Bike Finder · Giant
Giant Talon E+
Giant
Talon E+ 2022
DiscontinuedLightweight · Cross-CountryLegacy · 0.3/10iFreshness 0.3/10
Budget alloy hardtail for commutes and easy off-road miles
Motor
Giant SyncDrive Core · 50Nm · 250W
Battery
Giant EnergyPak 500 · 500Wh
Travel F/R
100mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
From £2,399
View the Giant Talon E+ on Giant’s site
Giant Talon E+ 2022
From £2,399
EMTB Forums verdict
The Giant Talon E+ (2022) is Giant's entry-level off-road hardtail eMTB, built around a lightweight ALUXX aluminium frame with 100mm of front travel and 29-inch wheels. It uses Giant's own SyncDrive Core motor (Yamaha-based, 50Nm) paired with a 500Wh EnergyPak battery, making it an approachable cross-country and trail bike rather than a heavy-hitting full-susser.
Two 29-inch trims were offered for the UK in 2022: the Talon E+ 1 (RRP GBP 2,499) with a Shimano Deore 10-speed drivetrain, a lockout SR Suntour XCR coil fork and Tektro hydraulic brakes; and the Talon E+ 2 (RRP GBP 2,399) with a Shimano Altus/Alivio 9-speed drivetrain, a simpler SR Suntour XCM coil fork and Tektro brakes. Both share the same 500Wh battery. Geometry is shared across all sizes, with a relaxed 68-degree head angle and a 73-degree seat angle.
This is a discontinued 2022 model year bike, so availability is now limited to old stock and the used market. There is no published rider or owner feedback to cite here. For riders wanting a simple, reliable pedal-assist hardtail for fire roads and gentler trails, it remains a sensible budget choice, though the entry-level coil fork and 9/10-speed drivetrains mark it firmly as a value-focused machine.
Geometry read
Size
Descending
38
Steeper 68° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Playfulness
52
Size balance
40
Rear-long with a planted front in L (FC:RC 1.51) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
62
Climbs well — a 73° seat keeps the front planted. 250W of peak power and 50Nm of torque.
Watch out forNot built for serious descending — happier on flow than in the rough and steep.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Lightweight · Cross-Country bikes (from 70 bikes in the database)
Battery500 Wh50 Wh above average
Motor torque50 Nm9 Nm below average
Value for money80/100from £2,399 · comparable bikes ~£2,999
💬 Forum discussion
Giant talon e+ wont power off display froze ? Help
9 replies · 3.8k views · last reply 38 months ago
Join the discussion →
Bike geometry diagram
SMLXLXXL
Reach384 mm406 mm428 mm449 mm470 mm
Stack625 mm634 mm643 mm657 mm671 mm
Seattube405 mm455 mm505 mm535 mm560 mm
Chainstay475 mm475 mm475 mm475 mm475 mm
Headtube Angle68°68°68°68°68°
Seattube Angle (eff)73°73°73°73°73°
Wheelbase1141 mm1167 mm1193 mm1219 mm1245 mm
Headtube105 mm115 mm125 mm140 mm155 mm
Standover723 mm753 mm788 mm808 mm828 mm
Front Centre666 mm*692 mm*718 mm*744 mm*770 mm*
FC:RC1.401.461.511.571.62
Trims · 2
£2,399
£2,499
MotorGiant SyncDrive Core · 50 Nm · all trims
BatteryGiant EnergyPak 500 · 500 Wh · all trims
Travel F/R100/? mm · all trims
FrameAluminium · all trims
ForkSR Suntour XCM ATB Coil 29" 100mm travel, Tapered 1½ - 1⅛" steererSR Suntour XCR 32 Coil LO Boost 29 100mm travel, Tapered 1½ - 1⅛" steerer, lockout
HeadsetOverdrive 1½ - 1⅛" · all trims
StemGiant Contact · all trims
HandlebarGiant Connect TR Riser 31.8x690~750mm · all trims
GripsGiant Sole-O Grip · all trims
SaddleGiant Sport · all trims
SeatpostGiant 30.9mm, 2-bolt Micro Adjustable, Forged Aluminium · all trims
BrakesTektro HD-M275, hydraulic disc, 160/180mmTektro HD-M280, hydraulic disc, 180mm
Rear derailleurShimano Alivio, 9-speedShimano Deore, 10-speed, Shadow+
CrankFSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T · all trims
ShiftersShimano AltusShimano Deore
CassetteShimano CS-HG200, 11-36T, 9-speedShimano HG50-10, 11-42T, 10-speed
ChainKMC e.9 Sport, e-bike optimizedKMC e.10 Sport, e-bike optimized
DrivetrainShimano Alivio, 9-speed; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Altus; Shimano CS-HG200, 11-36T, 9-speed; KMC e.9 Sport, e-bike optimizedShimano Deore, 10-speed, Shadow+; FSA Comet E-Bike crank arm set, FSA MegaTooth Direct-mount 1X steel 36T; Shimano Deore; Shimano HG50-10, 11-42T, 10-speed; KMC e.10 Sport, e-bike optimized
WheelsGiant GX03V · all trims
TyresMaxxis Rekon 29x2.4" Wire Bead 60TPI · all trims
Price£2,399£2,499
Rides similarly
Spot a mistake?
