Bike Finder · Giant
Giant Talon E+
Giant
Talon E+ 2024
DiscontinuedLightweight · Cross-CountryLegacy · 0.9/10iFreshness 0.9/10
Motor
Giant SyncDrive Core · 55Nm · 250W
Battery
Giant EnergyPak 500 · 500Wh
Travel F/R
100mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
From £2,249
View the Giant Talon E+ on Giant’s site
Giant Talon E+ 2024
From £2,249
EMTB Forums verdict
The Giant Talon E+ 29 is the brand's entry-level electric hardtail, an aluminium 29er built around 100mm of coil-sprung front travel, a 68-degree head angle and a long 475mm chainstay across every size. The geometry is classic trail-friendly hardtail rather than aggressive: a 73-degree seat angle and reach figures from 384mm (S) to 470mm (XXL) make it an approachable do-it-all bike for trails, dirt roads and commuting rather than a steep technical descender.
Power comes from Giant's own SyncDrive Core mid-motor, a smooth 55Nm unit run through the RideControl Dash controller with Smart Assist and five support levels. It is the gentlest motor in Giant's eMTB range, so this is a bike for extending your range and easing climbs rather than chasing the highest torque figures.
Three trims were offered in the UK. The 29 3 (£2,249) pairs a Shimano Altus/Alivio 9-speed drivetrain and Tektro brakes with the smaller 400Wh EnergyPak. The 29 2 (£2,399) keeps that build but steps up to the 500Wh pack. The top 29 1 (£2,599) adds a 500Wh battery, a 10-speed Shimano Deore drivetrain, Shimano hydraulic brakes and a lockout XCR fork, making it the pick for riders who want the longer range and crisper shifting. All three share the same frame, geometry and Maxxis Rekon 2.4in tyres.
This generation is now discontinued. Giant has since replaced it with an all-new Talon E+ built around the more powerful SyncDrive Sport 2 motor, a removable EnergyPak 430 battery and a RideControl Dash 2 controller, so the SyncDrive Core bike documented here is a previous-generation model best found on clearance.
Geometry read
Size
Descending
38
Steeper 68° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Playfulness
52
Size balance
40
Rear-long with a planted front in L (FC:RC 1.51) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
62
Climbs well — a 73° seat keeps the front planted. 250W of peak power and 50Nm of torque.
Watch out forNot built for serious descending — happier on flow than in the rough and steep.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Lightweight · Cross-Country bikes (from 62 bikes in the database)
Battery500 Wh65 Wh above average
Motor torque55 Nmabout average torque
Value for money88/100from £2,249 · comparable bikes ~£2,999
💬 Forum discussion
Giant talon e+ wont power off display froze ? Help
9 replies · 3.8k views · last reply 38 months ago
Join the discussion →
Bike geometry diagram
SMLXLXXL
Reach384 mm406 mm428 mm449 mm470 mm
Stack625 mm634 mm643 mm657 mm671 mm
Seattube405 mm455 mm505 mm535 mm560 mm
Chainstay475 mm475 mm475 mm475 mm475 mm
Headtube Angle68°68°68°68°68°
Seattube Angle (eff)73°73°73°73°73°
Wheelbase1141 mm1167 mm1193 mm1219 mm1245 mm
Headtube105 mm115 mm125 mm140 mm155 mm
Standover723 mm753 mm788 mm808 mm828 mm
Front Centre666 mm*692 mm*718 mm*744 mm*770 mm*
FC:RC1.401.461.511.571.62
Trims · 3
29 3
£2,249
29 2
£2,399
29 1
£2,599
MotorGiant SyncDrive Core · 55 Nm · all trims
BatteryGiant EnergyPak 500 · 500 Wh · all trims
Travel F/R100/? mm · all trims
FrameAluminium · all trims
ForkSR Suntour XCM 32 ATB Coil NLO, 29in 100mm travel, Tapered 1.5 - 1.125in steererSR Suntour XCM 32 ATB Coil NLO, 29in 100mm travel, Tapered 1.5in - 1.125in steererSR Suntour XCR 32 Coil LO Boost 29 100mm travel, Tapered 1.5 - 1.125in steerer, lockout
Shockn/a · all trims
HeadsetOverdrive 1.5 - 1.125in · all trims
StemGiant Contact · all trims
HandlebarGiant Connect TR Riser 31.8x720~780mm (S: 720mm, M: 750mm, L/XL/XXL: 780mm) · all trims
GripsGiant Sole-O Grip · all trims
SaddleGiant Sport · all trims
SeatpostGiant 30.9mm, 2-bolt Micro Adjustable, Forged Aluminium · all trims
BrakesTektro HD-M285, hydraulic disc, 180mm [F], 160mm [R]; levers Tektro HD-M285Tektro HD-M285, hydraulic disc, 180mm [F], 160mm [R]; levers Tektro HD-M285Shimano BR-MT200, hydraulic disc, 180mm; levers Shimano BL-MT200
Rear derailleurShimano Alivio, 9-speedShimano Alivio, 9-speedShimano Deore, 10-speed, Shadow+
CrankFSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T · all trims
ShiftersShimano AltusShimano AltusShimano Deore 10-speed
CassetteShimano CS-HG200, 11-36T, 9-speedShimano CS-HG200, 11-36T, 9-speedShimano Deore, CS-M4100, 11-42T, 10-speed
ChainKMC e.9 Sport, e-bike optimizedKMC e.9 Sport, e-bike optimizedKMC e.10 Sport, e-bike optimized
DrivetrainShimano Alivio, 9-speed; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Altus; Shimano CS-HG200, 11-36T, 9-speed; KMC e.9 Sport, e-bike optimizedShimano Alivio, 9-speed; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Altus; Shimano CS-HG200, 11-36T, 9-speed; KMC e.9 Sport, e-bike optimizedShimano Deore, 10-speed, Shadow+; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Deore 10-speed; Shimano Deore, CS-M4100, 11-42T, 10-speed; KMC e.10 Sport, e-bike optimized
WheelsGiant GX03V, 29er, Aluminium · all trims
TyresMaxxis Rekon 29x2.4in Wire Bead 60TPI · all trims
Price£2,249£2,399£2,599
Rides similarly
Spot a mistake?
