Bike Finder · Giant
Giant Talon E+
Giant
Talon E+ 2023
DiscontinuedLightweight · Cross-CountryLegacy · 0.3/10iFreshness 0.3/10
Motor
Giant SyncDrive Core · 55Nm · 250W
Battery
Giant EnergyPak 500 · 500Wh
Travel F/R
100mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
From £2,249
View the Giant Talon E+ on Giant’s site
Giant Talon E+ 2023
From £2,249
EMTB Forums verdict
The Giant Talon E+ (2023) is Giant's entry-level off-road hardtail eMTB, built around a lightweight ALUXX aluminium frame with 100mm of front travel and 29-inch wheels. It uses Giant's own SyncDrive Core motor (Yamaha-based, 55Nm) paired with an EnergyPak battery, making it an approachable cross-country and trail bike rather than a heavy-hitting full-susser.
Three 29-inch trims were offered for the UK in 2023: the 29 1 (RRP GBP 2,599) with a Shimano Deore 10-speed drivetrain, lockout SR Suntour XCR fork and 500Wh battery; the 29 2 (RRP GBP 2,399) with Shimano Altus/Alivio 9-speed, Tektro brakes and 500Wh battery; and the 29 3 (RRP GBP 2,249) matching the 29 2 spec but with a smaller 400Wh battery. Geometry is shared across all sizes, with a relaxed 68-degree head angle and 73-degree seat angle.
This is a discontinued 2023 model year bike, so availability is now limited to old stock and the used market. For riders wanting a simple, reliable pedal-assist hardtail for fire roads and gentler trails, it remains a sensible budget choice, though the entry-level coil fork and 9/10-speed drivetrains mark it firmly as a value-focused machine.
Geometry read
Size
Descending
38
Steeper 68° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Playfulness
52
Size balance
40
Rear-long with a planted front in L (FC:RC 1.51) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
62
Climbs well — a 73° seat keeps the front planted. 250W of peak power and 50Nm of torque.
Watch out forNot built for serious descending — happier on flow than in the rough and steep.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Lightweight · Cross-Country bikes (from 63 bikes in the database)
Battery500 Wh64 Wh above average
Motor torque55 Nmabout average torque
Value for money88/100from £2,249 · comparable bikes ~£2,999
💬 Forum discussion
Giant talon e+ wont power off display froze ? Help
9 replies · 3.8k views · last reply 38 months ago
Join the discussion →
Bike geometry diagram
SMLXLXXL
Reach384 mm406 mm428 mm449 mm470 mm
Stack625 mm634 mm643 mm657 mm671 mm
Seattube405 mm455 mm505 mm535 mm560 mm
Chainstay475 mm475 mm475 mm475 mm475 mm
Headtube Angle68°68°68°68°68°
Seattube Angle (eff)73°73°73°73°73°
Wheelbase1141 mm1167 mm1193 mm1219 mm1245 mm
Headtube105 mm115 mm125 mm140 mm155 mm
Standover723 mm753 mm788 mm808 mm828 mm
Front Centre666 mm*692 mm*718 mm*744 mm*770 mm*
FC:RC1.401.461.511.571.62
Trims · 3
29 3
£2,249
29 2
£2,399
29 1
£2,599
MotorGiant SyncDrive Core · 55 Nm · all trims
BatteryGiant EnergyPak 500 · 500 Wh · all trims
Travel F/R100/? mm · all trims
FrameAluminium · all trims
ForkSR Suntour XCM 32 ATB Coil NLO, 29" 100mm travel, Tapered 1½ - 1⅛" steererSR Suntour XCM 32 ATB Coil NLO, 29" 100mm travel, Tapered 1½" - 1⅛" steererSR Suntour XCR 32 Coil LO Boost 29 100mm travel, Tapered 1½ - 1⅛" steerer, lockout
HeadsetOverdrive 1½ - 1⅛" · all trims
StemGiant Contact · all trims
HandlebarGiant Connect TR Riser 31.8x720~780mm (S: 720mm, M: 750mm, L/XL/XXL: 780mm) · all trims
GripsGiant Sole-O Grip · all trims
SaddleGiant Sport · all trims
SeatpostGiant 30.9mm, 2-bolt Micro Adjustable, Forged Aluminium · all trims
BrakesTektro HD-M285, hydraulic disc, 180mm [F], 160mm [R]Tektro HD-M285, hydraulic disc, 180mm [F], 160mm [R]Shimano BR-MT200, hydraulic disc, 180mm
Rear derailleurShimano Alivio, 9-speedShimano Alivio, 9-speedShimano Deore, 10-speed, Shadow+
CrankFSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T · all trims
ShiftersShimano AltusShimano AltusShimano Deore 10-speed
CassetteShimano CS-HG200, 11-36T, 9-speedShimano CS-HG200, 11-36T, 9-speedShimano Deore, CS-M4100, 11-42T, 10-speed
ChainKMC e.9 Sport, e-bike optimizedKMC e.9 Sport, e-bike optimizedKMC e.10 Sport, e-bike optimized
DrivetrainShimano Alivio, 9-speed; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Altus; Shimano CS-HG200, 11-36T, 9-speed; KMC e.9 Sport, e-bike optimizedShimano Alivio, 9-speed; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Altus; Shimano CS-HG200, 11-36T, 9-speed; KMC e.9 Sport, e-bike optimizedShimano Deore, 10-speed, Shadow+; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Deore 10-speed; Shimano Deore, CS-M4100, 11-42T, 10-speed; KMC e.10 Sport, e-bike optimized
WheelsGiant GX03V, 29er, Aluminium · all trims
TyresMaxxis Rekon 29x2.4" Wire Bead 60TPI · all trims
Price£2,249£2,399£2,599
Rides similarly
Spot a mistake?
