-speed; Rotor Crankset for Fazua, 165 mm; SRAM Eagle 90 T-Type 12-speed; SRAM XS-1270 Eagle T-Type 12-speed; SRAM Eagle 70 T-TypeShimano Deore XT M8100 12-speed; Rotor E-Kapic Crankset + DM Chainring for Fazua Ride 60; Shimano SLX SL-M7100-IR Rapidfire+ Trigger shifter; Shimano SLX CS-M7100-12, 10-51T; Shimano SLX CN-M7100 SIL-TECHSRAM XX Eagle T-Type 12-speed (wireless)
Wheels29" wheelsetDT Swiss HX 1700 Spline LS, 15x110 mm / 12x148 mm
TyresContinental Xynotal 29"Maxxis Dissector 3C MaxxTerra EXO 29x2.4"
Weight18.5 kg
Price£5,899£6,799£9,999
Spot a mistake?
